- 01-21-2012, 01:40 PM
Thread Author #1
need help rooting
ok, I thought I was a smart fella, until I decided I wanted to root my android, all the reading, all the downloads, the recoveries, the roms, the loaders......OH and dont brick your phone, UHHGGGG, can someone please help out with step by step instructions I need to root my LG Optimus S (LS670ZVH) android 2.3.3 and the files I need to download.
I also have LauncherPro downloaded and operating, also have z4root on my phone, but it appears that I did not use it correctly, if you want to do it here, its ok, if we need to go off list, thats ok also
Im just getting a headache from the pages and pages of info on here, it should not be this hard.
help please,
Jason - 01-21-2012, 02:01 PM #2
Re: need help rooting
Have you looked at the sticky posts?
http://forums.androidcentral.com/lg-...rt-needed.html - 01-21-2012, 02:09 PM
Thread Author #3
- 01-21-2012, 03:05 PM #4
A marine who thought he was a smart fella... kinda reminds me of this:
Seriously though, I don't blame you in this instance. Hell, getting the right drivers installed on Windoze is a project in and of itself and no one should have to use Windoze to manipulate Android. Doesn't just running rageagaintthecage work if you have the right recovery installed?Waldorf: I have a good mind to go home.
Statler: If you had a good mind, you wouldn't be here in the first place. - 01-21-2012, 03:11 PM #5
- 01-21-2012, 04:06 PM #6
- 01-21-2012, 04:18 PM
Thread Author #7
- 01-21-2012, 05:10 PM #8
- 01-21-2012, 05:13 PM #9
- 01-21-2012, 05:18 PM
Thread Author #10
- 01-21-2012, 05:35 PM #11
- 01-21-2012, 05:55 PM
Thread Author #12
- 01-21-2012, 06:03 PM #13
Get your optimus rooted and then check back. It won't recognize the custom recovery if it's not rooted. FYI the recovery lets you install zip files,apk files, etc. Which you will see are essential to the whole process. Also perform data wipes and other cool things.
- 01-21-2012, 06:09 PM #14
- 01-21-2012, 06:18 PM #15
I really don't think you are reading the correct portion of the sticky thread I gave you. You don't need to deal with any of what you are asking. It takes care of it for you.
As to "recovery", it is a program separate from your normal phone software which allows you to install updates and make repairs.
A "custom recovery" adds the ability to install any software you'd like, even if not signed by the manufacturer (ie custom ROMs) and also allows you to make complete image backups of your system.
z4root doesn't work on the latest software so don't use it.
You don't need to use terminal emulator for the thread I gave you above. - 01-21-2012, 06:22 PM #16
IMO it is less work if you just use the Automated Root sticky.
It installs root and custom recovery in one shot, rather than 2 separate steps.
All you do is double-click and press A - 01-21-2012, 06:46 PM
Thread Author #17
- 01-21-2012, 06:51 PM #18
- 01-21-2012, 06:58 PM
Thread Author #19
- 01-21-2012, 07:03 PM #20
No it was painless and quick for me. Do you have all the LG usb drivers installed on your pc? That may be the culprit.If you're not 100% sure go to LG's website for the download and get it! But really after that I'm lost man.
Sometimes I have to connect my phone to my laptop, then "safely remove hardware " and then re mount the phone. Might help.....Last edited by aaronrw; 01-21-2012 at 07:45 PM.
- 01-22-2012, 12:32 PM
Thread Author #21
- 01-22-2012, 02:45 PM #22
- 01-22-2012, 03:04 PM
Thread Author #23
- 01-22-2012, 03:12 PM #24Thanked by:
- 01-22-2012, 04:18 PM
Thread Author #25
Reply
