Invincible Madness
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
Use root exploter and mount system as R/w on the top right.
Copy/replace the gallery.apk in System/app I guess, go back and change it to R/O.
do we need to uninstall the old one?
EDIT: Adding it is easier said than done. ADB won't connect, Astro says that directory is read only, ES says copy failed, and the built in browser, once I select copy, it takes me to the copy to dialogue, which only lets me copy to the sd card.
