Results 1 to 9 of 9
    Default need HELP testing
    I put together a new ZVH rooting method that avoids the blank screen with new LCDs and no longer uses rage. This should significantly simplify the process.
    In theory it should work but unfortunately I no longer have an Optimus to test with so all I can do is rehearse it in my head.
    Would appreciate if some folks could test out the new ZVH rooting instructions. Please re-download zvhrec.zip and zvhroot.zip even if you already have them.
    As always make a nandroid backup before flashing anything.
    Please revert to ZVD so you can test the whole procedure. You no longer need KP500 to revert to ZVD. Just put back stock recovery and run the ZVD update.zip from here.
    Thank you for your assistance.
    [How-To] Rooting LS670ZVH
    Installed ZVH by mistake? Use simple update.zip to revert to ZVD / Froyo
    Thanked by:
  2. Thread Author  Thread Author    #2
    Default Re: need HELP testing
    Anybody? If nobody is interested I'll just take it down. Rather not have people try it by accident before it is tested.
  3. #3
    jcwxguy's Avatar
    Posts
    Global Posts
    412 Global Posts
    ROM
    DECKS ICS -MASON KERNEL
    Ill try it when i get home (i get off work in 4 1/2 hrs)
    enjoying my ics evo4g
    Ok, great, thanks much.
  5. #5
    jcwxguy's Avatar
    Posts
    Global Posts
    412 Global Posts
    ROM
    working on it now, had to have dinner first :P plus person replacing after me was late
    Thanks. I'll be back in about 2hrs.
  7. #7
    jcwxguy's Avatar
    Posts
    Global Posts
    412 Global Posts
    ROM
    seemed to work for me (adb reboot recovery doesnt always work, took me a few times)
  8. Thread Author  Thread Author    #8
    Excellent, thanks for the help.
    Quote Originally Posted by jcwxguy View Post
    The one in Step #6 right? or the one in Step #3?
    I noticed that about the one Step #6, sometimes it works and sometimes it doesn't so I added note about it a while back to go to recovery using the 3 buttons if adb reboot recovery didn't work.
