Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By sarwaria23
    sarwaria23's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to Root Optimus S 2.3.3 HELP
    Ok guys i am new to all this rooting stuff and i have an LG Optimus S 2.3.3 LS670ZVH i read some other threads on how to root it but i dont think they are working for me or im doing them wrong. So if anyone can please tell me how to root my phone step by step with download links and works for 2.3.3 i would greatly appreciate it.
    janasher1 likes this.
  2. #2
    sfhub's Avatar
    Posts
    Global Posts
    2,486 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to Root Optimus S 2.3.3 HELP
    Did you try the automated root in the sticky?
    http://forums.androidcentral.com/lg-...pe-needed.html
  3. #3
    droid_filter's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by sfhub View Post
    Follow the link that sfhub provided to the sticky thread. There are two different methods to choose from in that thread. Either one will root your phone on 2.3.3. I followed the directions exactly and was rooted within minutes of starting. Absolutely could not be easier. If you encounter any issues just post back in here (or preferrably in the appropriate thread for the method you decide to go with) and sfhub, drewwalton, or one of the other awesome folks here at AC will be happy to help. sfhub answered all of the questions i had quickly and in great detail. Trust me, youre in good hands here.
  4. #4
    PatrickAkridge's Avatar
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold as Ice - CM9 kraven
    Default
    Quote Originally Posted by sarwaria23 View Post
    I've got the downgrade to 2.2.2 (you can go back to 2.3.7 with kraven's cm7. Lemme know by PM if you want the downgrade.... but yeah....u gotta downgrade to 2.2.2 first.
  5. #5
    blackops1125's Avatar
    Advisor
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by PatrickAkridge View Post
    You do not need to down grade to root ZVH. Just go to the roms,rooting & hacks thread and you can see all the ways to root your phone.
    sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
    Always happy to help, hit that thanks button if I did
  6. #6
    BriannaNovell's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How do you downgrade? Back to 2.2
  7. #7
    rshewmaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just received the second round of new updates for Sprint's LG Optimus S (2.3.3). Now Gingersnap will no longer work on it. Any suggestions?
  8. #8
    hlxanthus's Avatar
    Posts
    Global Posts
    1,793 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    RasbeanJelly/DanteRom v4
    Default
    Quote Originally Posted by rshewmaker View Post
    At this point there is no known root. Heck the devs haven't even gotten ahold of it yet. If root is important roll back to zvd or zvh baseband.
  9. #9
    rshewmaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Took half a day but reverting back factory settings and then following Deez2000 instructions ([How-To] Automated Rooting of LS670ZVD/ZVH/ZVJ) I was able to have a rooted 2.3.3 version. It's glitchy on somethings, but was nice to do before throwing this phone away when contract is up.
  10. #10
    ikeywatson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    jellybeanLIH leak
    donate or sell it ,to one of the devs
  11. #11
    rshewmaker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are just too many minor annoyances that I don't know if I, the update, or the hack is causing on the optimus.
  12. #12
    jgray4lyfe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I only have a Macbook and all of the threads are for Windows so can anyone help me on how to root lg optimus s 2.3.3 with a Macbook?
  13. #13
    sfhub's Avatar
    Posts
    Global Posts
    2,486 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Follow the instructions here:
    [How-To] Manual Rooting of LS670ZVH/ZVJ (+ links to root ZVD/ZV9)
    For steps that say install.bat, please replace with
    adb push copy2sd /sdcard/
    You'll need adb installed. Please understand that they weren't written specifically for Mac (so the instructions may not be perfect) but it should be close enough that you can figure out what to do.
  14. #14
    jonny5449's Avatar
    AC Citizen
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cm7/Cm9/Cm10
    Default
    Use sons of korhal
    Cm9
    787 MHz
    Hydro kernel
    Amphetamines
  15. #15
    Joshua Washburn1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank u very much
