Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Like Tree23Likes
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    Default Sprint Optimus guide to Rooting, ROMs, Recoveries & Themes
    If you are interested in maintaining, and supporting content at Androidcentral.com, please contact me via PM so your work can be added to this thread.
    This thread will server as a master list of recoveries, ROMs, Kernels, and Themes. Have fun flashing!
    Post #1 = Index
    Post #2 = Rooting
    Post #3 = Custom Recovery Images
    Post #4 = ROMs
    Post #5 = Kernels
    Post #6 = Theme
  2. Thread Author  Thread Author    #2
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    Default re: Sprint Optimus guide to Rooting, ROMs, Recoveries & Themes
    Custom Recoveries are what is used to make backup images of your phone, referred to as nand backups, and also used to flash custom ROMs, kernels, themes, and some other tweaks. You must have a custom recovery if you intend on flashing anything. The stock LG recovery will only flash zips made and signed by LG.
    Recovery Name:CWM Recovery
    Developer: Drew Walton
    Summary: This is a Gingerbread recovery image based off the work of Koushik Dutta and Clockwork
    Recovery Name:Xionia Clockwork
    Developer: Zefie
    Summary: RecoveryThis is a recovery image based off the work of Koushik Dutta.
    Recovery Name: ThunderC
    Developer: Drellisdee
    Summary: This is a recovery image based off the work of Amon_Ra.
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    [BOX="Actively Developed ROMs"]ROM, which stands for Read Only Memory, is an OS designed to run on your phone that has been created by a 3rd party, someone other than your carrier or phone manufacturer. These 3rd party developers are typically called chefs and introduce speed, functionality, and features to your phone, above what the carrier does. Develeopment or Alpha ROMs are not shown as they are still experimental[/BOX]
    Rom Name: GingerROM
    Developer:jstntp
    Summary: Gingerbread 2.3.3 ROM built from Sprint/LG ZVJ source. See changelog in the thread for more details.
    Rom Name: Team Hydro ROM
    Developer:
    Rom Name: TheKraven's CM7 Port
    Developer: The Kraven
    Summary: ROM built from Cyanogen source. See changelog in the thread for more details..
    [BOX="Discontinued ROMs"]
    ROMs listed below this warning box have reached end of life. These ROMs are not being actively developed any longer. Bugs may exist, but will not be addressed. Additionally there may be compatibility issues with basebands. These are kept here as a memorial for them.[/BOX]
    Rom Name: Your Mom Rom
    Developer:Jon Devere
    Summary: Gingerbread 2.3.3 ROM built from Sprint/LG ZVH source. See changelog in the thread for more details.
    Rom Name: Opti-ROM
    Developer: Beezy, Drewwalton19216801, Backetthis, Jondevere.
    Rom Name: gROM
    Developer: scrosler
    Rom Name: Reborn ROM
    Developer: Nick7
    Summary: Froyo 2.2 ROM built from LG VD source. See changelog in the thread for more details.
    Rom Name: Drew Waltons CM7
    Developer: Drewwalton19216801
    Rom Name: Unofficial CM7 (Gingerbread)
    Developer: ath3nos
    Rom Name: sROM
    Developer: scrosler
    Summary: ROM built from LG VD source. See changelog in the thread for more details.
    Rom Name:aospCMod
    Developer: aosp (the user, not the project), pfer10
    Rom Name: slide rom
    Developer: asadullah
    Rom Name: Shell ROM
    Developer: Nick7
    Rom Name: CleanROM
    Developer: scrosler
    Rom Name:ThundeROM
    Developer: Beezy, KsmithinNY
    Rom Name:nROM
    Developer: Nick7
    Summary: ROM built from LG VC source. See changelog in the thread for more details.
    Rom Name: LEGO ROM
    Developer: Beezy, Nick7, KsmithinNY
    Summary: A Modular style ROM built from LG VC source. See changelog in the thread for more details.
    Rom Name: CM7 Gingerbread
    Developer: Zefie
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    Kernels are what controls the interaction between the physical hardware (your phone) and the software (a ROM). Please note that not all kernels are compatible with all ROMs. You should see the kernel thread for more specifics.
    Kernel Name:Hydro Kernel
    Developer: drewwalton19216801
    NOTE: Works with GingerROM & ICS
    Kernel Name:iScream kernel
    NOTE: Causes issues with GingerROM
    Kernel Name:GingerKernel
    [BOX="Discontinued "]
    Items listed below this warning box have reached end of life. These are not being actively developed any longer. Bugs may exist, but will not be addressed. Additionally there may be compatibility issues with basebands. These are kept here as a memorial for them.[/BOX]
    Kernel Name:XioniaRedux
    Kernel Name:Xionia kernel
    Developer: Zefie
    Kernel Name:Picasticks simple OC kernel
    Developer: Picasticks
    Here are a couple of threads to help you better control your battery with OC'ed kernels
    Note: These are not kernels. These are for use with OC kernels.
    http://forum.androidcentral.com/lg-o...ery-tweak.html
    http://forum.androidcentral.com/lg-o...-profiles.html
    Thanked by 5:
    sblood86 and PatrickAkridge like this.
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    Themes change the look of a ROM. You should consult with the theme developer regarding compatibility questions. As a rule of thumb, to be compatible the ROM must be deodexed which can be verified by the ROM developer, and also the theme must be made for the source the ROM is built from, which the theme developer can answer.
