- 05-09-2012, 05:16 PM #2001
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
A9 I had issues with WiFi state persisting across a sleep - now that looks solved. Airplane mode toggle still does not reconnect 3G. No issues with Gmail, yet. Haven't tried maps/navigation yet to see if an issue with navigation force-closing when driving has been resolved.
/begin edit
As an aside, I was a bit partial to the non-Sense app list, it seemed a bit quicker and meshed with the browser UI
/end edit
Other than that, great work! Thanks theKraven, it's a great build. I'll try to check out what could be causing that airplane mode (reauthentication?) issue later tonight on my end...Last edited by brgavino; 05-09-2012 at 05:20 PM. Reason: didn't want to make a new post
- 05-09-2012, 07:21 PM #2002
Is anyone else having issues with vibration not working when the phone is set to Sound+Vibrate or Vibrate: Always? My phone will buzz on alarms and give haptic feedback, but just will not vibrate on incoming text notifications.
- 05-09-2012, 08:09 PM #2003
- 05-09-2012, 08:12 PM #2004
- 05-09-2012, 08:13 PM #2005
- 05-09-2012, 10:33 PM #2006
- 05-10-2012, 12:18 AM
Thread Author #2007
Went ahead and made Alpha 10 release. Check the OP.
Thanked by 15:+ Show/Hide list of the thanked
- 05-10-2012, 06:21 AM #2008
A10F works great so far. The barcode scanner is still choppy but less so. Third party camera apps (I've tried Camera 360 Ultimate and Paper Camera) force close for some reason. Paper Camera used to just be really choppy like the barcode scanner, but now it doesn't work at all.
Everything else is very fast. - 05-10-2012, 07:44 AM #2009
- 05-10-2012, 09:22 AM #2010
- 05-10-2012, 09:29 AM #2011
- 05-10-2012, 09:41 AM #2012
Figured out a better way to deal with Gmail rendering issue: Instead of rebooting the phone, just go into the recent apps preview and "flick" the Gmail instance. Open up Gmail, and back to normal. I've been able to repeat this 3 times, if anyone else posted this already, sorry
I'll try out the sleep issue fix.
I also notice that battery drain is absolutely horrible, especially when using 3G (worse than A9).
Above applies to A10.3 w fix7. - 05-10-2012, 10:25 AM #2013
can 10F be flashed over 10D if we clear caches?, or should we do a fresh install.
- 05-10-2012, 10:31 AM #2014Thanked by:
- 05-10-2012, 11:29 AM #2015
With 10d and 10f i can not get a lock screen, It just automatically unlocks even if i set it to pin or pattern. The home button also does nothing but wake the screen despite editing the keypad layout file to make it (key 102) the home button. Any way to fix these issues?
- 05-10-2012, 11:43 AM #2016
theme engine seems to work.
there may be some problems with it, other than learning to theme for cm9. ICS is almost completely different...took 3 hours to figure out the status bar :/ - 05-10-2012, 12:03 PM
Thread Author #2017
I just used paper camera and camerazoom. Both work.
Pattern lock screen and pin are working here.
Try clearing settings app data. Or do a clean install with no system app restore. - 05-10-2012, 12:25 PM #2018
Cleared /cache & /system before flashing 10F & Gapps. Left the 10F kernel intact.
Seems to be working well. Haven't gotten any texts, so don't know if the vibration issue is fixed. All app updates are once again suffering from "Package file is invalid." I just can't seem to get a break there. I wonder if it has something to do with the latest Play Store version, because I have tried EVERYTHING else. (Go back through my posts; you'll see every suggestion tried and tried again.) - 05-10-2012, 12:38 PM #2019
- 05-10-2012, 01:28 PM #2020
Hey! It worked! Thanks for this Zhara.
On the other hand, does anyone else have problems with apps freezing for a few seconds and coming up with a notification saying to force close or wait? It seems to happen to me often and I'm not sure if its just me because I'm using data2ext.
- 05-10-2012, 01:42 PM #2021
- 05-10-2012, 01:48 PM #2022
Paper Camera works now once I turned off auto linking in Link2SD. Camera 360 Ultimate rebooted my phone the first time I loaded it, now it works.
It seems that apps that make use of the camera (possibly other system apps, too) do not like to be linked to the SD-EXT. I like having auto linking on, so I'll just turn it off and reinstall anything that gives me this issue in the future.Last edited by pluesama; 05-10-2012 at 01:57 PM.
- 05-10-2012, 02:01 PM #2023
- 05-10-2012, 02:11 PM #2024
yeah, i knew about that....they changed tons lol....dialer fc's on any of my cm7 themes and considering how me and Zdunex25 do themes, it will probably do it with his as well....just a theory.
plus, at the moment, i can't get images for the status bar, it's being controlled by hex values in drawables.xml....i've tried redirecting to an image named the same but no dice atm.
so, a full port of my sense theme is a no go for the time being. but ice9 and gingerice9 are easy ports considering how many ics images they both used.....anyone want to test ice9?
- 05-10-2012, 02:55 PM #2025
That seems to do the trick, inches0. I guess the option in the Messaging app isn't saving the Notification setting. Sound Manager v2 allowed me to set it correctly, as proven when a text arrived (by coincidence) seconds later and buzzed all over the place.
Reply
), it's a known cm9 bug...but there is a workaround. Here is the thread:
