1. chcub1's Avatar
    2 things, 1) I'm having trouble with wifi when I'm downloading things sometimes the wifi disconnects does anyone how to fix that? And is it possible to get swype?
    02-10-2013 07:06 PM
  2. kylemaguire's Avatar
    1)reset the router? 2) just go to swypes website and download the beta.
    Sent from my LG-LS670 using Tapatalk 2
    02-10-2013 07:37 PM
  3. chcub1's Avatar
    Link to swype please?
    02-10-2013 08:51 PM
  4. fortyquid's Avatar
    Just Google swype. You have to register with them to get access, then they email a link to the apk.
    SwiftKey Flow is better though. It's free from their blog while it's in beta.
    02-10-2013 09:08 PM
  5. _alexkta's Avatar
    You don't have to register for Swype anymore
    Sent from my VM670 using Xparent Cyan Tapatalk 2
    02-10-2013 09:40 PM
  6. kylemaguire's Avatar
    http://lmgtfy.com/?q=swype+beta+download
    02-11-2013 08:59 PM
  7. bstillwell15's Avatar
    Maybe time to restore an old nandroid or reflash. Are you running a year old version, or have you been updating (alpha 19)?
    Sent from my GT-P7310 using Android Central Forums
    running a year old ver. planning on updating to alpha 19 after i test it out for a bit.
    02-13-2013 11:23 PM
  8. nus's Avatar
    I'm currently on an OV with ZV5 baseband and running CM7 on VM. Will upgrading to this ROM cause any permanent changes that may prevent me from going back to an OV-specific ROM? i.e. baseband changes?
    02-23-2013 07:19 PM
  9. _alexkta's Avatar
    Nope
    02-23-2013 08:17 PM
  10. Esp_eon's Avatar
    I'm a bit confused.
    I'm running your CM7 rom on my Optimus S at the moment; to upgrade to this CM9 rom, all I have to do is move my apps to my sd card, then do the usual wiping and flashing, correct?
    Also, can I flash the rom, then flash one of the kernels, with little or no adverse effects?
    02-24-2013 02:28 PM
  11. AndyOpie150's Avatar
    I use two apps.
    1: Titanium Backup with purchesed Pro Key.
    2: Root Uninstaller.
    Just before going to the recovery to wipe and format everything but the SD card I run the two options in the Scheduals tab of Titanium Backup.
    Root Uninstaller (I have the Pro version) automatically saves every and all downloaded apk's to the SD card (you have to manually delete an apk from the app, the updated app can't). This I use for several reasons.
    1: Titanium Backup sometimes freezes when trying to install a specific app when running the batch restore option. I then reboot and install the app by going to the Root Uninstaller folder on the SD card and copying the apk to the root of the SD card, then select to install. Then I finish the batch restore from TB.
    2: Sometimes I don't have a good enough data connection. Can't sign into the market after a new ROM flash, so I install Titanium Backup's apk that's in the Root Uninstaller folder.
    3: I update an app from the PlayStore and it's borked.
    I go to Root Uninstaller and re-install the old apk that did work.
    When in the recovery I make sure I select all these options:
    1: wipe data/factory reset.
    2: wipe cache partition.
    3: I go to the mounts and storage option and select:
    A: format boot.
    B: format data.
    C: format cache.
    D: format system.
    C: format SD ext(if you don't have a partition on the sd card skip this).
    Note: Don't format the SD card. It will wipe all data from it.
    I go to the advanced section and wipe the dalvik cache as well. OCD thing.
    Edit: Almost forgot.
    What you could do is get everything on the ROM set up just how you like it, apps in just the right place as well.
    Then make a backup.
    Now when trying different kernels, if one doesn't work for you, just restore backup and try another.
    02-24-2013 09:59 PM
  12. upconvert's Avatar
    Never mind.
    02-24-2013 11:15 PM
  13. chcub1's Avatar
    I'm having trouble with this ROM. The wifi turns off on its own randomly and as previously stated I tried resetting the modem still does it. And the data connection goes blank like every 10 minutes. I have to pull the battery and reboot to get data connection again and it gets very annoying. Can anyone help please?
    02-25-2013 11:06 PM
  14. AndyOpie150's Avatar
    First you must establish that your WiFi is working correctly.
    Flash a ROM that you know has the WiFi working.
    If everything checks out then download a fresh ROM and Gapps (making sure to use WiFi). If possible download to computer and transfer to sd card.
    Wipe and format everything but the sd card (and the sd ext if your sd card is not partitioned).
    What recovery are you using?
    02-26-2013 11:41 PM
  15. chcub1's Avatar
    The wifi does work, my mom has the same phone she doesn't have hers rooted. Hers is stock, and the wifi works with hers.
    I'm using cannibal open touch.
