DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Page 171 of 179 FirstFirst ... 168169170171172173174 ... LastLast
Results 4,251 to 4,275 of 4471
Like Tree997Likes
  1. #4251
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Default Re: [ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
    Are we close to infrastructure hotspot mode working?
    liamstanley likes this.
  2. #4252
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by Tyler555 View Post
    Is there any way to make a patch or something to make sd-ext less buggy. Or if we are using it wrong could you edit the rom post to include steps for using a sd-ext?
    I just can't seem to get things working right now. Thanks
    - - - Updated - - -
    haha true
    Did you try skipping setup on a fresh flash to enable the sd-ext options then reboot and continue setup as normal
    upconvert likes this.
  3. #4253
    Default Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
    Quote Originally Posted by thekraven View Post
    Those are meant to be experimental Gapps. Just to save from downloading from the play store everytime. It should also have google voice and gmail. If you have a sd-ext partition on your sdcard, you can turn on a2sd or d2sd in Settings/performance, and it will move data/app to sd-ext. You can remove apps from the gapps zip or remove with titanium backup. Otherwise, use the smaller gapps for normal use. .
    It did have both of those, but I deleted Google Voice because I don't use it. I was just surprised at how much space was being taken up - I used to be on Oxygen 3.0 and had plenty of room for apps. I enabled a2sd per your suggestion and that seems to have cleared up the space issue for the time being.
  4. #4254
    kylemaguire's Avatar
    Resident Teen
    Posts
    ROM
    Quattrimus
    Does anyone know a super simple way to figure out what ext a partition is? I want to make the jump to 19e but I'm afraid that I have mine formatted as ext2.
    Sent from my LS670 using Android Central Forums
  5. #4255
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    You can use the minitool partition manager on your pc.
    Sent from my GT-P7310 using Android Central Forums
  6. #4256
    Looks like the best fix for gmail/facebook whitescreens is to disable hardware acceleration, but it does not seem that CAI or Paranoid can set this on a per app basis. (Can anyone w/ more knowledge confirm this? The lack of data/local/hwui.deny folder makes me think it. Could it be implemented?)
    As a workaround, I used APK Multi-Tool to decompile the apks for Flipboard and Gmail, and remove the 'hardware accelerated="true"' flags from their manifests. Boom!- works great, no more whitescreens, and they load/run super-fast! Other ROMs are reporting big speed increases with hardware acceleration turned off for all apps that don't need it.
    Thanked by 2:
  7. #4257
    i was wondering if someone could help im using the alpha19.testE.cm91-20121120-kraven-LS670 on the cricket network and im not able to replace the telephony.db without having issues is there something i need to do first or how can i go about doing that
  8. #4258
    Holy crap this rom has come a long way from when I was a tester..... Glad to see you still in action @thekraven! I do miss your work.
    Sent from my One V using Tapatalk 2
  9. #4259
    bokoxthexchocobo's Avatar
    Posts
    ROM
    Gingersnap 2.2
    Hey thekraven,
    May I get your permission to use CAI as a base to port some roms? (If i could, major props, I will definitely include you in the credits). If not its cool, it will take me longer, but I think I can manage to compile bobz cm9 from source.
    Can't seem to PM you so I posted here.
  10. #4260
    G'day,
    In the new gapps, test_1 & test_2 is the google voice the same as google voice in the market, or is it optimized?
    If optimized is there a way to just install it without the rest of the zip?
    Really liking CAI, its running like a well oiled clock.
    Thanks in advance, G
  11. Thread Author  Thread Author    #4261
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Quote Originally Posted by Sine Wave View Post
    G'day,
    Those apps are from the market, you can remove what you don't like in the zip or just copy the apk to your sdcard and install it manually. Just make sure settings/security/unknown sources is checked.
    Thanked by:
  12. #4262
    williek113's Avatar
    Posts
    ROM
    CM7/CM9
    Are we going to be seeing some new great updates with the ics libs from qualcomm?
    I can't seem to stay on the same rom for longer than... a day... sent from my LS670, or my windows 7 computer
  13. Thread Author  Thread Author    #4263
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    I think they are old, we've been using ics adreno 200 libs when they came out in May.
    Edit: actually since april starting in alpha7. [ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
    Thanked by 3:
    tlrsax54 and kylemaguire like this.
  14. #4264
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Yes, but the egl file is the only difference.
  15. Thread Author  Thread Author    #4265
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    That's just the egl tweak. We petitioned qualcomm back in March and those are the files they gave us.
  16. #4266
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    So petitions do work
    A-android-B likes this.
  17. #4267
    Will the the gapps work on any ics ROMs for the optimus?
    Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
  18. #4268
    It should
    Sent from my LG-LS670 using Xparent Cyan Tapatalk 2
  19. #4269
    Do you guys know any good JellyBean themes for CM9?
  20. #4270
    One of my faves is JellyBlueX on the market
    Sent from my ZombieICS-VM670 using Xparent Blue Tapatalk 2
    Thanked by:
  21. #4271
    Quote Originally Posted by dingermtb View Post
    It looks awesome but it can't install on my phone
  22. #4272
    I changed my LCD density to hdpi (240) using Pimp My ROM, or you can use LCD Density modder, both on the market. I prefer PMR due to all the extra tweaks and mods you can apply.
  23. #4273
    Yea I have pmr to and all the tweaks are cool, but when you change lcd density do you change back after ?
  24. #4274
    I didn't. I kept mine at 240
  25. #4275
    Which one do I pick: A2SD or DC2SD
