Page 4 of 179 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 4469
Like Tree996Likes
  1. #76
    sundash22's Avatar
    Posts
    ROM
    GingerROM - FrankenTAB
    Default Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
    Quote Originally Posted by Invincible Madness View Post
    Same here, no wifi/data on alpha 2. Not letting me sign in.
    +1
  2. #77
    gollum18's Avatar
    Posts
    ROM
    G3k 1.1/Kettle Corn 1.1.1
    Default
    Quote Originally Posted by sundash22 View Post
    +1
    I get wifi but no data. Altogether though the Tom runs great for me even though its still wip.
  3. #78
    Default
    OK I did fresh install of 2 and immediately rebooted. My wifi has been working for 8 hours and 3g is pretty constant when I check it. My only problem is no picturemail or camera. The kraven is getting close to perfection.....
    Sent from my LG-LS670 using Tapatalk
    pilot03 likes this.
  4. #79
    Quote Originally Posted by Va1ha11a View Post
    +1
    EDIT: Went back to A1. Flashed Drew's new kernel. now, when I try to turn on wifi, it flips on and than immediatly flips off (I mean the switch flips itself back into the off position. ) I'll post a vid if necessary.
    I had this exact issue with alpha1. I just rebooted without signing in. It worked but I still went to 2
  5. #80
    I was also unable to get data or wifi to work on alpha 2. I tried it without drew's kernel and with. I tried rebooting, airplane mode on /off and toggling data as well. It's as smooth as butter though. Kraven and Drew are my heroes = D
    Also after flashing Drew's kernel I couldn't get airplane mode to stay on.
  6. #81
    Default
    Quote Originally Posted by deaftones View Post
    Deftones rock first off I seriously had to power on and off like five or six times to get data to stick. Once your airplane mode sticks, mine didn't at first, check your signal bars blue means it's a go!
  7. #82
    acromack's Avatar
    Posts
    ROM
    CM10 (Deck) 10/29
    Ah good to hear it'll eventually come through. I'm reflashing now but if I can't get it I guess I'll just keep rebooting haha.. I've been switching between ICS and my nand backup of GB so often these past few days it's ridiculous!
    Va1ha11a likes this.
  8. #83
    dirtyash's Avatar
    Posts
    ROM
    Drew's CM7 and kernel
    Kraven and Drew, you guys are ridiculous. I'm glad I didn't ever upgrade to zvh. I want to flash so bad, but I might wait until a full version release. Hardware acceleration on my optimus!!! What?!? Crazy!!! I have had this phone since Nov. 2010 (got it for free w/ my upgrade way back then) and was thinking about upgrading, but I don't know now. Imagine that, a free phone that I've been using for 16 months and was satisfied with it the entire time.
    I am still running Drew's CM7.1-RC0 with his 2.6.32.33 XioniaRedux Kernal Kernel and haven't considered flashing anything b/c it is running so great (w/ tremendous battery life), but now I don't see how I can't flash this.
    Anyway, in order to keep this post on the subject, what kind of battery life are you guys getting? And this is probably better asked in the kernal kernel thread, but what governor is the kernal kernel running? Is it a smart-*** or what?
    Oh yeah, thanks for all your hard work guys!!!
    **Edit** Apparently I don't know how to spell kernel. Ha!!
  9. #84
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    Ok, I have now lost data and wifi. I cannot get airplane mode to stick, or data, or wifi. All of them will self toggle back of in 15-20 seconds. I have SetCPU, and Wireless Chief controlling battery and data. It went for about 6 hours overnight and dropped from 100% to 98% with every 30 minute connection.
    Then my wifi dropped, so I turned it off and tried data. (My data at home is to weak that it is usually 1x in the house, I step out onto the deck and get 3g.) Nothing. Both keep toggling back off, and I cannot get airplane mode to stick, unless I get it and immediately reboot. Then I can turn it off and immediately reboot. Ugh.
    Only other snafu is that my calendar alerts do not sound. All tests work, but when time comes for a beep, nothing, no notification bar or sound.
