Page 146 of 179 FirstFirst ... 143144145146147148149 ... LastLast
Results 3,626 to 3,650 of 4472
Like Tree1000Likes
  1. #3626
    Default Re: [ROM]COLD AS ICE-CM9 Sprint LS670 9/1 ZVD basesband Alpha17
    1X Data isn't working. Says connected but no data. The signal bar remains grey and doesn't turn to blue to indicate a connection.
    Known Problem?
  2. #3627
    Default
    Quote Originally Posted by pclov3r View Post
    Known Problem?
    What build using.?
    Sent from my GT-P3113 using Xparent Cyan Tapatalk 2
  3. #3628
    Quote Originally Posted by Alnn View Post
    What build using.?
    Alpha 17c latest.
    Also, the phone keeps saying Android is upgrading and optimizing 1 application on reboot.
  4. #3629
    Got 17c to boot. Runs great! Thanks
  5. #3630
    sonicbluemustang's Avatar
    Posts
    ROM
    Cold As Ice
    LOL when did I join Virgin Mobil?
  6. #3631
    Default
    17c working for me... Try flashing, it again
  7. #3632
    Quote Originally Posted by sonicbluemustang View Post
    Did you flash the VM patch?
  8. #3633
    Posts
    ROM
    Cold As Ice
    Quote Originally Posted by PrimeOne1 View Post
    yup guess i did.
  9. #3634
    Has anyone managed to get the Visual Voicemail to work?
  10. Thread Author  Thread Author    #3635
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    You could try this VVM for ics.
    Thanked by:
  11. #3636
    Still no 1xRTT data for some reason. Says Mobile Network State connected but the 1X bars on the top left hand corner are grey.
    Any idea what is wrong? I've only been able to get 1X data to work on the stock rom.
    My phone IS flashed to another provider.
    Does this log down below help at all?
    Code:
    D/ConnectivityService(  575): ConnectivityChange for mobile: CONNECTED/CONNECTED
    E/ConnectivityService(  575): no dns provided for mobile - using 8.8.8.8
    E/ConnectivityService(  575): exception setting default dns interface: java.lang.IllegalStateException: Error communicating with native daemon to set dns for interface
    D/NetworkPolicy(  575): applying policy NetworkPolicy[NetworkTemplate: matchRule=MOBILE_ALL, subscriberId=valid]: cycleDay=7, warningBytes=5242880, limitBytes=10485760, lastSnooze=-1 to ifaces [null]
    D/ConnectivityService(  575): NetTransition Wakelock for WifiStateMachine released by timeout
    D/Tethering(  575): MasterInitialState.processMessage what=3
    D/PicasaSyncManager( 1659): active network: NetworkInfo: type: mobile[CDMA - 1xRTT], state: CONNECTED/CONNECTED, reason: dataEnabled, extra: , roaming: false, failover: true, isAvailable: true
    D/PicasaSyncManager( 1659): background data: true
    D/TelephonyProvider(  759): Preferred APN: -1
  12. #3637
    Quote Originally Posted by thekraven View Post
    Kraven, I tried them and I get the error message of not sufficient space to download the messages. I get this even after a fresh install.
  13. #3638
    Also, is the installation of Mount2SD possible with the latest build? I haven't been able to make it work -newbie on this. My partitions are FAT32/ext4/swap.
  14. Thread Author  Thread Author    #3639
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Code:
    You will need to set the apn manually for your network. This is pretty much setup for Sprint and virgin only. And adjust the build.prop to your network also.
