DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 51
Like Tree23Likes
  1. #26
    jcwxguy's Avatar
    Posts
    Global Posts
    412 Global Posts
    ROM
    DECKS ICS -MASON KERNEL
    Default re: Sprint Optimus guide to Rooting, ROMs, Recoveries & Themes
    Quote Originally Posted by bmwindish7 View Post
    My phone is currently running the Reborn rom and i rooted from ZVD. Can i use the new ROMs or do i have to do anything special?
    The new roms require VH baseband (only exception is thekraven's CM7 which is VD baseband), so in order for them to work, you will have to update to VH baseband (links should be included in the OP post of the rom your looking at)
    enjoying my ics evo4g
    Thanked by:
  2. #27
    ddrfr33k's Avatar
    Posts
    ROM
    HydroROM 1.1.0
    I've lurked on these boards for a while, but finally registered to download files and ask a few questions.
    I'm running a ZVH, all the standard implements of torture. The zergling rush from ZVHauto was successful, so I'm rooted and running clockwork. I flashed and installed gRom, which works beautifully, except for one thing: tethering.
    The wifi tether app that comes with gRom doesn't work. I checked the thread, suggested updating. I tried beta 6(which came with the rom), and beta 9, and both don't work.
    I tried jumping over to opti-rom, and that couldn't help me either.
    Does your mom rom support tethering? Is there an app out there that will work with gRom? I'll go with whatever rom works, I hate the sprint one anyways.
  3. #28
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    I think that Your Mom does include the wireless tethering widget. GIve that a go until HydroROM drops.
  4. #29
    ddrfr33k's Avatar
    Posts
    ROM
    HydroROM 1.1.0
    Default
    Quote Originally Posted by epidenimus View Post
    Thanks for the heads up. I'll shoot you a thanks when I'm not on my phone.
  5. #30
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    If I am running stock GB with the latest version (8.1) of GingerKernel, and I tried to to flash a Your Mom Rom, what would happen? Would I revert back to GingerKernel 6.1 (because YMR now ships with 6.1), would I stay with 8.1, would I brick the phone, ow would something else happen?
  6. #31
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Default
    It would flash your mom in full (assuming you did a full wipe as told to :P) including the 6.1 version of gingerkernal. No issues, just boot backing android after flashing the rom, and give it a few good minutes (go have a beer or smoke a cigarette) then boot into recover and flash gingerKv8.1 and reboot and you are good to go, just remember you perform no wipes to flash the kernal.
    Thanked by:
  7. #32
    ok ive looked and looked and looked and am completely lost, im on a lg optimus s vd rooted with gingerbreak and thats all i have, i want to install a custom rom but all of my trys fail, ive read and read and i seriosly am confused and no mattter what i try it fail any help would be appreciated
  8. #33
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Quote Originally Posted by m3m0ry View Post
    Have you got Xionia custom recovery installed yet? That would be the next step in the path... then do the nandroid backup, then ROM-ing.
    Thanked by:
    m3m0ry
  9. #34
    ive tried installing Xionia custom recovery by copying the files onto the root of the sd card bot extracted both un extracted and either one extracted and one not extracted i cant get it to install when i am in recovery menu
  10. #35
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    You have to use 'flash_image" to install the recovery from a working Android with ADB. Check the directions for Xionia recovery for more info. It's not like some devices, where it just gets installed on reboot.
    Thanked by:
    m3m0ry
  11. #36
    If you are having troubles with installing recoveries, try this automated package:
    [How-To] Install Stock/Custom Recovery - 100% automated
    [How-To] Rooting LS670ZVH
    Installed ZVH by mistake? Use simple update.zip to revert to ZVD / Froyo
    Thanked by:
    m3m0ry
  12. #37
    ok i have great news, i was able to get your mom rom installed, but now my only problem is i cannot get a network, it stays searching for service, any suggestions?
  13. #38
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    and then...
    ...i was able to get your mom rom[requires ZVH radio] installed...
    ...and now...
    now my only problem is i cannot get a network, it stays searching for service...
    any suggestions?
