- 10-13-2012, 06:16 PM
Thread Author #3801
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/6 ZVD basesband Alpha17
ALPHA 18 . uploading.
- Added Fastcharge toggle to the notification drop down.
- Test 21 kernel.(says test 20, builder error
) .. - Sprint VVM 9016 fixes.
- Home button to answer calls
- audio routing fixes
- Nav bar buttons and option from KonstaT
- Circle battery mod
- Line battery bar
- still has gmail whitescreen , got the fix, but won't boot maybe next release.
- the fastcharge toggle works independently of the CAI parts switch... will try to fix later. So use either one to toggle it on/off
- needs a new virgin patch
Thanked by 5: - 10-13-2012, 06:21 PM #3802Guess whos coming back!
- 10-13-2012, 07:01 PM
Thread Author #3803
- 10-13-2012, 08:01 PM #3804
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/13 ZVD basesband Alpha18
Flashing now will let u know what goes down
Sent from my LG-LS670 using Tapatalk 2 - 10-13-2012, 08:26 PM #3805
- 10-13-2012, 08:46 PM #3806
- 10-13-2012, 09:09 PM
Thread Author #3807
Not for this phone.
- 10-14-2012, 01:00 PM #3808
i still get the 9016 voicemail texts, is there a specific app version im supposed to use? because im using the one that was posted earlier like 3 posts up
Would You Kindly?...
001100010010011110100001101101110011 - 10-14-2012, 01:07 PM #3809
- 10-14-2012, 01:48 PM
Thread Author #3810
- 10-14-2012, 04:50 PM #3811
Are you actually using the VVM app on this phone? If so, where did you get it?
As Kraven mentioned, the second one fixed it for me; however, I'm not using the VVM app b/c I was waiting for someone else to be the guinea pig on that one since I borked my phone before trying to get that going. - 10-14-2012, 04:59 PM #3812
- 10-14-2012, 06:12 PM #3813
- 10-14-2012, 07:55 PM #3814
Running perfect here. So far, no Random Reboots or lockups, just nonstop use of awesomeness. Loving the mods and designs added :P
Offline Charging is such a pain. Reboot = Offline Charging. Do you guys have it?
Fast Charge is extremely amazing. No more 2-4 hour charges xD
Sent from my LG-VM670 using Tapatalk 2 - 10-14-2012, 08:22 PM #3815
- 10-14-2012, 09:01 PM #3816
yea i am using the vvm app, basically the steps i had to do to get it to work was i had made a backup via titanium from like hydrorom where it worked fine, and then i used the vvm that was posted earlier, copy and paste it to system/apps, set the right properties and reboot phone, now its in there but acting odd, so this is where i restore the data only from titanium and reboot and it works, i get voicemails and it displays and everything
tbh tho i have never used the i compose thing that most people seem to have problems with where it says no memory or what ever but it working to the point i wanted it to anyways
also kraven that 3754 fix worked like a charm thanks!Would You Kindly?...
001100010010011110100001101101110011Thanked by: - 10-14-2012, 09:25 PM #3817
- 10-14-2012, 09:42 PM #3818
So far I'm not seeing any clock lag with the latest. Audio routing working properly as well. Awesome job! Play music is giving me problems with lag, but it could just be the app. Apollo is working fine. Keep up the great work!
Edit: clock lag returned after a couple of days.Last edited by deaftones; 10-19-2012 at 05:34 PM.
- 10-14-2012, 10:20 PM #3819
- 10-15-2012, 04:56 AM #3820
I'm using latest with no over clock and EGL patch. Fixed a lot of problems for me.
Sent from my LG-VM670 using Tapatalk 2 - 10-15-2012, 10:03 AM #3821
- 10-15-2012, 10:05 AM #3822
- 10-15-2012, 11:10 AM #3823
- 10-15-2012, 03:02 PM #3824
EGL Patch zip is in this thread.
[GUIDE] Disable CPU rendering
Sent from my LG-VM670 using Tapatalk 2 - 10-15-2012, 03:15 PM #3825
Reply
