1. username4040's Avatar
    i'm trying to take off icons in a theme i used apk manager and edited the xmls in the xml folder and values folder (strings.xml). still no luck and i'm guessing i have to edit MANIFEST.MF, CERT.SF, CERT.RSA files but i don't know how.
    09-03-2011 06:20 PM
  2. basketthis's Avatar
    I would say post in the roms section but everyone in this section of the forum is so good and aware you will probably get your answer here.
    username4040 likes this.
    09-03-2011 06:39 PM
  3. basketthis's Avatar
    Err... I thought someone would help. Lol. Can you explain a little more what you are trying accomplish?
    09-03-2011 09:10 PM
  4. username4040's Avatar
    lol i'm pretty much trying to remove icons from a theme that's an apk file and the kinda icons that appear in the app drawer not status icons or any other.
    09-03-2011 11:17 PM
  5. basketthis's Avatar
    Icons for what? Icons for apps?
    09-03-2011 11:48 PM
  6. username4040's Avatar
    yes! i'm trying to get rid of them cause the theme doesn't have all the icons for my apps.
    09-04-2011 12:08 AM
  7. basketthis's Avatar
    Lol. I feel the same way about the themes. Have you tried using Titanium Backup to uninstall the apps?
    09-04-2011 12:11 PM
  8. jondevere's Avatar
    might be easier to go to the themer that made it and ask for an icon pack... or a stock icon pack to fix your individual request. Sounds like your goin bout it the hard way... On that note. The hard was rocks! Glad to see you are taking the time to try. GOOD LUCK and seriously I would ask for a stock icon pack.
    I wish I knew what u needed but I am at a loss as well on what u are trying to accomplish
    09-04-2011 02:16 PM
