Guide on data2ext!
manny29
348
14
Ok here it is if I forget something then correct me....
1.Ok first install a fresh cm7 ath3nos rom with gapps.
2.reboot let it boot up and back up your files on ur sdcard
3.now. go to advance a partition follow.
Ext--1024
Swap--0 leave it at zero.
4.get data2ext2-v7.zip----on second post by----basketthis
5.go to terminal
6.(code)---mke2fs-m0-b4096 /Dev/block/mcblk0p2
7.data2ext --enable
Also really. Nice guide here thank--ens04
http://optimusv.wikispaces.com/Moving+data+directory+to+MicroSD+with+Data2ext
Sent from my LG-LS670 using Tapatalk
I don't get its more complicated The when using a ra-recovery when u could do it in the recovery partitioning ok I guess I will do more research thanks
Yea I'm on ath3nos Gingerbread an the files on modules. Are not there
Re: Help please data2ext.;)
I understand the first part about gingerbread but wtf us the second part about? You should have no problems with modules....
I don't know what exactly I have to do I'm just asking for that first step.....lol
And for that second part on reborn there is data2ext in modules. Y gingerbread doesn't. Have it
Look at the link I posted. It's all the steps... its the other way around reborn doesn't have them. Cm7 port does
Actually I'm kind of confused about this whole situation too. Am I supposed to make a partition first, or do the zips from the data2ext thread do that? It never really specifies, and I think I understand what's going on, but I've bricked my phone twice, and I thought I knew what was going on then too. Please, I know I may seem stupid, but sdext is something I've never delved into before. If I guess wrong and brick my phone again, I might just break down and shoot myself in the head.:'(
Oh jesus christ. I jumped and partitioned my sd card, I didn't know it would wipe my whole card. I have backups, but god, I don't feel like doing this at 1 in the morning.
Anytime you play with partitions plan on losing any info on it.
Grab the ext2 data2ext and flash, follow the instructions to format and set block size, restart and run the data2ext --enable then restart. You can verify it worked by looking in settings under storage. Should have 1 gig total if you did a 1 gig partition.
Yeah, I wish I had known that an hour ago. My backups on the computer were about a month old. I lost all of my Zenonia 3 progress, and all of my gameboy save files that weren't on my computer (Everything except pokemon emerald and firered). Other than that, I'm okay, but I'm about ready to crawl into a corner and wallow in self-pity reflect on my mistakes.
This is what I thought damn thanks for explaining. Bro...+1
Hi, I tried doing this last night but I couldn't get past the part where you are required to do some unmounting. After trying to execute the command all I got was a line saying "unmount: permission denied" does anyone know how to get around this? Thanks.
Depends on what rom you're using. If you aren't on gingerbread/cm7 it wont work.
I got it to work to.... if you do it bigger then u need to find what. Size block number you Ned to rezise it
What do you mean by this? What if say I wanted to create an ext partition size of 4 gb the recommended max is 1 gb do you know if any problems would occur or just what in general is so bad about it?
Maxyguy666
