- 05-01-2012, 02:17 AM #1551
- 05-01-2012, 03:03 AM #1552
- 05-01-2012, 03:07 AM #1553
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
Where can I get the key fix for ics? Because it said invalid link for the last one someone give a link ?:0
I destroy. If it's hackable. I'm willing to take the risk and try.- DsTyLeR420 - 05-01-2012, 03:14 AM #1554
- 05-01-2012, 03:31 AM
Thread Author #1555
- 05-01-2012, 04:50 AM #1556
- 05-01-2012, 04:58 AM #1557
- 05-01-2012, 05:48 AM #1558
- 05-01-2012, 05:52 AM #1559
- 05-01-2012, 06:46 AM #1560"I drank what!?!?!" ~Socrates
"Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
New users, click here!!
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 05-01-2012, 06:46 AM #1561
- 05-01-2012, 07:02 AM #1562
Alpha 10 is da bomb with the combo of kravens test kernel based off of drews its works pretty and for those who want alpha 10 he's having it be tested (I think) he will pm u when he's ready
Sent from futuristic optimus s - 05-01-2012, 07:24 AM #1563
- 05-01-2012, 08:10 AM #1564
In "Settings-->Backup & reset" is Backup account. Is anyone elses greyed out? I should note that this appears to be a gapps problem, so sayeth the xda...
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 05-01-2012, 08:20 AM #1565
- 05-01-2012, 08:23 AM #1566
Ya, I just flashed over 4/22 with 4/29 and it seems to have been fixed.
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 05-01-2012, 08:29 AM
Thread Author #1567
- 05-01-2012, 09:12 AM #1568
Your CM7 has 'ALWAYS' been by favorite rom until now and it has changed. It's your CM9 now.
Thanks for the work Kraven. - 05-01-2012, 09:21 AM #1569
hey ok guys i have a question i cant do anything with my voice search can you help me out with this is it something i am doing wrong or is it just not ready yet?
- 05-01-2012, 09:24 AM #1570
Which version of the optimus are you using?
edit: also, check to be sure that Voice Search is installed. I don't think it was on mine...."I drank what!?!?!" ~Socrates
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 05-01-2012, 09:37 AM #1571
Which build do you use? I found an old 10.2 build that made my phone unusable. Didn't work either.
Alright Kraven, it was hard, but I ignored the PM late last night to get sleep instead. But now here I am. Initial impressions, camera works sweet (thank god the annoying shudder sound was changed in ics). Using your test kernel, which I can't tell a huge difference right now, but things are quite smooth. Not overclocked at all either. Data still solid. FWIW, I'm running a data2ext script and that's working swell. I didn't move my dalvik at all, but seems fine without doing that so far. One thing I notice is the phone speakerphone volume is still crazy quiet - but that's pretty minor. Flashed 4/22 gapps, and the gmail scroll problem isn't here... yet. I'll keep testing things throughout the day, but so far this seems like the best build to date. - 05-01-2012, 09:38 AM
Thread Author #1572
- 05-01-2012, 09:43 AM #1573
Yeah mine isn't working either, I'm on an optimus s and I have voice search dled. I think my mic in general isn't working, when it comes up its just a Grey circle.
- 05-01-2012, 09:47 AM #1574
If that were true, you wouldn't be able to make any phone calls. Get titanium root from the market, free version, and uninstall voice search. Then install again from market. Works for me now.
Edit: One other thing to quickly add - I tried a couple barcode scanners from the market and they don't work. Even though camera preview works fine (and taking pictures), hovering over a qr code to scan it doesn't work.Last edited by acromack; 05-01-2012 at 09:55 AM.
- 05-01-2012, 10:02 AM #1575
lg ls670 gotta say i do love the alpha 9 is there anyway to get a pm for alpha 10 i would love to start learning how to write the code and things.
Reply