    Thread:Theme_team themes for LG/Spring Gingerbread Roms: gROM & Opti-ROM
    Developer: jstntp and jondevere
    Thread:Ztag's gROM themes
    Thread:Theme_Team Themes for Froyo based ROMs
    Thread: Phone contact dialers and Swype Metamorphs
    Developer: thekraven
  7. #7
    Jessicalt1's Avatar
    Lover of all things Andi
    Posts
    Global Posts
    418 Global Posts
    ROM
    MikRunny v1.01
    Thanks Mike! You may also want to include the rooting guide links for VD for those who may not have upgraded yet, or have downgraded due to bugs.
    Just another crazy Andi lover
    Have you been helped? "Thank" the person who helped you!! Don't be stingy!
  8. #8
    basketthis's Avatar
    Posts
    Global Posts
    1,456 Global Posts
    ROM
    AOSP!!!
    Quote Originally Posted by Jessicalt1 View Post
    Who are you? Don't you have a new phone? lol. J/k. You are always welcome in the "best-phone-in-the-world" forum, if you choose to visit.
    "Th- th- thinking of a master plan"
  9. #9
    Jessicalt1's Avatar
    Posts
    Global Posts
    418 Global Posts
    ROM
    MikRunny v1.01
    Quote Originally Posted by basketthis View Post
    hahaha, I do but this forum is way more active than the Nexus one is! But in all seriousness, I sold my phone to a co-worker and she's letting me play around with it still. lol
  10. #10
    basketthis's Avatar
    Posts
    Global Posts
    1,456 Global Posts
    ROM
    AOSP!!!
    Awesome! It's great having you around. I was just "giving you a hard time". Looks like you will have more playing around to do yet!
  11. #11
    could you link stock roms if you get the chance. I am looking like crazy to find one that isn't just a broken link. (i was hoping you would know better than I do on where to look) thank you so much!! have a great day (yes, I am soo bricked. I am hoping that i can fix this..)
  12. #12
    fwankbewwy's Avatar
    Posts
    ROM
    MIUI GB
    This seems like the most appropriate place to ask some things..
    Well I realize some OTA updates messed people up; is it possible that I make a nandroid backup of before I update, and one after, then just restore back and forth to flash different roms?
    Also I'm running cm7 and I made my own boot animation (just took frames from a few gifs, really ) but is there any way I could change the red LG splash screen to something else, specifically through adb?
    I'm using kraven's cm7 port and bob's kernel.
    Also what would my baseband version be on the cm7 port because it just says unknown so when I flash anything else I usually just restore to rooted stock .-.
    if this wasn't a good place for this, my apologies.
  13. #13
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Quote Originally Posted by fwankbewwy View Post
    No you cannot nand back between zvd and zvh as the custom recovery does not flash the radio. If you are running kravensROM then you are on zvd.
    Thanked by:
  14. #14
    I might claim noob of the year award, but I am just hoping for a general update.
    I was all set to install a cr and then get working on a rom.
    I used the gingerbreak utility in July, and then shortly after my life went berzerk on me. I haven't really had time to read up to a a level of comfort. I have a really rudimentary concept of what I need to do, but I'm hoping for a, "here is the cr I like, the rom I like, and the 1, 2, 3 etc of what you need to do."
    I'm rooted, but that's as far as I've gotten.
  15. #15
    i tried doing a custom rom and now my phone will not boot all the way up what do i do
  16. #16
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    Quote Originally Posted by djdj17 View Post
    Where does it stop? What recovery did you install? Can you get to the recovery using the keys on boot?
    Thanked by:
    djdj17
  17. #17
    it stops at the the loading screen after the cyanogenmod screen. i tried going into recovery mod but it will not work it gets stuck on a black screen
  18. #18
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    What recovery did you install? Which ROM did you attempt to install? Please tell me that you did not use ROM Manager.
  19. #19
    in the rom manager it was the first one it there were only there i backed up before i tried this like it sad but i think i some how missed some steps
  20. #20
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Yes, the step you missed was reading before doing. ROM Manager is not supported and is known to brick this device. Please refer to this stickied thread for a possible solution. Good luck!
    Thanked by:
    djdj17
  21. #21
    thanks ill try what i can
  22. #22
    Tyler555's Avatar
    Posts
    ROM
    CM7.2 and now CAI CM9
    my phone comes from sprint defaulted to the svd can i still use the roms seen here? and why arent they still developing them i just got my phone a month ago and have svd installed ?
  23. Thread Author  Thread Author    #23
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    If you have ZVD, you can root,install xionia recovery and install either ReBorn or the Kravens CM7. If you make the jump to ZVH, there is Your Mom.
  24. #24
    My phone is currently running the Reborn rom and i rooted from ZVD. Can i use the new ROMs or do i have to do anything special?
  25. #25
    Quote Originally Posted by bmwindish7 View Post
    I'm not sure what you mean by the "new roms", however, I have zvd as well and xionia clockwork recover with TheKraven's CM7 Port rom
    Works great, I'm happy with it. It is my first time root and flashing rom, so I haven't tried any other roms yet. Lots of features and mod ability built in. Takes at least a day of exploring to see the many features.
