06-26-2015 05:39 PM
4,496 ... 178179180
tools
  1. vector84an's Avatar
    the version is 2.3.3 baseband ls670mvj_6150.kernel 2.6.35.7-perf lg-electronic@si-rd10BLD165 #2.
    Ehm, you're running ZVJ, this rom is built for ZVD - no service is 100% normal...
    Just finished going over this over here:
    [ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
    3ud1 likes this.
    06-03-2013 08:03 PM
  2. 3ud1's Avatar
    Oh..thanks for advance.
    Ok i will try and read about rom-cm10-1-pac-rom-jb-4-2-2-jbc-alpha-build-20
    06-04-2013 05:11 AM
  3. upconvert's Avatar
    Has anyone noticed that the weather widget on the lockscreen is broken? It used to work last year when I was on this ROM. I switched back to this ROM a few months ago, and now it just says "no data tap to refresh." I've also noticed that it was broken on one or two other ROMs, I think. Anyone have any ideas?
    06-28-2013 01:05 PM
  4. _alexkta's Avatar
    Upconvert I've noticed the same & I don't think it's the rom because I've tried other roms
    Sent from my VM670 using Tapatalk 4 Beta
    07-01-2013 05:55 AM
  5. djchru's Avatar
    This is a CM issue... Yahoo changed their weather API
    07-01-2013 08:46 AM
  6. upconvert's Avatar
    Yeah, I saw a commit in the CM source that fixed the API. I just don't know enough to be able to make a patch.
    07-01-2013 10:07 AM
  7. bunanson's Avatar
    If anyone wants to try a fresh build of Paranoid Android 1.6 ics/cm9 to see whats working or not. Probably just a one time build.
    • Tablet UI, Play around with paranoid settings to your liking
    • Test kernel 23
    • ZVD based.
    • Uses the old way of automatic apps and dalvik to sd-ext.
    • Native usb mass storage is broken, so use the old usb app included..
    • Has Youtube hq fixes
    • build.prop uses debug.composition.type=dyn for less flickering in the UI, works well in CAI too.
    • Currently inline with CAI,
    • Camera may need to be set manually to phone dpi.. Settings/Paranoid settings/List of apps/All tab/ Find Camera and set UI: phone , Stock dpi: phone
    • Same with Google Search, change the app to phone dpi and UI to phone Stock dpi : phone thanks relooreloo
    • If you want this ROM to behave as generic CM9 without paranoid features you can turn off hybrid mode in
      Settings / Paranoid settings. This will disable paranoid framework and rom will become standard CM9 with phone layout and default DPI.
    • Thanks to c3c0 for PA ics repos.
    Paranoid Android DOwnloads
    I want to try this on my Optimus V virgin mobile, can somebody kind enough to write a few lines which fix to use after flashing the ROM? My Op V, Zv5, CWM v4.0.1.5, currently running ThatGuyLurking "ParanoidAndroid 8/12/12 Mic fixed" built.
    TIA,
    bun
    07-21-2013 09:04 PM
  8. upconvert's Avatar
    TIA,
    bun
    Flash ROM, gapps then virgin patch, attached to first post.
    Sent from my GT-P7310 using AC Forums mobile app
    bunanson and ppossumm like this.
    07-21-2013 10:44 PM
  9. Kahroo's Avatar
    Will this work if I have a Baseband Version of VM670ZV5? Also this has PA in it, does Phablet mode work for this ROM?
    11-04-2013 06:16 PM
  10. thewraith420's Avatar
    Yes it works fine on zv5 and from what I remember it does have phablet mode
    Tapatalk'n Squid style! Android 4.2.2 JBC on my VM670 running LS670ZVJ firmware
    11-06-2013 10:31 AM
  11. jonny5449's Avatar
    Phablet never did work for me lol
    Sent from my LG-LS670 using Tapatalk 2
    11-06-2013 12:56 PM
  12. mikemillsjr's Avatar
    Anyone know a mirror to the gapps with working old voice search and mdpi or just the one with voice search? All the links in the op are dead except the one w/o voice search...
    11-08-2013 11:49 AM
  13. johnny Mnemonic's Avatar
    Does anyone have a link to the gapps every link I try on goo says file cannot be found or 500 internal error.
    11-16-2013 06:36 PM
  14. ClutchX_LA's Avatar
    I will try to find a link johnny
    Previous Username: UnrootedDroidOwner
    Current Phone: Lg MACH(LS860)
    Old phone: Lg Optimus S(LS670) Currently my MC:PE server hoster
    And soon to come is a Nexus 7 2012
    11-16-2013 07:11 PM
  15. thewraith420's Avatar
    http://www.mediafire.com/?26nlguhhn1of5pd
    I've got a pretty good collection of ov/os files
    Tapatalk'n it Squid style on JBC 4.2.2 from my VM-670
    Tim Henning likes this.
    11-17-2013 12:10 PM
  16. CaptainPackers's Avatar
    The gapps link is broken. What gapps can I use?
    03-17-2014 12:04 PM
  17. thewraith420's Avatar
    Sent from my XT907 using Tapatalk
    03-18-2014 10:36 AM
  18. SimplePurple's Avatar
    The test 38 kernel is dead, does anyone have the file, could you post an external link if that is okay.
    04-14-2014 05:39 PM
  19. unknownsoldierx's Avatar
    How do I do a fix_permissions? It is suppose to be in /system/bin/sh, but there isn't even a sh folder.
    04-27-2014 09:02 PM
  20. Melson Mendoza's Avatar
    how to install clash of clans in lg ls670 ?? or how di install incomptibles apps to phone ??
    04-29-2014 12:00 PM
  21. SimonHGR's Avatar
    Can I get this ROM from anywhere? It seems that Goo is dead, or at least comatose, right now. Are there any mirrors, or other locations I might try.
    Or, is there any ROM suitable for an Optimus S 670 (ZVD) anywhere? I'm trying to use this old phone to learn about this stuff, and having finally rooted it, I seem to be at a loss as to what to do next, since I can't find any roms yet...
    06-26-2015 05:39 PM
4,496 ... 178179180
