Page 38 of 179 FirstFirst ... 35363738394041 ... LastLast
Results 926 to 950 of 4469
Like Tree996Likes
  1. #926
    xplode196's Avatar
    Posts
    ROM
    FreeGS3
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/20 ZVD basesband Alp
    When I was testing out Alpha 5, the battery life was terrible. I think it was due to the app multi-tasking, since I'd find my data intensive apps still open in the background or something. Just my 2 cents here. I probably won't go back to CM9 until it hits beta because even with an extended battery, my phone wouldn't last too long on CM9.
    Remember to "Thank" people who help you out!
  2. #927
    Quote Originally Posted by Pkt_Lnt View Post
    I tdrops to 40% in ~four hours with very minimal use, and 5.5 hours it turns off. I charged fully, unplugged at bedtime, 7 hours later it dropped to 65%, no use.
    Messing with a ton of battery/data control apps, Juice Defender, Wireless Data Chief, SetCPU, NoFrills CPU control, AutomateIT, ad nauseum..... I own them all, but one thing or the other does not work / annoys me, so I try another. I'm probably making it worse by tinkering.
    this is what i do. recharge the battery fully the reboot the phone and pull out the power cord
  3. #928
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/25 ZVD basesband Alp
    Downloading a7 now
  4. #929
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    Quote Originally Posted by acromack View Post
    I noticed not overclocking helps a LOT for battery life. Even up to just 729mhz will make it pretty bad. Stock speed isn't terrible after all.
    I have it at 600/245 with ondemand.
    Quote Originally Posted by xplode196 View Post
    Alpha 5 v 12 was great for me, alpha 6 not so much in battery, awesome in everything else.
    Quote Originally Posted by javascriptvoid View Post
    I'll try that, interesting idea.
    Quote Originally Posted by Va1ha11a View Post
    Downloading a7 now
    Oh crap, square one here I come.
    Be nice to have notifications in Goo Inside.
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  5. #930
    prowlingfox's Avatar
    Posts
    ROM
    tdm's AOKP ICS
    was the dithering fix supposed to cure the color banding?
  6. #931
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    So Kraven, any thoughts on adding updating through Goo.im? Could be rather awesome to be able to update the ROM through an app on the device instead of downloading the new ROM and then putting it on the SD Card
  7. #932
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Early results, loves, loves, loves my wifi router, even when I tell it not to - turn wifi off, bing, back on and connected before I can reboot.
    Does NOT want to connect data. Data toggles and airplane mode toggles w-i-l-l n-o-t s-t-i-c-k, even with immediate boot. Treating me like A1-A5 before V12.
    Reset / wipe / format / systemFormatALL.zip. Just A7 and Gapps. @#$%&!*......
    Ok, after toggling airplane, fast reboot, untoggle airplane, fast reboot, toggle data, fast reboot, untoggle data, fast reboot, toggle airplane on (symbol shows in status bar -FIRST TIME!) and off, toggle data on and off. At last! 3G in happy Cyan.
    Galaxy Nexus GSM
    Kindle Fire
  8. #933
    Do a6 and/or a7 require/work better after flashing a boot.img? If so, which one?
    Thanks!
  9. Thread Author  Thread Author    #934
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    a7 plus gapps should be good enough. It has the latest boot.img fixes.
  10. #935
    pimpjuice1992's Avatar
    Banned
    Posts
    It gets stuck on lg splash sometimes. It randomly freezes sometimes and won't unfreeze and I have to pull the battery then it gets stuck again and few battery pulls will fix it
  11. #936
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Quote Originally Posted by pimpjuice1992 View Post
    Sounds like you did not wipe / factory reset / format everything. Maybe try again?
    First boot is long, but the rest are fast, and no freezes so far. I have not installed any user apps at all yet.
    Galaxy Nexus GSM
    Kindle Fire
  12. #937
    Banned
    Posts
    I do everything twice.
  13. #938
    Default
    My phone froze on me as well. I wiped everything and flashed debugzip. But overall this rom is kicking **** and taking names.
    Va1ha11a likes this.
  14. #939
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    OMG I have not been checking AC for cm9 updates and I'm on alpha 4 while everyone's on alpha 7 I missed out on 3 alphas lol
    Sent from futuristic optimus s
    Pkt_Lnt likes this.
  15. #940
    RED MAN's Avatar
    Posts
    ROM
    "Stock" for now
    I have been busy with school but I am downloading A7 and the latest Gapps now. Will test and report back. Thekraven, thanks for turning on the tethering app. Your the man.
    Better to be dead and cool, than alive and uncool.
  16. #941
    RED MAN's Avatar
    Posts
    ROM
    "Stock" for now
    I have tried ten times and can not download A7 from the Goo inside me link. thekraven is there possibly a mirror link? I keep getting download unsuccessful.
  17. #942
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    Quote Originally Posted by RED MAN View Post
    Try the goo im app from the PlayPen?
    sent from LS670 w thekraven CM9/ICS using Tapatalk
    Galaxy Nexus GSM
    Kindle Fire
  18. #943
    Been messing with this rom quite awhile and been using this site for quite awhile so heres my question is mms still not working or is their a work around or something i love this rom and my only problem is mms cant receive i hit the download it says fail keep trying trying and trying and just consistently fails. So has mms been fixed or is it still being worked on
  19. #944
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    Quote Originally Posted by theewolf View Post
    It is still not working for me in ALPHA 7.
    Galaxy Nexus GSM
    Kindle Fire
  20. #945
    RED MAN's Avatar
    Posts
    ROM
    "Stock" for now
    The app gave me a 7.13 KB download. I know this Rom is bigger than that. I tried it twice with the same results. I can't get this ROM to save my life. The app wont give me the ful download but it says the download is complete and I have tried three different browsers to download it from the link with no success. It keeps stopping at around seventy percent and saying download failed.
  21. #946
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    Well try as I might, I cannot get data to connect on A7. It shows 3G in status, but Play and browser will not work. Nada. Zip. Zilch.
    sent from LS670 w thekraven CM7 using Tapatalk
    Galaxy Nexus GSM
    Kindle Fire
  22. #947
    RED MAN's Avatar
    Posts
    ROM
    "Stock" for now
    Someone please help me get the A7 download. I even tried downloading it to my tablet and it still failed.
  23. #948
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Goo IM seems to have troubles. I deleted the one that I DLed directly from the app on my phone yesterday.
    Just tried the web link in the OP, and it got to 20.3 mb of 70.4 mb and is frozen. Tried to pause the DL in Firefox and it failed because "file could not be read". Tried a second time and it froze again at about 22 mb.
    I think you just have to wait. Get ahead on that school work.
    Galaxy Nexus GSM
    Kindle Fire
  24. #949
    Thanks kraven!
    I tried a7 last night, but my deal-breaker issue is still present: I cannot put the phone on mute. I also noticed that the power button still hangs up an active call, even though the setting is off. I didn't try bluetooth, but I imagine that it still won't work for calls.
  25. #950
    time to be like normal people and use a computer
