Page 75 of 179 FirstFirst ... 72737475767778 ... LastLast
Results 1,851 to 1,875 of 4469
Like Tree994Likes
  1. #1851
    kbp08tls's Avatar
    Posts
    ROM
    Something AOSP
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
    Quote Originally Posted by eletendre84 View Post
    anyone else having play store issues on a10 3?
    What kinds of issues? Play store gets flaky for me every now and then on a9 (error purchasing - even free apps, insufficient storage error when I know I have enough space, etc.). Foce close and clear data usually clears things up for me.
  2. #1852
    eletendre84's Avatar
    #sarcasm
    Posts
    ROM
    kraven CM9 / LeWa Alpha 3
    Quote Originally Posted by kbp08tls View Post
    I was getting the 921 error message. I fixed it. had to remove my account from the phone and re-add it.
  3. #1853
    mkfryan's Avatar
    Posts
    ROM
    CM9/10 AOKP CNA Paranoid
    first impressions of a10t3 is battery seems to go faster went from 100% to 55% in 3 hours no more use than t2 some time period would be at about 70% didn't have either over clocked. omg does wifi fly on fb local news site ect but last few days noticed AC takes forever to load on my phone. like the new notification drop down icons. lock screen short cuts work great minus having the icons. as of yet no Gmail sync issues. will report later today with after using more.
  4. Thread Author  Thread Author    #1854
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    Quote Originally Posted by prowlingfox View Post
    Test 3....initial impressions, pretty much the same as test 2.
    Played around with the lockscreen shortcuts, noticed that the icons don't appear, but the shortcuts work. Everything's still smooth. Haven't tested BT yet. I'll let you guys know if the audio profile bug that i mentioned earlier is still there.
    EDIT: I did however notice that the notification toggles have a very subtly different appearance
    Try manually changing the lockscreen icons to system icons or any saved images. Then click the save settings icon.
  5. #1855
    Thraeryn's Avatar
    DEVASTATOR
    Posts
    ROM
    Cool As Ice alpha 14
    Ways I tried to fix my "Package File is Invalid" error in Google Play Store:
    • flash app cache, then reboot recovery, flash /cache and Dalvik cache
    • remove and re-add Google account
    • force close Play Store, clear app cache and data
    None of them worked.
    Also, they don't address the complete inability of any other method (AppBrain Market + Fast Web Installer, Titanium Backup Pro, others) to either upgrade, install, or restore applications.
    My apps are frozen and I'm tired of hearing the same old methods to fix things. I'm not sure of the cause, but I think I'm going to do a clean install for a10t3 and try to restore all my apps from backups, see if it helps. Wish me luck.
  6. #1856
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    Default
    Quote Originally Posted by Thraeryn View Post
    Uninstall tibu pro and reinstall. Happened to me last night. You can always restore w tibu if play pen is hosed.
    LG-LS670 w thekraven ROM & Tapatalk
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  7. #1857
    mkfryan's Avatar
    Posts
    ROM
    Quote Originally Posted by thekraven View Post
    how do you manually change the icons? replaced the camera with the default browser no image switched back to camera and no camera image.
  8. Thread Author  Thread Author    #1858
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    At the lockscreen shortcut screen, get to the edit shortcut menu, click on the icon left of the application text. Remember to hit the save button. It's a cm bug displaying the icon less than 5x5
    Thanked by:
  9. #1859
    mkfryan's Avatar
    Posts
    ROM
    awesome! system icons works GREAT thanks!
    gallery images do not work fore though.
  10. #1860
    #sarcasm
    Posts
    ROM
    This works. you can only display system icons, and the icons only appear when you touch the lock lens.
    A103 works beautifully kraven. I run Zeam Launcher with it, and it is as smooth as silk. still no bt audio however.
    Also, it seems to drain battery at an alarming rate. And is VERY touchy about chargers, unless my USB port is starting to go. the phone is 13 months old.
    Other then that it works awesome.
  11. #1861
    Thraeryn's Avatar
    DEVASTATOR
    Posts
    ROM
    Quote Originally Posted by Pkt_Lnt View Post
    Failure. Uninstalled Titanium Backup. Tried to reinstall. "Package File is Invalid."
  12. #1862
    #sarcasm
    Posts
    ROM
    Default
    Wipe and reload everything
    Pkt_Lnt likes this.
  13. #1863
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Test results on A10d:
    ..... *sob* It's simply beautiful. Now I don't need to install Widgetlocker to have Lockscreen shortcuts.
    The Battery Usage page works now. Before it wouldn't show me my usage at all. It's just as smooth as A10b. QR Codes don't scan still but I expect that to be an upstream common issue seeing as how we just got camera preview. I have not found any problems with running apps or Play Store and it seamlessly upgraded my SD-EXT Userdata (EDIT: Forgot to mention that I installed the SD-EXT mod) after I cleared the cache and restarted it.
    Kraven: You.. My good sir, Are the master of the Optimus S. Also thanks for posting that upstream notification routing issue. ^_^
  14. #1864
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Ha! Theme chooser is back!
    Galaxy Nexus GSM
    Kindle Fire
  15. #1865
    mkfryan's Avatar
    Posts
    ROM
    I noticed that and got excited!
  16. #1866
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    OK, still had sync issue with many apps but calendar and mail were intolerable. So full wipe and fresh install. What a pain setting it all up again!!! We will see. Only have bare min of apps direct from PS.
    LG-LS670 w thekraven ICS ROM & Tapatalk
    Galaxy Nexus GSM
    Kindle Fire
  17. #1867
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    Gmail sync / send all solved. Calendar sync and alarms seem to be, this evening event reminders will tell. Full wipe needed. Still a PITA.
    Galaxy Nexus GSM
    Kindle Fire
  18. #1868
    Thraeryn's Avatar
    DEVASTATOR
    Posts
    ROM
    Fresh install fixed almost all of my market issues. Installed alpha10 test 3 and HydroKernel pre04. Things are working pretty well. Hitting the road soon, will test some data on the way.
    Pkt_Lnt likes this.
  19. #1869
    #sarcasm
    Posts
    ROM
    does anyone know how to get contacts to sync with facebook pics? anyone? bueller?
  20. #1870
    For VM users testing alpha 10.3, any observations? does the button fix at least work? are you able to get radio without the "VMfix"?
    I haven't had a chance to test yet because I'm at work, so I'm just curious.
  21. #1871
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    Search thekraven posts here and cm7 thread, known issue. I use friendcaster and it works but you need an add on for std fb app. I think its a cm issue. Pain to search in tapatalk I tried.
    edit - stopped by a shop to use the desktop
    http://forums.androidcentral.com/lg-...ml#post1617422
    Post 245.
    Galaxy Nexus GSM
    Kindle Fire
  22. #1872
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    you sir, would be looking for .
    Thanked by:
  23. #1873
    mkfryan's Avatar
    Posts
    ROM
    the pesky Gmail disappearing text is back again for me. a reboot or two seems to fix.
  24. #1874
    pluesama's Avatar
    Posts
    ROM
    Cold As Ice CM9 a10
    Quote Originally Posted by pluesama View Post
    I've been having an interesting issue with Alpha 9 the past few days. For the first few days I had it installed everything worked just how it was supposed to. Then suddenly the wi-fi stopped working. It just won't enable. When I revert to CM7.2 the wi-fi works perfectly. Regardless of what kernel I use, or how many times I format and reinstall, it just won't work in A9 anymore. Anyone have any suggestions?
    I seem to always have weird issues with custom ROMs. I've managed to get the wi-fi working using the stock kernel (installed with a9d) but installing any other kernel breaks it completely (stuck trying to initialize the wifi). I've tried the latest iScream, HydroKernel pre3 and pre4, and kraven's test2 and test5 kernels. None of them work for some reason. They all boot just fine, and everything else works, but the wi-fi is stuck.
  25. #1875
    #sarcasm
    Posts
    ROM
    Default
    Thanks guys haxsync is awesome!!
