Results 1 to 24 of 24
- 01-02-2012, 10:48 PM
Thread Author #1
Bricked it myself...Backlit blank screen need help. PLZ!
Orginally had 2.3.3 LS670VZH SW. I tried downgrading, so I used LS670ZV9 and now a blank screen. I then flash the LS670ZV8 and after restarting the phone. The screen is backlit and you
can hear the phone sound the start up but remains blank. I have read many threads and know
theres a lcd hardware issue when downgrading so would it work if I could find the LS670VZH SW?
I cant find it in .tot form. I find recovery zip files but I can see the screen so I can do anything. - 01-02-2012, 11:23 PM #2
Can you viewthe screen with screencast? If so perhaps you can simply boot to recovery and flash the zvh update.zip
- 01-03-2012, 12:44 AM #3
Re: Bricked it myself...Backlit blank screen need help. PLZ!
The ZVH update.zip is in the reference section of the ZVH rooting thread:
Section D8 (2nd post)
http://forums.androidcentral.com/lg-...rt-needed.html - 01-03-2012, 02:56 AM
Thread Author #4
- 01-03-2012, 03:11 AM #5
You only need root to control with screencast if I remember correctly. You can still use it without root just to view the screen. You didn't brick the phone at all. It's just you are using the newer LCD with old drivers. So just use screencast so you can see what you are doing.
- 01-03-2012, 03:18 AM
Thread Author #6
- 01-03-2012, 03:26 AM #7
- 01-03-2012, 03:33 AM
Thread Author #8
ok thanks for the replies. so with screencast, im should see my cell screen and do the update.zip and should get it back running or am I going to be jumping alot of hurdles. Thanks I post up later, hope to hear from you later.
- 01-03-2012, 03:40 AM #9
- 01-03-2012, 04:17 AM
Thread Author #10
- 01-03-2012, 08:03 AM #11
Boot in to android, start screencast, then you can boot into recovery to do your update.zip
- 01-03-2012, 07:55 PM
Thread Author #12
ok i did the "home & volume down & power and the screen boots up blank
so I assume its in recovery mode. I start then ran adb shell and get
"C:\Program Files\Android\android-sdk\platform-tools>adb shell
- exec '/system/bin/sh' failed: No such file or directory (2) -"
Im using a youtube video to help me out in this process.
[YT]http://www.youtube.com/watch?v=71BbGd0LTRI[/YT] - 01-05-2012, 02:12 AM
Thread Author #13
- 01-05-2012, 05:11 PM #14
- 01-05-2012, 06:00 PM #15
- 01-05-2012, 06:24 PM #16
- 01-05-2012, 06:51 PM #17
yeah i am going to give it a try... also my evo pops up when I use the "abd devices" command but my optimus never does..and its recognized by my comp and it pops up in device manager as LG Android USB Device..is this because USB debugging isnt enabled..I cant enable it cuz i cant see my screen??
- 01-05-2012, 08:24 PM #18
Yeah thats a problem. I think with a custom recovery debugging will be enabled by default... But I assume neither of you are rooted so you just have stock recovery. It's probably best just to force flash to ZVD. There are a few guides around on force flashing. I haven't done it in a while but its pretty easy from what I can remember.
- 01-05-2012, 10:20 PM #19
THE STROKES... I fixed mine and hopefully what worked for me will work for you too..MAJOR THANKS TO hlxanthus and sfhub
I downloaded the ZVD update from this thread [How-To] Simplified UNROOT and return to STOCK and started at step 3 (it even has the steps for doing it blind) and I got my screen back only problem now is I still have a blank screen for recovery and even bootanimations but if i let the phone fully boot up and use the power button to turn just the screen off then press it again the screen turns back on and I CAN ACTUALLY SEE IT!!!
LMK if this works for you..
I only wish I didnt assume that I didnt have stock recovery still cuz I wouldve tried that alot sooner..
Deadset thanks for help too but luckily I didnt have to force flash the ZVD firmware..Last edited by eliment; 01-05-2012 at 10:27 PM.
- 01-05-2012, 11:37 PM #20
I think it's because the update you used didn't update the stock recovery. So the stock recovery still has the old drivers. I am not 100% sure though. I haven't rooted this phone in a long time now so its hard to remember the common problems people were facing. If you are planning on rooting the newest Xionia has both drivers and won't give you the blank screen.
- 01-05-2012, 11:46 PM #21
- 04-20-2012, 05:57 PM #22
Hey Gang,
Same deal here...downgraded in order to get wifi tether working..what ever...now have blank boot ani..running on optimus s with CM7...no boot...boot shows in screen cast but not on screen...anyway to get that back..can get my hands on another stock optimus s, but I don't know how to pull the rom or even if that would work...any advise would be greatly appreciated.
thanks! - 04-20-2012, 06:39 PM #23
Use screencast to install the ZVD update.zip
- 04-20-2012, 09:10 PM #24
thanks sfhub,
I did as you said and installed the ZVD update.zip...got stuck in a boot loop, did a wipe data/factory reset came back to life...did a optiauto-sfx to reroot...still no boot ani (except in screencast)....I know it's a small thing and I am grateful my phone still works...but I really like my boot ani...any chance of getting that back...I read somewhere (may have been this thread) that the Optimus S has a different kind of video driver..any chance of redoing that driver? Anyone?
thanks in advance!
Reply
