Kyleluvsandroid
Active member
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
It drives me up the wall that adobe flash won't run on here. Initially the only reason I went to this rom was for the time warner app to play live tv you have to have ics. So I flashed this and found out you can't watch with a rooted phone. Then I found a version of the app that was moded and will run. Well it will let me go in now, I can hear audio but after a minute it says it can't play this stream please try another or try again later. I am assumeing it is from flash not working. Possibly could the moded app. Will anyone ever get flash working on here??????????? Also is there a way to unroot cm9 so the app can't even tell it was ever rooted? Then I just flash backup to be rooted again.