    Yes. You need to install a ROM which is compatible with the radio/baseband that you have installed. You have ZVD and Your Mom is a ZVH ROM, so no dice. Try going with Reborn or sROM. If you want to use Your Mom ROM, you must first follow the guide to switch your radio/baseband to ZVH.
    Thanked by:
    m3m0ry
  14. #39
    thanks for all the help, i finally got it due to all the help only after 8 months of completely confusing myself and a breakdown and plea for help its done, and entirely to you guys, thanx so much now i dont have a crappy phone but a nice one with a great functionality and with TheKraven's CM7 Port installed all is great really thanks guys you helped me out so much
  15. #40
    Rom Name: Tam Hydro ROM
    Developer:
    Summary: Gingerbread 2.3.3 ROM built from Sprint/LG ZVH source. See changelog in the thread for more details.
    If one 'l' is good, then is 'll' even better?
    Apparently not when it leads to a 404 error
    "http://forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/151016-rom-team-hydro-hydrorom-1-0-beta-2-a.htmll"
  16. #41
    Dirtpuddle's Avatar
    Posts
    ROM
    DanteROM
    Are there any ROMs out there compatible with 2.2.2, other than Kraven's? I tried that one and it didn't work, and I confess I may have done something wrong, but I was able to flash Reborn and am using that just fine. It just makes me a little leery since it's no longer supported.
  17. #42
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Quote Originally Posted by Dirtpuddle View Post
    There are several ROMs that are compatible with ZVD, though not all of them are 2.2.2; CM7 is an example. You might also try sROM. If you are confused about the difference, please see my Welcome Guide, found in the stickies.
    I don't know who is circulating the idea that Reborn is no longer supported or recommended. That ROM is about as solid as they come. The only thing that is inconvenient at present is that new users will have to update a bunch of stuff on first run, but most ROMs have you doing that if they are more than a couple months since packaging.
  18. #43
    Dirtpuddle's Avatar
    Posts
    ROM
    DanteROM
    Lol, first page of this thread! But if it's not true, I have no problem keeping it.
    I was thinking 2.2.2 and zvd were the same, but obviously I have more schoolin'
  19. #44
    yeah the ROM list needs to be updated, many ROMs that aren't included and some "discontinued" ROMS are actually still active. I would also sort the ROMs by whether they run off of ZVD or ZVH, and there is even some ICS ROMS in the works.
  20. #45
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Kernels need to be updated
    Sent from futuristic optimus s
  21. Thread Author  Thread Author    #46
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    I'm super busy with a house reno right now. I am not putting links to Alpha or experimental ROMs. Only stable ROMs that are safe for a newb.
  22. #47
    blackops1125's Avatar
    Advisor
    Posts
    Default
    Reborn is not supported by the DEV anymore, meaning he is not taking any bug reports or doing any updates. Reborn 2.2.4 is the last of the reborn line. Now that is not to say it is not widely used, cause it is, I use it myself. I still feel it is one of best roms!
    Supported Roms mean they are being actively being updated by the Dev still.
    Current Device(s): Motorola Droid Razr
    Previous Device(s): LG Optimus S
    Always happy to help out, Just remember to hit that thanks button!
  23. #48
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Quote Originally Posted by blackops1125 View Post
    Supported Roms mean they are being actively being updated by the Dec still.
    Supported and actively developed are two different things in my view. Example: Windows XP; folks are still producing compatible software and guys like me still have to support it, but there is no active development from Micro$oft. (It really does injustice to compare Reborn ROM to MS product, but it's what comes to mind.) Same thing with an Ubuntu LTS: they mostly just maintain the repos for 3 years instead of 1.5.
    A good stable release does not need much developer support.
  24. #49
    Advisor
    Posts
    Default
    I agree with you on that. Again Reborn for example, has a lot of users still that don't mind helping others with problems when they do arise. So in that sense, yes it is still supported.
    aaronrw likes this.
  25. #50
    Default Re: Sprint Optimus guide to Rooting, ROMs, Recoveries & Themes
    I've actually used reborn but the only issue I had was the boot loading which took 5 minutes when normally it should be 1 minute to say the least. Now I'm running S rom and it's smooth and boots easily.
    Sent from my LS670 oh hush
    Thanked by:
