Page 130 of 179 FirstFirst ... 127128129130131132133 ... LastLast
Results 3,226 to 3,250 of 4472
Like Tree1000Likes
  1. #3226
    nichobrooks's Avatar
    Posts
    ROM
    CM7 MiRaGe
    Default Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
    Quote Originally Posted by nichobrooks View Post
    Reporting:
    - Audio fix for alpha16 speakerphone (low volume issue) during calls works like a charm
    - MMS works on alpha16
    - Dedicated ringtones does not work (dedicated = specific contact - specific ringtone (different from default ringtone))
    I'm about to flash alpha16c, I'll report back in a few minutes.
    Thanks for keeping our little phones alive and up-to-date
    BTW: my device is a VM670 with Cannibal 1.2 recovery.
    I flashed alpha16c with no problems, I did the following on cannibal 1.2:
    Main screen
    -Wipe data/factory reset
    -Wipe cache partition
    -Wipe system, data, cache
    Mounts and storage
    -format boot, system, data, cache, sd-ext
    Advanced
    -Wipe Dalvik Cache
    Then I used Leslie Ann's prep for new rom wiper (wipes 3 times)
    Now flash alpha16c, when done, flash gapps and reboot system now.
    If you are on Virgin Mobile flash the fix after the first boot.
    Hope it helps.
    BTW : Alpha16c: loud speaker working like a charm, everything else works as well (BT, WiFi, etc)
    Governor interactiveX min:480 max:600 (if I go lower than 480 I get reboots)
  2. #3227
    glitchsta's Avatar
    Posts
    ROM
    CM9 Alpha5 ZVD
    my phone backs up as 1980 also...ever since this cannibal recovery...where is the link for the 3x wiper...
  3. #3228
    Posts
    ROM
    CM7 MiRaGe
    Quote Originally Posted by glitchsta View Post
    Here you go bro
    Easy wipe zips
  4. #3229
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    Quote Originally Posted by eletendre84 View Post
    right, im just saying, if you read the errors posted above, the system is trying to set the volume on boot on a device that is showing a date of 06-02-1980 or whatever. if its happening on more then one device, its not a localized issue
    Ah HA! Good catch! I missed that in the logcat here and the one I had on my screen. Evidence, good stuff. I have tried three times to duplicate that in COT with no success. I always have my phone plugged in when doing operations in recovery.
    edit posted about this in COT to see if Drew has ideas
    @tdm got the fix too to test on quattrimus, has some problems, but he has ideas on mods to make it work.
    http://forums.androidcentral.com/opt...ml#post1894150
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  5. #3230
    glitchsta's Avatar
    Posts
    ROM
    CM9 Alpha5 ZVD
    if you watch the logcat when it first boots its all messed up cant load zipalign or anything...I will upload it if u anyone wants to decode it for me =p....just tons of compiling errors it seems
    Thanked by 2:
    Pkt_Lnt likes this.
  6. #3231
    wormy987123's Avatar
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Main screen
    Mounts and storage
    Advanced
    -Wipe Dalvik Cache
    Hope it helps.
    im going to try your way I just downloaded the wiper linked in the thread to give it a try so heres to it working
  7. #3232
    Quote Originally Posted by Pkt_Lnt View Post
    Thanks for that, I just did the same thing, got the same errors.
    It is the new audio fix it seems. I get the same hang forever at boot animation. There must be some of us with phones with different hardware that are getting this. Looks like it is back in the hands of the devs, lgics team, or thekraven. Meanwhile, alpha 15f runs for me, or play with the quattrimus nightly.
    Thekraven said you do not need the audio fix on 16c.
  8. #3233
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Quote Originally Posted by gwz85 View Post
    because it is included in the build of 16c. Still appears to be the problem.
    Attached Thumbnails Attached Thumbnails [ROM]COLD AS ICE-CM9+Paranoid Android  LS670 11/20 ZVD basesband Alpha19-rom-cold-ice-cm9-sprint-ls670-6-26-zvd-basesband-alpha16-android-forums-androidcentral..png
    Galaxy Nexus GSM
    Kindle Fire
  9. #3234
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    It must be the audio files here is a logcat showing audio stuff failing
    here is a dmesg from adb
    Thanked by 2:
  10. Thread Author  Thread Author    #3235
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Looks like it's missing the zipalign tool in the /system/xbin/ directory. You probably can delete the 95zipalign script in system/etc/init.d/ and it will fix that error.
    Not too sure why the audio files work for some and not others. tdm said it was probably a kernel header issue and i'll look into it.
    Thanked by 3:
    Va1ha11a, wormy987123 and Pkt_Lnt like this.
  11. #3236
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by thekraven View Post
    can we take the zip align tool from a previous alpha and put it in /system/xbin to see if it works?
  12. Thread Author  Thread Author    #3237
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Yeah, just flash this or push the zipalign to /system/xbin/
    Attached Files Attached Files
    Thanked by:
    Va1ha11a likes this.
  13. #3238
    Conker1r's Avatar
    Posts
    ROM
    TheKravensCM9 Cold As Ice
    Alpha16c works great for me.
    Formated boot, system, data, cache, dalvik cache | in that order.
    My phone specs. in case others are not the same.
    I have had the ls670 since launch day. (not the purple one)
    *LGE THUNDERC - LG LS670*
    *SYSTEM*
    Model: LG LS670
    Manufacturer: LGE
    Device: Thunderc
    Product: COLD.AS.ICE
    Brand: Sprint
    Firmware: 4.0.4
    API Level: 15
    Processor: ARMv6-compatible processor rev 5 (v6l)
    System RAM: 431 MB
    *DISPLAY*
    Logical Density: 1.0
    Font Scaling Factor: 1.0
    Pixels Per Inch X: 160.0
    Pixels Per Inch Y: 160.0
    *GRAPHICS*
    Renderer: Adreno (TM) 200
    Version: OpenGL ES-CM 1.1
    Vendor: Qualcomm
    Max Texture Size: 4096x4096
    Max Texture Units: 2
    more detailed specs here.
    EDIT: I also flashed Amphetamines-01, which made the phone silkier than it already was.
  14. #3239
    Posts
    ROM
    CM7 MiRaGe
    Default
    I forgot to mention that specific contact ringtones don't work
  15. #3240
    Is this a possible tether fix?
  16. #3241
    rebel69ization's Avatar
    Posts
    ROM
    Cold As Ice /Hydro ICS
    Default
    Full wipe, system, data, cache, and dalvik cache, Leslie Ann's prep for new rom zip. 16c online, flashed with drews touch 5.0.2.7
  17. #3242
    Partof300's Avatar
    Posts
    ROM
    COLD AS ICE/HydroKernel
    Got this working as well and it is awesome!
    First thing I tested was the speak phone, I no longer have to take my motorcycle helmet off before riding!
    Thanks kraven, this is the best. Keep up the good work!
  18. Thread Author  Thread Author    #3243
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Alpha 16D is up with speakerphone fixes from tdm.... crossing fingers.
  19. #3244
    Sdude1200's Avatar
    Posts
    ROM
    Stock.... for now
    Default
    Downloading and flashing now. I'll report back with results asap
    Sent from my Frozen Optimus S
  20. #3245
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Default
    downloading now will report back as soon as I flash it. won't be able to provide a logcat till later today.
    Sent from my LG-LS670 using Tapatalk 2
  21. #3246
    Buddlespit's Avatar
    Wannabe kewl
    Posts
    Global Posts
    675 Global Posts
    ROM
    Wicked Sensations TW-JB
    Both 16c and 16d won't boot. Stays on Cid. I'm assuming it's the same issue everyone else is having.
    "I drank what!?!?!" ~Socrates
    "Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
    New users, click here!!
    Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0
  22. #3247
    pmoneyprix's Avatar
    Posts
    ROM
    opti aokp, viper stock
    I also am hung on boot. All of the alpha 16's hang on boot for me. I'm gonna try with the triple wipe and report back. Edit. Even after the wipe it still hangs on boot. I'm running one of the first optimus's, if that makes a difference.
  23. #3248
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Default
    I also hung on boot, cant say how old my optimus s is I got it refurbished. if I wasent working I would get a logcat.
  24. Thread Author  Thread Author    #3249
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    aww shoot and it flashed fine for me. Mine is an original batch one.
  25. #3250
    tovinhudson's Avatar
    Posts
    ROM
    CM9 | CAI a16d
    I was able to clean flash 11d with COT and the zipalign fix.
    It stayed on the animated CM9 boot screen for slightly longer than normal. I'd say it took about five minutes.
    Bought new November 2010.
    So far, so good! Nice to have the speaker phone back. Thanks.