  15. #3640
    TheMofaDe's Avatar
    Posts
    ROM
    Stock
    Sry im a noob and im running Xionia Clockwork CWMA v1.2518.6
    i wanna install this rom but step 3 confuse me because i dont see a option anywhere to wipe BOOT or SYSTEM
    STEP 3
    3.Now wipe Data, BOOT, SYSTEM, CACHE from recovery
    These are the only wipe option i have
    wipe data/factory reset
    wipe cache partition
    and under the ADVANCE menu
    Wipe Dalvik Cache
    Wipe Battery Stats
    If i can still flash this rom can someone tell me what to wipe and in what order from the options i have mention above
  16. Thread Author  Thread Author    #3641
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Quote Originally Posted by memsman View Post
    You might try the alpha 17b build, as it doesn't have any apps to SD scripts. 17c uses the same built in scripts as quattrimus.
    And I use google voice, so I'm not too sure on the VVM issues. Can you choose where to store the voicemails?
    - - - Updated - - -
    Quote Originally Posted by mofade1 View Post
    STEP 3
    Wipe Dalvik Cache
    Wipe Battery Stats
    Check under mounts in the recovery for the boot format. The data/factory reset in recovery already formats the data, system, and cache.
  17. #3642
    Where do I edit the APN? There is no APN settings under the menus.
    I've edited values already with QPST.
  18. Thread Author  Thread Author    #3643
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    open voice dialer and say "open A P N S" and enter your APNS. Or manually edit the apns-conf.xml file in the /system/etc/ folder before flashing.
    Then change these lines in the build.prop to your network.
    ro.cdma.home.operator.alpha=Sprint
    ro.cdma.home.operator.numeric=310120
    gsm.sim.operator.alpha=Sprint
    gsm.sim.operator.numeric=310120
    gsm.operator.alpha=Sprint
    gsm.operator.numeric=310120
  19. #3644
    Thanks for this but sadly it did not change anything.
    I verified all the info is correct. Im using PagePlus which is a Verizon
    MVNO with a open device policy.
    Any other ideas?
    Sent from my Nexus S 4G using Tapatalk 2
  20. #3645
    puffen619's Avatar
    Posts
    ROM
    Cold As Ice
    I missed cold as ice, as always great rom.
    The only 2 things I noticed is that when listening to music or in a call I can't adjust the volume, it just stays the same. Also I thought clock lag was going to be fixed, maybe I'm wrong?
    I'm on alpha 17c and VM
  21. #3646
    weriov's Avatar
    Posts
    ROM
    DanteROM v2.5
    Loving exploring this ROM so far - thanks to Kraven and everyone else who's been involved. Only problem I've had so far is with Visual Voicemail. Followed the customization guide, but like others, I get the notification that I'm out of memory and there's not enough space to download messages. In fact, mine also gives errors V30 and T30, indicating that it can't connect to the voicemail service at all. I don't mind trying Google Voice to deliver my VM, but if I flash back to a different ROM that uses Sprint Visual, will that screw me up?
  22. #3647
    Buddlespit's Avatar
    Wannabe kewl
    Posts
    Global Posts
    675 Global Posts
    ROM
    Wicked Sensations TW-JB
    Quote Originally Posted by weriov View Post
    I use YouMail (I love the ditching option). I had to forward missed calls to the Youmail. Now, it (to this day) still fowards my missed calls, even if I swap roms.
    "I drank what!?!?!" ~Socrates
    "Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
    New users, click here!!
    Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0
  23. #3648
    Quote Originally Posted by puffen619 View Post
    I'm on alpha 7c and VM
    7c is really old. Try 17+Vm fix
  24. #3649
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Quote Originally Posted by ThatGuyLurkin View Post
    I think he meant that....
    Sent from my LG-LS670 using Tapatalk 2
  25. #3650
    TNK2's Avatar
    Posts
    Thanks to Kraven and everyone who's working on this lovely rom.Everything works great so far, I just hope that youtube hq and regular video get fixed some time soon. Also has anyone got Awesomebeats v3 to work with this? I tried and all it does is forcecrash like crazy so I had to reformat everything and reinstall the whole rom to get DSP back. I guess I'll try the market beats installer and see if that works with DSP manager. Also is it weird that when you get a notification or someone calls when you got headphones on that it comes out of the phone speakers instead?
