- 11-27-2012, 10:14 PM #4151
- 11-27-2012, 10:44 PM #4152
Re: [ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
You will never get Netflix to work on this phone. Netflix uses hardware acceleration to render video. Qualcomm has not (nor ever will) release drivers for HW acceleration for Android 4.x. And the sad part is, its not just this phone that they won't release drivers for.
Sent from my LG-LS670 using Android Central Forums - 11-27-2012, 10:46 PM #4153
- 11-27-2012, 11:31 PM #4154
- 11-27-2012, 11:36 PM #4155
I have an 8gb card partitioned with 2gb ext4 and 6gb fat32
Good to know. I'll give it a shot. Do I need to start fresh with a wipe and re-flash, or can I toggle the setting to dc2sd and let the script sort everything out on reboot?
Sent from my LG-VM670 using Android Central Forums - 11-28-2012, 12:48 AM #4156
- 11-28-2012, 02:09 PM #4157
Sent via my ZV5 VMOV(ns) - 11-28-2012, 02:18 PM #4158
I did a quick search, but didn't find anything, so I apologize if this has already been addressed. Does anyone else's phone not enter the lock screen when you turn the screen off sometimes? I don't know under what circumstances it does/doesn't work yet. But if I run Fast Reboot after the phone stops going into the lock screen, it pops the lock screen up and then it starts working fine (entering lock screen when I turn the screen off).
- 11-28-2012, 02:32 PM #4159
- 11-28-2012, 02:47 PM #4160
- 11-28-2012, 03:40 PM #4161
Mine was doing it for a while with high clocking but since I updated I haven't bothered to clock that far up again
I was clocked to 864
Sent from my LS670Thanked by: - 11-28-2012, 03:45 PM #4162
- 11-28-2012, 04:15 PM #4163
- 11-28-2012, 04:18 PM #4164
- 11-28-2012, 04:59 PM #4165
Apart from the lock screen issue (which may or may not be fixed now), this rom has been great. I'm using this on the Optimus V.
I don't really have deep sleep issues anymore, I did until I tried this, but now it seems to be fixed. The only issue I see now is the clock lag, but I don't mind that because I don't use an alarm.
Thanks theKraven.Thanked by 3: - 11-28-2012, 08:17 PM #4166
Sorry I have been gone for a while. long story, work and a new phone. I will be flashing t alpha 19E and new apps either tonight of tomorrow and test it out. With me having a new phone I can test more unstable releases if Need be . Just PM me
- 11-28-2012, 08:47 PM #4167beamed from the mothership...but its only a proxy for mylubuntu 12.04
- 11-28-2012, 09:54 PM #4168
My phone won't boot after flashing Alpha19. It's stuck at the LG screen.
EDIT: When installing it has the following error:
E:Corrupt file: system/usr/icu/icudt461.dat
E:signature verification failed
EDIT2: After toggling the security checks it successfully installed. I don't recall having to ever do that before.
EDIT3: Now it's stuck at the loading screen that shows the lanky android guy with the glowing circle on his chest.Last edited by John Smith7; 11-28-2012 at 10:07 PM.
- 11-28-2012, 10:39 PM
Thread Author #4169
- 11-29-2012, 12:20 AM #4170
Whenever I record a video with the built in video recorder the thumbnail does not display correctly in the gallery (or in quickpic). It will only display a blank grey/black square. The video plays back ok though. This is with alpha 19E and kernel 21. After installing CM9 I flashed back to another rom that I know can correctly create and display video thumbnails (to see whether it was an issue with thumbnail creation or thumbnail display) and the thumbnails of the videos I recorded with CM9 were still blank in the other rom so I am thinking that the issue is with the CM9 rom creating the thumbnails.
Anyone else see this problem? - 11-29-2012, 12:27 AM
Thread Author #4171
ICS uses hardware decoder for thumbnail creation, so i don't think it will work with our omx workaround atm.
- 11-29-2012, 01:09 AM #4172
- 11-29-2012, 01:54 AM
Thread Author #4173
You might have to go through one by one to see which one causes it. It could be the beats/walkman audio/xloud stuff.
- 11-29-2012, 08:56 AM #4174
I did a full wipe, installed alpha 19E, gapps with the older voice, disabled signatures, then the zvd to zvj patch . Then formatted my32gb
In COT, partitioned 1024mb, chose 256mb swap, rebooted recovery, mounted the next, rebooted system for long reboot. Skipped the Google setup in cm9 and saw that a2sd was somehow automatically selected. Setup Gmail, updated in play store, rebooted.
Now... I noticed somehow drop box made it through all that and was on my apps list.y - 11-29-2012, 03:46 PM #4175
I don't see the 1 gig reflected anywhere, and after a few installs I'm getting no storage room errors. My web eemsoddtime typing these postthecurto wantjuaround. I don't understand what dc2sd is, or if that would help. I love this from and I'm. Very impressed with all of the work that has obviously gone into it, I would love to get this smoothed out so I can show off what ana
Reply
