Page 162 of 179 FirstFirst ... 159160161162163164165 ... LastLast
Results 4,026 to 4,050 of 4472
Like Tree1000Likes
  1. #4026
    Default Re: [ROM]COLD AS ICE-CM9 Sprint LS670 11/20 ZVD basesband Alpha19
    Dig the updates, and would love a whitescreen-free Gmail app, but I have to stick with 18c. 19e is giving me the same problems as Oxygen - FCs on ES File Explorer & Tweetdeck, and a glitch in Words With Friends that makes it unplayable. (I also got frequent whitescreens in Dolphin Browser on Oxygen, but didn't try the new CAI long enough to see if this problem carried over, as well.)
    Not complaining, just reporting - much thanks, The Kraven, for sharing your awesome work!
    Sent from my LG-LS670 using Android Central Forums
    Thanked by:
  2. #4027
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by relooreloo View Post
    Hmm I will have to verify but es file explorer worked fine for me on 19a and c? Perhaps the white screen fix broke it?
    Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
  3. #4028
    Seditec's Avatar
    Posts
    ROM
    Stock
    es file explore works fine on all 19 for me
    Sent from my LS670
  4. #4029
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by Seditec View Post
    Sent from my LS670
    Yes, I ment I'm pretty sure it worked on one of the test versions of 19 as well.
  5. #4030
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    I think I might have messed something up. I am getting out of memory errors. I have an ov. I did a full wipe including data and sd-ext. I flashed the rom, gapps and virgin patch 19. I tried to restore my apps through titanium (which worked fine on the previous builds), but I ran out of memory. I rewiped and reflashed. I tried installing my apps though the play store, but I ran out of room again. Under settings, partition info it says I'm using 259 mb on my sd-ext, but when I go there in root browser, there is nothing there.
  6. #4031
    bluefalcon13's Avatar
    Posts
    ROM
    DanteROM
    I think my nub-ness is showing.... I seem to be failing to setup app2SD properly. so far, I have re-partitioned my SDcard to hold 1Gig for /sd-ext, setup the settings under performance (to a2sd), but my apps are not dumping into sd-ext, but only into the internal flash :/
    Does anyone know where I am going wrong here?
    Thanks
  7. #4032
    DoesItMatter's Avatar
    Posts
    ROM
    Rooted Jellybean, CM 7.2
    Did a fresh install of Alpha 19E
    Did a format boot, then wipe system/data/cache a couple of times
    The dalvik-cache -> cache seems to be broken?
    Soylent Green Is People!
    Sprint - Samsung Galaxy S3 --- Rooted, Tweaked, & Obfuscated
    Stock Rooted Jellybean 4.1.2 MB1 with all bloat removed
    Agat TW Kernel 0.4.3 -- MD4 Modem/Radio -- PRL 24014
  8. #4033
    So I flashed this coming from bobzhome's ics rom and I don't think apps2sd is not working for me because my internal memory is almost running out and on my previous rom I had like 100 apps and my internal memory would only have like 15 mbs taken up, idk if I did something wrong and does anyone else seem to have this problem?
  9. #4034
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Quote Originally Posted by bluefalcon13 View Post
    Thanks
    Same thing happened to me, I just switched a2sd to dc2sd and that fixed it for me.
  10. #4035
    Posts
    ROM
    DanteROM
    Just tried that, but I ended up out of memory again after installing a few apps. Going to roll back to my A18 install until this evening to try and get it working tonight.
  11. #4036
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Me too, I tried it with and without the mountext script.
  12. #4037
    Posts
    ROM
    On a side note - I went back to Alpha 18 (can't remember which version of 18 I am using - I think 18C)
    Flashed the test35 kernel built on 11/20 - wow - that kernel is damn speedy!
    Thanked by:
  13. #4038
    Posts
    ROM
    DanteROM
    got it working with a fresh flash:
    1) uninstall anything in the downloads tab
    2) set app2sd to dc2sd (assuming you have the partition built right)
    3) reboot phone
    4) install away!
    Thanked by 2:
    Thraeryn likes this.
  14. #4039
    This rom has the best battery life, thanks Kraven!
  15. #4040
    Quote Originally Posted by upconvert View Post
    I had that exact problem, out of memory when i tried flashing 19 but I'm on the s not the v. I decided to just stay with the 18c build.
    Sent from my LG-LS670 oh hush
  16. #4041
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Well I'm also running bobzhome's kernel. With my custom build. White screen fixes seem to be working.
  17. #4042
    The volume doesn't seem to work, it only stays at loud it doesn't lower with the headphones or without them
    Never mind I rebooted and that stopped
  18. #4043
    Encerspay45's Avatar
    Posts
    ROM
    MiRaGe/jawz101 kernel
    So, on the new update, does this mean I can disable apps2ext?
  19. #4044
    Quote Originally Posted by Encerspay45 View Post
    Yes
  20. #4045
    koeylondon's Avatar
    Posts
    ROM
    DanteROM(w/Hydro)/CAI CM9
    Just so we're clear, TheKraven, I'm gonna miss this rom starting Saturday when I get my new phone.
    You're like that online friend I don't really see, but who's constantly sending me awesome stuff. I will miss you, and this ROM, more than you can know.
    Thanks again, and I look forward to another build before I leave. ;-)
  21. #4046
    Posts
    ROM
    Quote Originally Posted by _alexkta View Post
    Yes
    Yayayay!!!! Link2SD, here I come!!
  22. #4047
    koeylondon's Avatar
    Posts
    ROM
    Actually, from what I can tell, all 2EXT scripts are now disabled by default.
  23. #4048
    gyanos422's Avatar
    Posts
    ROM
    aospCMod-vm670-20110601
    I tried to flash this on my VM670 but get Status 7 error. how do i install on this device?
  24. #4049
    Quote Originally Posted by gyanos422 View Post
    What recovery are you using?
  25. #4050
    Posts
    ROM
    Changes Daily
    He got it... He was on cwm green and switched to xionia. That did the trick
    Thanked by:
