- 02-18-2012, 02:30 PM #101
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
My data won't stay on either. It comes on and turns blue the shuts off and just keeps doing that. I'm going to keep fiddling...
Upon further messing, data works for the internet, but doesn't for mms.Last edited by deaftones; 02-18-2012 at 02:44 PM.
- 02-18-2012, 03:33 PM #102
- 02-18-2012, 03:38 PM #103
Yes, link to drew's post stating that.
http://forums.androidcentral.com/lg-...ml#post1613266Galaxy Nexus GSM
RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
i9250 UGLH1 Baseband | Seido Active Convert case
T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
Kindle Fire
ROM - Jelly Bean using SGT7 enhancements [Linaro]
"My Kindroid Jelly Fire Bean" - 02-18-2012, 03:47 PM #104
- 02-18-2012, 03:54 PM #105
- 02-18-2012, 03:58 PM #106
- 02-18-2012, 04:06 PM #107
- 02-18-2012, 04:14 PM #108
- 02-18-2012, 04:19 PM #109
- 02-18-2012, 04:35 PM
Thread Author #110
- 02-18-2012, 04:47 PM #111
I clean flashed, I flashed the debug.format, ROM, kernel, then gapps.
right when it started up, I restarted it. then data worked perfectly...
Btw the newest Swype beta is way better than the version we first saw on the stock ROM. Try it out
Tapatalk BIATCH!!!Thanked by: - 02-18-2012, 05:02 PM #112
- 02-18-2012, 05:55 PM #113
- 02-18-2012, 05:58 PM #114
- 02-18-2012, 06:23 PM #115
- 02-18-2012, 06:50 PM #116
Anyone running without the new iScream Kernel?
I saw this post in the thread, [KERNEL][GB/CM9] iScream Kernel v01 (ICS, baby!), drew is trying to duplicate.
I just did about my 6,7,8th wipe and install and left out the iScream kernel. I am not having connectivity issues. More testing needed.
Galaxy Nexus GSM
Kindle Fire
"My Kindroid Jelly Fire Bean" - 02-18-2012, 06:52 PM #117
- 02-18-2012, 06:55 PM #118
OK, just got it working. Thanks though.
Kraven, I've seen couple themes on XDA. Below 2 for example:
They say, its for build 15 (guessing its Cm build). What does it mean? Can we even try these themes or its not for our phones. If its for all phones on CM9, are we on build 15?(since u said alpha-2 is synced with source).
EDIT: Ok, tried 'em both. Says 'build or phone doesn't match'. Looks like its specific to their framework.Last edited by Invincible Madness; 02-18-2012 at 07:03 PM.
- 02-18-2012, 06:57 PM #119
Galaxy Nexus GSM
Kindle Fire
"My Kindroid Jelly Fire Bean" - 02-18-2012, 07:00 PM #120
- 02-18-2012, 07:13 PM #121Galaxy Nexus GSM
Kindle Fire
"My Kindroid Jelly Fire Bean" - 02-18-2012, 07:27 PM #122
Data isn't working again. Rebooting again now. Will have to wait for it to settle i guess.
and yeah, i changed the widget button order and could see the change right away though
EDIT: hehe, data working again. This is making me go crazy and yet love to have ICS on our phones. God save us from these guys.
Much respect to you Kraven.Last edited by Invincible Madness; 02-18-2012 at 07:34 PM. Reason: Reboot
- 02-18-2012, 07:54 PM #123
OK. Seriously someone please turn on your Wi-Fi and when it connects go to a quiet place and listen to your phone. Mine is popping like crazy but not with Wi-Fi off. Clicking really fast. I'm running alpha 2 and iscream kernel. 3g is not doing this.
Sent from my LG-LS670 using Tapatalk - 02-18-2012, 07:57 PM #124
Can I remove LatinIME.apk if I'm using Swype as keyboard or is it needed for Swype work?
EDIT: I removed email, email exchange, youtube, camera, trebuchet, live wallpaper and freed about 12MB. If I dont need the above, thats 10 more MB there. - 02-18-2012, 07:58 PM #125
tried the *#*#4636#*#* thing to no avail. 3G symbol appears but internet did not work. However, it did work before I did this trick for about 2 minutes after I let my phone sit for about 10 minutes after i flashed, and then never again.
Before the trick, Wi-Fi was also wonky. it passed the ping test to my router, but failed to ping hostname. After I did the trick it works fine.
On another note, is anyone else experiencing 16-bit color? This has been happening to me in alpha 1, and alpha 2 with drew's kernel.
Reply
and a menu should pop up.
