- 11-17-2012, 11:30 PM #4001
- 11-18-2012, 12:26 AM #4002
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 10/13 ZVD basesband Alpha18
a2sd on alpha19 is a mighty big failure. Turned it on first boot, rebooted, installed TiBu, Swype, Gmail, rebooted. When set to install to "default", all the apps TiBu is restoring are going on internal memory. Something may be ending up on my /sdext, as it's at 7% instead of 4% like it was on my second reboot (this is #3? 4?). Whatever it is, though, it's not enough; I only have 12 MB free on internal now.
I'll try undoing most of these app installs and switching to the other script option, seeing if it helps. - 11-18-2012, 02:39 AM #4003
- 11-18-2012, 05:24 AM #4004
- 11-18-2012, 05:25 AM #4005
By the way I'd test if you don't mind letting a VM670 user in
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware - 11-18-2012, 11:26 AM #4006
- 11-18-2012, 11:54 AM #4007
I just downloaded and flashed alpha19a. I think this update will require a full wipe. Tried just wiping cache and dalvik but it hung on the cm9 animation (waited 5-10 min) I pulled battery and started from scratch and all seems well. Partition info screen looks good and the ext options in performance I'm sure will make some ppl happy. I will note that most will probably expect ext to be enabled by default though and that's not the case currently. For the moment I reverted to my a18c nand but ill be playing testing more as I have the time. Thanks again for your work on this great rom and allowing me to help test for you.
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware - 11-18-2012, 01:15 PM #4008
I'll test kraven, even though I'm a virgin user, I don't care that it says sprint... or that my keys are switched, I'm experienced enough to fix that.
Sent from my LG-VM670 using Tapatalk 2 - 11-19-2012, 05:56 PM #4009
Update: back on alpha19a fixed my keys and setup to my liking using dc2sd ext option. Working great it'll be my daily for a bit now so I'll post anything that comes up
Sent from my LG-LS670 using Tapatalk 2 - 11-19-2012, 06:39 PM #4010
So, wraith, what install method works best to get apps actually on /sd-ext ? Have you tried using TiBu, or have you installed exclusively from Play Store? I'm wondering what would happen if I told TiBu to install to "External" instead of "Default", but I have a feeling it'd move everything to /sdcard instead of the symlinked folders on /sd-ext (which, when I check Root Browser, give no indication that they're symlinked).
- 11-19-2012, 06:45 PM #4011
- 11-19-2012, 08:36 PM #4012
- 11-20-2012, 04:08 AM #4013
No issues here what ext option are you using
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware - 11-20-2012, 06:28 AM
Thread Author #4014
A little update... alpha 19 is in testing and will be released shortly.
Fixes and features
- Gmail whitescreen fixed version1 thanks popdog123
- partition info screen in settings thanks squadzone
- Apps to ext and dalvik cache to ext option in performance settings thanks Nobodyatall
- I/o Scheduler settings
- recent apps switcher ported from AOKP
- html vids in webpages should be working thanks ganster41
- if you had youtube reboots, it's now fixed by hephappy
- 11-20-2012, 07:19 AM #4015
- 11-20-2012, 10:32 AM #4016
- 11-20-2012, 07:24 PM #4017
- 11-20-2012, 07:52 PM
Thread Author #4018
ALPHA 19E Released
- Gmail whitescreen fixed version1 thanks popdog123. Same fixes as in Oxygen rom. It might make some apps incompatible, so report if any.
- Apps to ext and dalvik cache to ext option in performance settings thanks Nobodyatall. Choose a2sd for only apps moved to sd-ext. Reboot to take effect. Choose d2sd for dalvik + apps to sd-ext. Reboot to recovery and wipe dalvik. You may need to manually delete the data/dalvik cache folder. If you like the old way of automatic app to sdext, swap out the init.d folders from my old builds.
- Still has test kernel 23, But try out any of the newer kernels to your liking. Test 21 still gave the best ontime clock
- Virgin patch coming soon
- known bug when viewing html vids in the browser then switching to the Youtube app, the vids are choppy. Force close the browser and youtube app to fix. This is due to the codec not getting released between apps.
Thanked by 11:+ Show/Hide list of the thanked
- 11-20-2012, 08:31 PM #4019
- 11-20-2012, 08:52 PM #4020
- 11-20-2012, 09:29 PM #4021
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 11/20 ZVD basesband Alpha19
Everything's running super smooth and everything's working great. I also love the webos recent window style, thanks for adding the option to change it. Thanks kraven
Sent from my LG-VM670 using Tapatalk 2 - 11-20-2012, 09:33 PM #4022
- 11-20-2012, 09:51 PM #4023
- 11-20-2012, 10:04 PM #4024
- 11-20-2012, 11:39 PM #4025
Reply
