Page 159 of 180 FirstFirst ... 156157158159160161162 ... LastLast
Results 3,951 to 3,975 of 4496
Like Tree1000Likes
  1. #3951
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/13 ZVD basesband Alpha18
    Full wipe and beyond. Repartitioned. Two different sd cards. Have had these same two issues each time I've installed. TWRP 2.2.2.1
    Let me ask you something. Which Jo Ann Fabrics app did you try? The sneaky third party app or the one issued by the company? 5th International US, Inc is the publisher of the real app.
ID:	45731Click image for larger version.
    The reason I would like to use this ROM is access to ADB. With BobZ', I have no ADB connectivity. But, these two apps, used frequently, might force me to go back and then figure out a way around the lack of ADB support.
    If it matters, in case I haven't mentioned it, this is an OV with your patch for the buttons applied.
  2. Thread Author  Thread Author    #3952
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    I see now. It's a few lines in the build.prop that makes the difference for market capatibility. You can make the changes on the phone via Root browser app.. adb pull and push the build.prop to make the changes. If it works, i'll update the virgin patch. Unless Bobzhome's are different values there.
    ro.product.model=LG-VM670
    ro.product.device=VM670
    ro.build.product=VM670
    ro.cm.device=VM670
    And make sure you don't mess with these lines and leave as is for the nav buttons. If you delete the #, it will make it stay on all the time.
    # turn on navbar keys
    # qemu.hw.mainkeys=0
    Thraeryn likes this.
  3. #3953
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold.As.Ice CM9/Kernel 21
    Wait so for the steps on installation for Optimus V:
    1. Full wipe + wipe dalvik & wipe cache
    2. Flash "Alpha 18c" zip
    3. Flash "New Gapps with older voice search inside"
    4. Flash "10/13 Virgine fix for alpha 18"
    5. Boot
    Is that right? By the way, I'm on ZV4 is that going to be a problem o.o
  4. Thread Author  Thread Author    #3954
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Looks like you did everything correctly. I flashed the VM patch too and got the market incompatibility on those apps.
    After you make the build.prop changes, you will need force stop Play and clear data, then force stop Google framework and clear data. Reboot and clear cache and dalvik.
    Settings/apps/ All tab... find Google play store ..force stop .. clear data
    same tab.. find Google services framework. force stop .. clear data
    how to solve the problem of 'This app is not compatible with your device'
    New Virgin patch below with the changes.
    Virgin.fix2.cm9alpha18.zip
    Thraeryn, ph37rd and Sollsun like this.
  5. #3955
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hmmm... that's the problem I have now with the navbar... it does stay all the time.
    as for the other changes to the build.prop, I'll make those and get back to you in a few hours. have to go to jo-ann's and get the wife some more yarn since she's working today. it's a fair trade off, she knits and i get to play with the phone stuff...
  6. #3956
    Zakman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM10/BobzHome's 4.1
    Kraven, can u have the option for the normal task switcher rather than the sense one?
    johnh02 likes this.
  7. #3957
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thekraven View Post
    ro.cm.device=VM670
    I'm rebooting with the ro. changes right now. As for the navbar things you mentioned, they're not anywhere in my build.prop file to even mess with.
    Hmmm... unless I'm missing something, I edited the build.prop in /system and have permissions set to rw-r--r--
    no change of behavior from what I experienced before.
    Those two apps I mentioned are still coming up as not valid for this version and the navbar across the bottom is still persistent no matter how I have it set via settings> system
    Going to flash back to BobZ' ICS ROM for the morning before I head out to do the errands, will change back and investigate more when I get home.
    Thanks for the quick reply and on going help.
  8. Thread Author  Thread Author    #3958
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    It's built into the frameworks, i probably won't change that. But if someone finds the commit for the task switcher chooser code in AOKP ICS, i might add it.
  9. #3959
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good enough... will give it a shot when I get back.
    Any thoughts on the inability to turn off the NavBar? or is that part of the new Virgin.fix2 ?
  10. #3960
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just an aside to this whole discussion...