    02-27-2013 07:13 AM
  16. chcub1's Avatar
    I'm using 19e, and lose data regularly. I have to turn data off and on again to get it back . I'm not roaming or anything. Could it be related to my SetCPU app, which throttles the CPU when the screen is off?
    I'm having the same problem! The data turns off like every 20 minutes for me and I have to pull the battery to get data again. Have you found a solution?
    02-27-2013 09:54 AM
  17. AndyOpie150's Avatar
    Did you download ROM from computer? Which Gapps are you using. The 20120511 Gapps I downloaded three different ways came up at just over 15MB. The thread says they should be 21MB. This tells me there corrupt. This could be causing all the problems. I'm going to try and download all gapps in thread and try each and every one (as long as they don't look corrupt) to see if any will work better and not cause corruption of the ROM and downloaded apps.
    I need to find a WiFi source. Then I'll post results.
    02-27-2013 04:10 PM
  18. Esp_eon's Avatar
    By any chance, is the flashable zip file you got 15MB? I'm fairly certain that it means 21MB uncompressed after it's been flashed, since some people may not have initially installed the Gapps initially, and they may not have 21MB after installing apk's.
    02-27-2013 04:14 PM
  19. AndyOpie150's Avatar
    I'm sorry. That confused me. The thread said the Gapps.zip was 21MB. That would indicate it's 21MBs compressed, so you will be able to tell if the download became corrupted.
    In as much as there are no md5 sums generated and posted to check against, this is the only clue I have to go on. When I tried to sign in to the PlayStore I got a blank home page.
    All info tells me it could (repeat, could) be the Gapps.zip is corrupt.
    I'm also going to try with an ext.4 sd ext format. I'm currently using the ext.3 format which is supposed to be what is required for the ICS ROMs.
    That might take a while till I get my Windows/Linux machine back up.
    Edit: Extract 15MB Gapps.zip. It was 23.26MB extracted.
    I'm starting to fully believe that the problem is the Gapps.zip is corrupt.
    upconvert likes this.
    02-27-2013 04:39 PM
  20. chcub1's Avatar
    Do you know how to solve the 3g data problem?
    02-27-2013 05:24 PM
  21. chcub1's Avatar
    02-27-2013 07:45 PM
  22. AndyOpie150's Avatar
    This thread is for discussion of the Cold as Ice and Paranoid Android ROMs. This Forum is the Optimus S/Rooting, ROMs, and Hacks
    We don't need to derail this thread.
    But, I will give some info real quick.
    The V has an mdpi screen ( screen density desidnation). Any ROM from another phone with an mdpi screen can be ported over to the V.
    This requires swapping some key folders in the system, editing the framework.jar from a computer using APK MutiTool or APK Tool, etc., and finding the right combination of host ROM and kernel. Takes anywhere from a day to a week to port a ROM.
    In as much as the ROM is from a phone with an mdpi screen, yes it can be ported over to the V. No, you cannot just download and flash the ROM.zip in it's current state.
    Any other questions need to be started in a new thread in: Optimus V/Rooting, ROMs, and hacks.
    inceyet and BarakaBalls like this.
    02-28-2013 09:16 AM
  23. chcub1's Avatar
    What about the data problem? Just wondering if you know a fix for it...
    02-28-2013 08:28 PM
  24. Sine Wave's Avatar
    This is meant as a question, not a complaint. It's a GREAT build Kraven! Thank you.
    When I set up the ext, I added a swap file. It does not get used.
    Is there something, not to complicated, I can do to activate it.
    Can anyone recommend a dependable kernel with swap built in?
    Am trying to squeezea too much out of the "Little Phone That Could"?
    tia, g
    03-01-2013 08:36 AM
  25. Gpd54's Avatar
    I'm running CAI on Optimus V since yesterday. I really like it and appreciate theKraven's work on it.
    No major issues. However, I did happen to notice today:
    - clock: lock screen clock was off by about 10 minutes until I unlocked the phone. I only noticed it once this morning.
    - wifi: after installing Juice Defender (JD) on CAI 19E, wifi wouldn't start properly after JD had stopped it (e.g. when screen is off, etc). The only way I found to fix it was reboot, but then it would happen again the next time JD stopped wifi. I've no idea whether this is a conflict between JD and CAI, ICS, or whatever, but I will say that I've been running JD without issue for months on a custom GB ROM.
    Workaround:
    Juice Defender stops/starts wifi automatically in its default "balanced" mode to save battery. As a workaround in JD, you can select "customize", go into the Settings tab, and set WiFi to "disabled", which will prevent JD from managing your wifi. I haven't had the problem with wifi on CAI since doing this.
    03-05-2013 11:30 PM
4,496 ... 172173174175176177178 ...