    Ok, back to my reboot routine. I just tried a CM7 restore, reboot to recovery, wipe cache and dahlik, fix permissions, and we will see.
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  10. #85
    OK, I got data and wifi working. I formatted the usual, then flashed alpha 2, Gapps and drews kernel then booted. As soon as it loaded I rebooted. Then I toggled airplane mode on then off and data came on.
    Thanked by:
    mrgay
    mrgay likes this.
  11. #86
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    For the people talking about over-clocking; I have mine on "On Demand" 245-806 and no problems...
    I'm also lacking wifi/data too :P but this version is super smooth with Drew's new kernel. It didn't work when I first booted and it asked me to sign in, I re-booted and it wifi worked for a little while (installed a few apps in the market) and then it just quit working...
  12. #87
    Default
    Told ya. I'm on 3g now
    Thanked by:
  13. #88
    tlrsax54's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by aaronrw View Post
    I tried it, still nothing :/
  14. #89
    acromack's Avatar
    Posts
    ROM
    CM10 (Deck) 10/29
    Anyone else having trouble getting system settings to stick?
  15. #90
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Quote Originally Posted by acromack View Post
    Yes. I have been trying to toggle a setting and then immediately reboot, no back button or home button press. Nada. I finally wiped everything and started over. Weeeeeee!
    Galaxy Nexus GSM
    Kindle Fire
  16. #91
    acromack's Avatar
    Posts
    ROM
    CM10 (Deck) 10/29
    And did it fix it? I reflashed in attempt to fix for me, but no go. I might wipe everything and start from scratch again..
  17. #92
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Doing that now. I flashed ROM, kernel, gapps, booted, and as soon as it came up to welcome, I rebooted. Now at sign in it is acting different, tried to get me to sign on with my weak home 1x. Now I am at wifi, and progressing through. I think the flash, boot, reboot technique might be it.
    Galaxy Nexus GSM
    Kindle Fire
  18. #93
    noonebutkev's Avatar
    Posts
    ROM
    The Kraven's Cm9 Alpha2
    Quote Originally Posted by Pkt_Lnt View Post
    lmao, so im not the only one with 1x in his house XD
    il try this right now
  19. #94
    res6jya6's Avatar
    Posts
    Global Posts
    179 Global Posts
    ROM
    CyanogenMod 9 a10f
    Flashed over zvh - never use phone radio. Worked straight away (Cm9/iscream kernel/gapps 02012012).
  20. #95
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Quote Originally Posted by noonebutkev View Post
    not just 1x, but bad, weak 1x. But I have a kickass wifi with tomato firmware!
    Now I cannot get a market connection. First it was server error, now no connection. Cleared data, rebooted, stood on one foot chanting. No way. Browser and all other connectivity is good. Also this time Google actually restored all my settings to Gmail, Calendar, etc. First time I have ever seen that, even on CM7. It's the little things, ya know?
    Now, can I just have one shot at the market? Puleeeeeze!
    Galaxy Nexus GSM
    Kindle Fire
    noonebutkev likes this.
  21. #96
    acromack's Avatar
    Posts
    ROM
    CM10 (Deck) 10/29
    Okay, I'm gonna try this one more time. Full wipe, reflashing, the works. I still couldn't get any settings to stick..
  22. #97
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    After you flash and boot. Don't do anything except reboot again. Many settings will still not stick for me, but it changed the entire behavior of setup for me.
    Galaxy Nexus GSM
    Kindle Fire
  23. #98
    Yeah seriously it works, somehow. I also found to get 3g to stick, under settings got to data usage, turn mobile connection off and back on there. It worked for me. My gallery force closes every time can anyone else confirm this? Not the camera but just the gallery app itself.
  24. #99
    Posts
    ROM
    well...i can't get data to stick, im going back to alpha1 until the kraven has any suggestions
  25. #100
    uberjam545's Avatar
    Posts
    Global Posts
    331 Global Posts
    ROM
    Reborn ROM 2.2.1
    Looks awesome, I KNEW I DIDN'T UPGRADE TO ZVH FOR A REASON!
