ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
I flashed this ROM a couple of days ago, but Flash still doesn't work for me. Is there something else I need to change on my phone??
Baseband: LS670mvj_6150
Build number: GingerRom
Android version: 2.3.3
Kernel version: 2.6.35.7-perf lg-electronics@si-rd10-BLD165 #2
SW version: LS670ZVJ
This is a ZVH ROM. You have ZVJ.
will this rom get an update? It seems the problems we had are solved on this new release. Want to know if this rom will get an update to that update
Probably not... the developer of this ROM said on his website that he will no longer be developing for this phone. You can try GingerRom... its a cleaned up stock Sprint ROM on ZVJ.
Status
leehrenterprises
