Page 17 of 179 FirstFirst ... 14151617181920 ... LastLast
Results 401 to 425 of 4464
Like Tree994Likes
  1. #401
    PatrickAkridge's Avatar
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Cold as Ice - CM9 kraven
    Default
    The 58 boot img fixes ADB, Wifi, Screen Rot., and Gallery for me, but it has been causing "Clock" to force close when I tap on alarms... anyone else see this?
    Sent from my LG-LS670 running CyanogenMod 9 and ICS
    Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
  2. #402
    Default
    Quote Originally Posted by PatrickAkridge View Post
    I'm not sure what the differences are but I'm running 57 with all of the above working and have had no issues with clock force closing, though I do get random reboot. I kinda expected that with it being experimental though.
    Sent from my LG-LS670 using Tapatalk
  3. #403
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
    Quote Originally Posted by hman333 View Post
    I have no issues with any of that and I'm on the normal Alpha4 ROM and Gallery, Voice Search, ADB, WiFi, Screen Rotating, etc all work, the only thing I can tell that doesn't work is the Camera but I'm assuming that's a driver issue.
  4. #404
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Default
    Clock doesn't like me...
    Sent from my LG-LS670 running CyanogenMod 9 and Ice Cream Sandwich!
  5. #405
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Default
    Video bugs... yes, its Nyan Cat.
  6. #406
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    Quote Originally Posted by ShadowEO View Post
    Don't get your hopes up for the camera anytime soon. Kraven and Lupo are amazing, but it's gonna take a while for a working camera to get down the pipeline (simply because there is a WHOLE lot more than just a single driver acting up). Take a look at post 3193 on thread over at xda to get an idea of the scale of the problems they're facing.
    Thanked by:
  7. Thread Author  Thread Author    #407
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    Just noticed live wallpaper works. I'll make a separate zip if you would like to try ics live wallpapers.
    Thanked by:
    Va1ha11a likes this.
  8. #408
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Yes Please! Unintentional fixes FTW!
    Also, I don't know if this is just me, but when I pull up the keyboard in the browser (to log into AC, for example) the browser freezes up.
  9. #409
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Quote Originally Posted by Va1ha11a View Post
    I know, I wasn't really planning on using the Camera anyway which is the reason I took the dive and flashed to the ROM.
    @thekraven: I noticed that too yesterday I installed a Live Wallpaper and it worked! *Goes to find his Super Mario LWP that he was using on Android-x86.*
  10. #410
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Default
    Guys, especially leaven, can y'all throw together an offline charging zip based off of CM9? I flashed the one for CM7 thinking it would work with CM9... no luck.
    I feel pretty stupid now.
  11. #411
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Default
    Mine does that sometimes too.
  12. #412
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    found if anyone is interested in playing. IDK if it works (I haven't the time to test) so I am in no way responsible if anything happens. Now, disclaimer time over, the resolution for the optimus s is 320x480. Instructions are included in the OP of this thread. All Credit for making this goes to Akilldema for porting it to our resolution, and 73v1n on the cm team for making it. I take no credit for this work other than mentioning it here in this thread.
    Also, after looking at Lupo's cm9 thread over at xda, it seems like the browser issue isn't just with stock (and affects not just the opti s).
    EDIT: Tested. Confirmed working. DOES NOT cause borked wifi (as was previously thought)
  13. #413
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    I seem to notice my clock on the lock screen, as well as the top clock in the status bar doesn't seem to update sometimes...but the clock app itself does stay updated. Anyone else have this problem?
    Also my wifi quit working again, but re-flashing the patch file seemed to fix it again
    Attached Thumbnails Attached Thumbnails [ROM]COLD AS ICE-CM9+Paranoid Android  LS670 11/20 ZVD basesband Alpha19-screenshot_2012-02-26-10-27-31.png
  14. #414
    bjbroderick's Avatar
    Posts
    ROM
    Cold As Ice CM9 A4 / ICS
    It works. Very nicely. Thanks for the link
    Thanked by:
  15. #415
    Posts
    ROM
    Lol, and now my WiFi is borked. Starting over from alpha 4
  16. #416
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Default
    Quote Originally Posted by tlrsax54 View Post
    Thats odd. Mine hasn't done that... yet. :rolleyes:
    EDIT: it just started. Just now.
  17. #417
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Quote Originally Posted by bjbroderick View Post
    ya think you're borked because of the new boot anim? Or something else? (I wouldn't think putting something in /system/media would affect the wifi, but I'm no dev, so kraven (or Drew), correct me if i'm wrong.
  18. #418
    drewwalton19216801's Avatar
    Posts
    ROM
    HydroROM
    Default
    ya think you're borked because of the new boot anim? Or something else? (I wouldn't think putting something in /system/media would affect the wifi, but I'm no dev, so kraven, correct me if i'm wrong.
    Boot animation can't effect WiFi. They are just simply unrelated.
    Thanked by:
  19. #419
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    I'm sorry, but I'm not quite clear. Which is the correct time? The SB Clock, or the Big Clock in the Center Clock?
  20. #420
    prowlingfox's Avatar
    Posts
    ROM
    tdm's AOKP ICS
    found if anyone is interested in playing. IDK if it works (I haven't the time to test) so I am in no way responsible if anything happens. Now, disclaimer time over, the resolution for the optimus s is 320x480. Instructions are included in the OP of this thread. All Credit goes to Akilldema for porting it to our resolution, and 73v1n on the cm team for making it.
    Me ghosta. lol. using it on CM7.2.
  21. Thread Author  Thread Author    #421
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    Not too many updates as alpha4 was based on lupohirp Beta4 folders. Plus their fixes are not exactly public.
  22. #422
    eletendre84's Avatar
    #sarcasm
    Posts
    ROM
    kraven CM9 / LeWa Alpha 3
    Is the new build waiting for the next big release by lupohirp?
  23. Thread Author  Thread Author    #423
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    They just released Beta4 yesterday. So we are about even for now.
  24. #424
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    The big clock in the center is right...I opened up the clock application. It reads correctly and my alarms go off on time, but often times the clock on the top right (smaller clock) sticks to whenever I last shut my screen off.
    Another example; I see a lot of text messages that will say "Sent at 1:05 PM" but the small clock says it's only 1:00....kinda trippy lol.
  25. #425
    "The Button Pusher"
    Posts
    Global Posts
    592 Global Posts
    ROM
    Default
    Please help, kraven. I removed the persist...16bpp line in build.prop, successfully rebooted, and it ain't helping.
    It is doing the "rays" thing with EVERYTHING. Please Take a look at my images.
    Anything you can think of to fix this??
    Can't get vids to play either...
    Thnx for suggestions in advance...