    Is there a sushi place called Fuji or something still in the Tulsa area? I believe is right across from a mall out there (something hills maybe?)... Twenty something years ago I used to travel all over the country for work and have had sushi everywhere in the US. That place had some of the best, freshest and most original sushi of anywhere I've been... whodathunkit...
    exProphecy likes this.
  11. #3961
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Oh I was just wondering.. I was looking at the installed apps and saw "Spare Parts" in the system apps. How come it's not in the app drawer? and how do I access it?
    Quote Originally Posted by ph37rd View Post
    I like this post ^_^ I love sushi! Unagi FTW
  12. #3962
    ricoson9's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hey kraven I was wondering if you can confirmif this works on this rom iv tried it on quattrimus cm9 it works but on this rom it flashes but won't go pass the boot image
    [MOD][ICS & JB]●►ACID Audio Engine V4.0◄● for most of the devices|☆☆☆TEAM AC!D☆☆☆ - xda-developers
  13. #3963
    drew_t's Avatar
    Posts
    Global Posts
    120 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Alnn View Post
    I think cm10 would be too much for this little phone
    Sent from my LG-LS670 using Xparent Red Tapatalk 2
    Bobz' CM10 actually works quite well, at least on my OV. If he could find the time to fix a couple of niggling issues such as 3G not kicking in when you go out of WiFi range, and the mic not working other than for calls, I would go back to using it fulltime.
  14. Thread Author  Thread Author    #3964
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Quote Originally Posted by ricoson9 View Post
    try what? Looking at the the audio zip, you will need to make room in system before it can flash fully. You will need ~21 MB in the system before you can flash. Delete some ringtones, bootanimation, live wallpapers, TTS files, foreign fonts you dont use.
    Edit, yeah not compatible. [MOD][ICS & JB]●►ACID Audio Engine V4.0◄● for most of the devices|☆☆☆TEAM AC!D☆☆☆ - Page 7 - xda-developers
    Read their last few pages, Everyone gets booting problems with it. V4 doesn't work well with CM, but v5 might.
  15. #3965
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    BRAVO - Everything working as designed... No NavBar, apps compatible, etc... now just going about getting all the stuff put back into its rightful place.
    Thank you very much for your efforts on this nagging issue.
  16. #3966
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    wait so does anyone know how to access the hidden Spare Parts in apps? I want to change the windows and transitions speeds
  17. #3967
    ph37rd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    isnt that under dev tools?
  18. #3968
    Samuelg900's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Zakman View Post
    Yeah, I personally prefer the regular one as well.
  19. #3969
    arrrghhh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Maybe102 View Post
    Does WiFi hotspot work on this or able to with amarket apk?
    I don't think it works yet. I for now I use foxfi. I but it's limited to blueDUN connection only
    Quote Originally Posted by A-android-B View Post
    "Wifi tether for root" works for hotspot but it makes an ad-hoc network.
    Did I miss it in the OP? I see some patch for 3rd party wifi tethering apps, but no mention of built-in wifi tether. Mind confirming TheKraven? I don't depend on the feature, but being able to create an infrastructure wifi network on-the-fly comes in handy quite often... Thanks!!
    Quote Originally Posted by Samuelg900 View Post
    +1, I would much prefer the 'normal' recent apps list. The Sense one is.. Well, Sense
  20. #3970
    johnh02's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    quattrimus cm9
    Yeah I don't really like the sense one either
    Sent from my CAI VM670
  21. #3971
    thewraith420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes Daily
    Quote Originally Posted by johnh02 View Post
    I like it the sense task switcher... Perhaps a toggle could be added to get the standard one?
    Edit: Also just have to say I'm running a18c and it's the smoothest most complete feeling ics rom I've tried yet! Great job! Really appreciate your work, and look forward to future releases. Thanks.
    Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
    johnh02 likes this.
  22. Thread Author  Thread Author    #3972
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Sense is staying
  23. #3973
    KidFr3sH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How come when flash I can't get sms split ?
  24. #3974
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kraven, if one were to attempt to integrate the youtube HQ fixes into BobZhome's CM10 ROM, how would they do so? which libs/files do I take from this ROM and push it into his .zip?
  25. #3975
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes Daily
    Quote Originally Posted by exProphecy View Post
    I'm no expert but I'd guess it has to be done at source level
