i need help removing clockworkmod from my phone cause it installed cm7 just fine then went back to stock then i installed pica-sticks kernel just fine with stock rom the problem is it wont install themes or roms besides unofficial CM7 for optimus s i use v3.2.0.1
this is the error message i get when i try to flash roms or themes:-\
finding update package...
opening update package...
Installing update
Amend scripting (update-script)
is no longer supported
Amend scripting was deprecated by google in 1.5.
It was necesary to remove it when upgrading to ClockworkMod 3.0
Gingerbread based recovery.
Please switch to Edify scripting (update-script and update-binary) to create working update zip packages
Installation aborted
Installing update
