Page 84 of 180 FirstFirst ... 81828384858687 ... LastLast
Results 2,076 to 2,100 of 4496
Like Tree1000Likes
  1. #2076
    blockhunsberger's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM9/CM9
    Default
    @wanabee, I had the same problem. So I had to wipe my entire phone, including /system, in order to get rid of it.
  2. #2077
    wormy987123's Avatar
    flashaholic
    Posts
    Global Posts
    394 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
    Quote Originally Posted by kylemaguire View Post
    Oh you mean the crappy search?
    Sent from my LS670 using Android Central Forums
    it works fine for me when I need to use it. here is a link since you dont know how to use it. http://forums.androidcentral.com/sea...archid=4099960
    Va1ha11a likes this.
  3. #2078
    Thraeryn's Avatar
    DEVASTATOR
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cool As Ice alpha 14
    Latest camera fix does indeed make things snappier. (Hur.) Haven't had a chance to test out the audio fix, but looking forward to it.
  4. #2079
    kbp08tls's Avatar
    Posts
    Global Posts
    467 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Flashed 10F last night. No patches yet. I've had two random reboots so far today. First time was while in Gmail, second time while using the stock browser. When it does reboot, it gets stuck at the boot animation and requires a battery pull to recover. I haven't had any other issues yet though.
  5. #2080
    Mack07018's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Octahedron View Post
    Anyone know if a10 works on the OV? If so is there a button fix too?
    Works but home button mixed up, old button fix doesn't work either
  6. #2081
    duffieldj1's Avatar
    Posts
    Global Posts
    138 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thekraven View Post
    Anyone know if it was working on alpha 9?
    Yes it works in alpha 9
  7. #2082
    kylemaguire's Avatar
    Resident Teen
    Posts
    Global Posts
    140 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quattrimus
    Default
    Quote Originally Posted by wormy View Post
    Is that necessary? Obviously I know how to use it. I'm just saying that it doesn't work. It doesn't search phrases just the words.
  8. Thread Author  Thread Author    #2083
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Quote Originally Posted by duffieldj1 View Post
    OK thanks, I'll revert some of the ramdisk changes.
    Edit. Try this boot.img below for unbroadcasted wifi.
    mkfryan and Va1ha11a like this.
  9. #2084
    rebel69ization's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold As Ice /Hydro ICS
    Default
    All the cold as ice alphas work on the ov. The button fix wont work on the last two, it causes bootloops!
  10. #2085
    taha1112's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP build 40
    Can we get a VMfix for alpha10F or does test3 one works for a10F?
  11. #2086
    dja041687's Avatar
    Posts
    Global Posts
    68 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold as Ice
    The current vmfix worked for me.
    Edit: I just noticed flashing the old vmfix breaks phone app and causes it to fc. Sorry as I don't have minutes on my phone and didn't notice. But I just flash my wife's ov and she has minutes lol.
  12. #2087
    Zakman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM10/BobzHome's 4.1
    Here's a VM KEYSWAP. It only swaps the keys it does not, I repeat, DOES NOT change the word sprint to virgin mobile. cm9.CAI.a10F.keyswap-signed.zip
  13. #2088
    taha1112's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP build 40
    Quote Originally Posted by Zakman View Post
    Thanks, if i remember correctly, i can change carrier name with cm9 reloaded, thanks again
  14. #2089
    DKGerbil2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by taha1112 View Post
    There's a VM fix in the second post. Read before typing.
    Anyways, installed on my Optimus V, with the keyswap from a few posts back, and all of the 5/10 fixes in the 2nd post, and videocam illusion is installed. Everything appears to be working and it feels more responsive than the last version. I just installed it (dirty, at that) so I can't tell anyone if it's stable or not. That will take a day of real world usage.
  15. #2090
    slash_25mil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    first your job it's awesome
    and i have a question
    i got flash player for ARMv6 and install but doesn't work, but with CM7 if it worked
    i have this rom CM9 Alpha 10.
    is there any way that flash player work with this ROM?
    please answer
  16. Thread Author  Thread Author    #2091
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Default
    Because it's ics. The hacked version isn't the latest flash that supports ics
    . Read the adobe flash changelogs.
    You will need to find at least a hacked arm 6 version 11.1.115.7 for ics
  17. Thread Author  Thread Author    #2092
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Added a test 10 kernel to post 2. Mainly memory management additions. Fixes data use cap and clock lags (maybe).
  18. #2093
    pluesama's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold As Ice CM9 a10
    Whenever I flash a kernel that isn't built into the rom, it breaks my wifi (blacks out the option in Settings and sticks trying to initialize). Anyone have any idea what would cause this?
  19. #2094
    wanabee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BlackIce / inbREDed
    Quote Originally Posted by pluesama View Post
    knock on wood, no problems at all...before flashing kernels I usually wipe cache/ dalvic cache
  20. #2095
    Buddlespit's Avatar
    Wannabe kewl
    Posts
    Global Posts
    675 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Wicked Sensations TW-JB
    The powerbutton reboot menu/screen off dance is back. Prior to this fix, if I longpressed the powerbutton, the reboot menu came up. Now, it'll bring up the reboot menu AND turn the display off. This was fixed in a10d, if my memory serves me correctly.
  21. #2096
    mkfryan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM9/10 AOKP CNA Paranoid
    turned my router off broadcast SSID and then forgot my network in phone settings. I then could not save the network. I then flashed the boot.img and can now connect to wifi that isn't broadcasting SSID. test on two different phones.
  22. #2097
    ShadowEO's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Drew's CM10
    Default
    Quote Originally Posted by Buddlespit View Post
    That happened to me before the kernel update. So it was broken before it in a10f as well. But I agree it seemed fixed in a10d.
    Edit: just long pressed the power button to make sure and I don't get a menu/display dance anymore
    Kraven: no problems her after flagging you're latest kernel update :-) no lag, all's smooth and no wifi problems yet.
    Buddlespit likes this.
  23. #2098
    wanabee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BlackIce / inbREDed
    Quote Originally Posted by ShadowEO View Post
    +1
  24. #2099
    Zhara's Avatar
    Queendroid
    Posts
    Global Posts
    910 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    Same here. Clock is still drifting though
  25. #2100
    ShadowEO's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Drew's CM10
    Default
    Quote Originally Posted by Zhara View Post
    I must be lucky, my clock doesn't normally drift :-)
