Page 13 of 179 FirstFirst ... 10111213141516 ... LastLast
Results 301 to 325 of 4469
Like Tree996Likes
  1. Thread Author  Thread Author    #301
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
    Here's a new boot.img if you want to test. No wifi yet. But it has adb and usb mass storage working. So uninstall the usbstorage.apk from /system/app via root explorer or tb. Just wipe cache and flash.
    Test data on this file.
    To go back to alpha4 boot.img. Swap out the boot.img from the rom zip, and place inside the zip below and flash without signature.
    Attached Files Attached Files
  2. #302
    rukin5197's Avatar
    Posts
    ROM
    MIUIgb | AOKP
    Default
    Hey, if I want to cherry-pick your commits for camera and USB fixes, will I need to change anything to make it usable for our lg optimus v's?
    Awesome job, btw
    Sent from my Amazon Kindle Fire using Tapatalk
  3. #303
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    Default Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
    Quote Originally Posted by eletendre84 View Post
    Anyone else having massive data/wifi issues on alpha 4??
    Just you and me I think. Just back from a long day of work and then meetings. I have a couple ideas to try. Fingers crossed.
    Quote Originally Posted by PatrickAkridge View Post
    Sorry... the "PATCH" is the fix itself. I am sorry. I call it a patch because it has to be reapplied each reboot; a FIX is a fix that stays applied in my book...
    I am by no means trying to be a smart elic...
    Sorry for the inconvience.
    No worry, thanks. Probably my having applied too many patches to so many different systems through the years. I took it too literal, not your fault, it is my understanding. Got it clear now.
    I cleared up my instructions for you...
    Try applying the data fix on post 129 i think it is..
    TheKraven generously posted the link to that in the OP
    I have done that at least half dozen times. Something it just different with my phone is all I can think. The joys of testing, especially alpha.
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  4. #304
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by Pkt_Lnt View Post
    Well mines not great either...wifi says it's sending and receiving but it wont' load anything. 3G will work slowly, but won't load everything...my FB app won't load but I can slowly load it through the browser. I am just chillin' because I'm sure it will be fixed in the near future, Kraven is doing a great job!...heck even if just wifi was great I would be happy
  5. Thread Author  Thread Author    #305
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Quote Originally Posted by gannon5197 View Post
    Awesome job, btw
    I'm just setting up the camera stuff, so it probably won't build yet. The usb fixes are all in the same files as wifi fixes. I wasn't going to push till i got wifi fixed.
  6. #306
    fenderman's Avatar
    Posts
    ROM
    pure kraven cm7 cm9!!!!
    Said it right there data and wifi work, just not great! Some work by the man kraven and ics will be working great for our opt.s!!! Dam fun testing alpha builds lol also noticed in the browser an issue with the screen going wack with colors and lines on alpha 4
  7. #307
    rukin1's Avatar
    Banned
    Posts
    Any pics? lol
  8. #308
    fenderman's Avatar
    Posts
    ROM
    Another issue I've been having more recently as in about the last twelve hours running alpha 4 is my SD card unmounting happening most when coming out of sleep. Funny because I had a Samsung behold 2 that came out of the box stock firmware Android 1.5 and 1.6 that had the unmounting issue lol shame on Samsung
  9. #309
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    My SD card is unmounting like every 3 hours any fix???
    Cold As Ice!!!!!!!!!!
  10. #310
    rukin1's Avatar
    Banned
    Posts
    Any pics or what.. lol
  11. #311
    PatrickAkridge's Avatar
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Cold as Ice - CM9 kraven
    Did I miss anything on the last 5 pages of the forum? I was playing Piano LOL... I love music... Anyways...
    I should have made it clear that it was a fix..
    Try clearing data and dalvik cache?
    Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
  12. #312
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Quote Originally Posted by thekraven View Post
    Will try to flash here shortly...
    I really wanted adb.. As I have been saying in the forums,
    I plug my phone into the AC wall plug... and it DOESN'T say charging... And on reboot, battery %'ge changes..
    Your getting closer, kraven!
    THANKS! Any suggestions?
  13. #313
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Quote Originally Posted by towelie55 View Post
    my data aint working :/ shizzle
    Refer to the OP.
  14. #314
    @Thekraven , I know I cant do too much to help out but I can give you free storage and ftp on my website and for you to host the cm 7 and cm 9 files it would be something like this if you like
    example of link goofwear.com/android/thekrave/cm9
    I can even set it up with an auto index script to look like this
    that way you don't have to you those upload sites , please let me know if you are interested
  15. #315
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    This is coming along nicely! I look forward to trying it out after another fix or two. My device needs daily driver level, as I use it for work.
    @PatrickAkridge: Your signature block is a horrible, horrible pun. I want to eat that little Android sammich so the words disappear like the wrapper! Nom, nom, nom, nom, nom!
    Thanked by:
    PatrickAkridge likes this.
  16. #316
    I was expecting extreme lagging but this rom may even be smoother than CM7.2 some of the animations are sketchy but it's an alpha rom so yeah... but everyhting comes up fast and smooth even when i'm switching between things quickly
  17. #317
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Gallery is working for me using alpha 4
  18. #318
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Quote Originally Posted by jonny5449 View Post
    As it is in mine...
    To all of you, including CM7 people...
    When you take a screenshot or photo, CM7 OR CM9 might not pull up the photo or screenshot or image in the Gallery. Download the app called "SD Sync" in the market. It helps.
  19. #319
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    As it is in mine...
    I didn't download an app just worked after reflash
  20. Thread Author  Thread Author    #320
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Test this boot.img. Wifi should be working again but with the adb and usb fixes. Airplane mode still not toggling correctly. Testing out a differernt wireless driver.
    43 has the same same dhcpcd config as previous betas
    44 has a slightly different dhcpcd config
    Thanked by:
  21. #321
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Does this flash like a regular zip
  22. Thread Author  Thread Author    #322
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Yeah, just wipe cache and flash in recovery. Make sure wifi is working before you flash it.
  23. #323
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Thanks it worked
  24. #324
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    I will be flashing soon... I just need to send it over to the phone via ADB.
  25. #325
    eletendre84's Avatar
    #sarcasm
    Posts
    ROM
    kraven CM9 / LeWa Alpha 3
    Is there an alpha5 build coming soon kraven?
