Page 173 of 180 FirstFirst ... 170171172173174175176 ... LastLast
Results 4,301 to 4,325 of 4496
Like Tree1000Likes
  1. #4301
    Sine Wave's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
    Quote Originally Posted by Trailblazerman View Post
    Kraven, any ideas about clock lag? Man, I love every aspect of this ROM, but the clock lag is killing me. Sometimes it takes a full minute to update. This device is my clock.
    For me tapping the the power button to dim the screen, and a second time to activate the screen brings the clock right in.
    Trailblazerman likes this.
  2. #4302
    alimalimbaev's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Really good job!!! If there any way to fix the mic of the headphones, I have to use them the most of time!?!
  3. #4303
    ganggreen30's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Beta????
    Sent from my VM670 using Xparent Pink Tapatalk 2
  4. #4304
    Trailblazerman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thekraven View Post
    I narrowed it down to the ril. If you go by airplane only or wifi only, the clock keeps time. Try un checking automatic timezone and network time. It is the proprietary files we have to work with.
    Thanks! I'm testing turning those settings off. Not sure about editing the properties file, but I might be up for that if this doesn't work. I will report back my findings.
  5. #4305
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sine Wave View Post
    Nice. This works for seeing what time it is, so that helps a lot. Thanks!
    However, when I unlock the screen, it shows the wrong time. Now that's odd.
  6. #4306
    Sine Wave's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It works with the screen unlocked
  7. #4307
    upconvert's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold as Ice
    You can also just rotate the screen to bring it back to the right time. If I need to use it as an alarm I plug it in and set the screen to stay on all night.
  8. #4308
    BigBobMI's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
    I just installed this and like it so far (although battery life seems much worse than Mirage), but I seem to be having some trouble with having the apps installed to the SD card. I used Mini Partition Tool to create an ext4 partition of about 1 GB on my 8 GB SD. Under the Performance settings, I also set the mode to A2SD. However, it does not seem like the apps are automatically being installed to the SD card. When I go to Apps under the Settings option, some of the apps give me the option to "Move to SD card", but many of the apps do not even give me that option. Some of the apps that do not give me the option to "Move to SD card" include doubletwist, Amazon App Store, Google Reader, Handcent SMS, Swype Beta, The Weather Channel, Titanium Backup, Yahoo Mail.
    Am I missing something here? Thanks.
  9. #4309
    chcub1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    USB mass storage isnt working, it worked earlier but not anymore. it says connected but doesnt show up on my computer ive tried rebooting the phone and using a diffrent computer can anyone help please? im in a rush i have to finish an essay and its saved on my sd card...
  10. #4310
    flapjack.fiasco's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    JBC/Squid's Kernel
    Quote Originally Posted by chcub1 View Post
    Use Dropbox or Google Drive to upload until you figure out how to get USB working.
  11. Thread Author  Thread Author    #4311
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Turn off fast charge and reconnect the usb cord
    chcub1 likes this.
  12. #4312
    fortyquid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try again with d2sd. Seems to work better for me.
  13. #4313
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by fortyquid View Post
    ^^^^^^^^^^^This. I also had to use d2sd to get my Dalvik Cache over on the SD as well. I was getting out of space errors. I don't know if you can really trust the Android 'move to sd card' interface. I just watched the storage numbers as I installed apps. It went up quickly. Some of these apps are real pigs (ie.Evernote).
  14. #4314
    chcub1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having trouble with my 3g staying connected, like the 3g icon is there but there's no little arrows or when I open browser it doesn't work until I turn off data then back on and sometimes that doesnt work either, any help?
  15. #4315
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold.As.Ice CM9/Kernel 21
    Anyone else having problems posting on instagram?
  16. #4316
    Alnn's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Me it shuts down all the time after I take pictures... Since I don't use it too much I discontinued looking into the problem.
    Sent from my LG-LS670 using Xparent Red Tapatalk 2
  17. #4317
    Alnn's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But I know this much. Once you take a picture and it goes into processing. It shuts down all the time.
  18. #4318
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've had this problem as well. Mostly after switching to roaming (in my local grocery store) and then back to Sprint. A reboot is required when this occurs.
    19e does it way less than others for me.
  19. #4319
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Quote Originally Posted by Alnn View Post
    The one way I know to make it work is if you reboot your phone then try again. The second picture you take force closes though. So basically you have one shot after every boot..
  20. #4320
    kylemaguire's Avatar
    Resident Teen
    Posts
    Global Posts
    140 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quattrimus
    Quote Originally Posted by exProphecy View Post
    For me, when I disable the "advanced" camera, I get about 3 shots before a reboot.
    Sent from my LG-LS670 using Tapatalk 2
  21. #4321
    gingerc76's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Umm noob question but where is the caller ID settings on this rom
    Sent from my LG-LS670 using Xparent Purple Tapatalk 2
  22. #4322
    Tyler555's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7.2 and now CAI CM9
    I'm getting a portable USB dac/headphone amp and was wondering if there were any kernels that support digital audio through usb that also support this rom or kravens cm7.2
  23. #4323
    _alexkta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Every time I try CAI I always have problems with calling and the other person can't hear me, if I swap out the phone apk with one from Bobz ics will it fix that?
    EDIT: It didn't work
    Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
  24. #4324
    upconvert's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold as Ice
    Quote Originally Posted by _alexkta View Post
    The reason I love this rom is that I can make calls using regular earbuds and the phone's mic. There is one small bug, that isn't even enough to complain about, but it might be related to your problem. On the first call of the day, I have to wait until the call starts and then turn up the volume. After that calls proceed fine.
  25. #4325
    _alexkta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just using the Paranoid Android ROM and calling works for me on it
    Sent from my VM670 using Xparent Cyan Tapatalk 2
