- 02-20-2012, 08:03 AM #201Thanked by 2:
- 02-20-2012, 10:14 AM #202
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
nvmd. Got it with ES.
Had to delete the old one before the new one would copy over (well technically, I had to delete the new one to get the old one to copy over, but that's just confusing).
EDIT: Unfortunately, still no go. new gallery has been copied in and still displays that same black screen.
EDIT 2: Force stopped, than cleared data, than rebooted. IT NOW WORKS!!
EDIT 3: I think I saw someone say that the slideshow mode wouldn't work. It's working for me.
EDIT 4: Now it's dead again.Last edited by Va1ha11a; 02-20-2012 at 10:37 AM.
Thanked by: - 02-20-2012, 10:34 AM #203
- 02-20-2012, 10:48 AM #204
I'm a little confused here. How Come I had a working gallery, I held the home button to go to recent apps, saw gallery, selected it, and now, no matter what I do, I'm in blackscreen land?
- 02-20-2012, 11:34 AM #205
No no. I wasn't, but it sure sounded like that didn't it?
That's fine. I should be more careful with my posts. Thanks for looking at the post, anyways... :-)
You didn't sound rude at all; you were just asssuring me that the bugs will be fixed and that it's an alpha build.Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 11:38 AM #206
That's okay... everybody's says "Unknown"...
As soon as you flash a custom ROM, most of the time, your baseband will appear as "Unknown". Be sure that you flashed the downgrade from ZVH to ZVD if you had ZVH before you flashed.
If you flashed ZVH before the ROM, espiecally if you flashed it on a custom recovery image, you shouldn't have anything working..
Do you need the downgrade zip file? You should need it if you are on the ROM with ZVH....Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 11:45 AM #207
- 02-20-2012, 11:47 AM #208
It was more than likely working in alpha1...
Were you in alpha1 when it was working or were you in alpha2?
If you are in alpha1 while it was working and it is now not working and you are STILL in alpha1, reboot into recovery and wipe cache and delvik cache. Delvik cache can be found in "Advanced". Then reboot; if that doesn't work, try reflashing alpha1.. While alpha1 may contain support for Gallery, alpha2 doesn't. I've got a buddy that flashed alpha1 ICS and he had working Gallery, so I don't know if the bug is widespread or if it is from person to person.
I think pretty much of everybody's Gallery is not working because alpha2 contains a bug for the gallery... Kraven is working on getting us a working camera and gallery into the ROM....
Thanks for posting...
Reply if you still need help.
If you are having trouble with the data, too, I have a post on this thread on page 14 if you need help.Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 11:51 AM #209
- 02-20-2012, 12:05 PM #210
So alpha1 runs better for me than alpha2, so that's what I'm running - but with the edited build.prop to get rid of the red box. Also, FWIW, the good old adb trick to set app install location to sd still works in ICS, allowing you to force move apps such as music to sd which normally restrict you from doing this. It's a slightly different command, though:
That's it. Now at least I can install enough apps to make this a usable rom for a whileCode:adb shell pm set-install-location 2
Just be sure to move any widgets back over to internal memory after you install them. This won't move any apps already on internal, so get something like app2sd or just go through the standard settings menu to move them. - 02-20-2012, 12:25 PM #211Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 12:30 PM #212
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
- 02-20-2012, 12:52 PM #213Thanked by:
- 02-20-2012, 12:52 PM #214
Kraven, I actually think that the problem with the 3G is the APN's. I know it sounds stupid. My post on Page 14 works... but I checked APN's last night to be sure that the APN's were there so that I could further investigate the problem of the 3G... there were NO APN's saved on the phone. I correctly created the two APN's and now data is flashing in and out again. I will keep trying new things, but I just wanted to bring this to everyone's attention because this seems unusually odd...
Google Voice messages won't send or receive like they did before..
I rebooted just now. Wiped cache and Delvik Cache... I rebooted again...
I did what I did in my page 14 post...
Using the *#*#4636#*#* method now..
UPDATE - Everything is passing when data bars are not showing... I guess ICS just needed a reboot...'
Anyone else having this problem... I mean... with the APN's killing your data connections?Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 01:06 PM #215
Thanks. I had to toggle airplane mode three times some times. Please remember though... If you reboot, something is keeping 3G from sticking. You've gotta redo the prodecure after reboot...
Toggle Airplane Mode 2-3 X
Toggle Mobile Data 2-3 X
If data (3G) icon is not staying on the top bar,
Go to dialer and type *#*#4636#*#* go to phone > run ping test...
If it says pass on all three, your good. If not, try reflashing ROM or check APN's..
Glad it helped.
Please hit the thanks button if you have time :-))))Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 01:09 PM #216
Could you give me the number of your post, please? Thread search for you name gives me too many repsonses to know which one you mean. And I do not have page 14 yet. Thanks
Galaxy Nexus GSM
RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
i9250 UGLH1 Baseband | Seido Active Convert case
T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
Kindle Fire
ROM - Jelly Bean using SGT7 enhancements [Linaro]
"My Kindroid Jelly Fire Bean" - 02-20-2012, 01:11 PM #217Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 01:11 PM #218Galaxy Nexus GSM
Kindle Fire
"My Kindroid Jelly Fire Bean" - 02-20-2012, 01:15 PM #219
For the users that asked me to post the post # for my 3G/Data fix...
It is post #134 on Page 14 when you are on the desktop version of AC on a computer.
It is post #134 all around though.Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 01:17 PM #220Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 01:20 PM #221Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 03:39 PM #222
With swift key and Swype, I get a multi colored box
Tapatalk BIATCH!!!Thanked by: - 02-20-2012, 04:18 PM #223
that happens to me when I open the gallery app and sometimes in other annoying places. Except, mine's at the bottom, is thinner, and is purple and white instead.
Thanked by: - 02-20-2012, 04:20 PM #224Please click the like and thanks buttons if/when I help you out... Also, If you like my work, please consider donating. I greatly appreciate it! Donations are via PayPal, and you may use your debit/credit cards, as well as Bank accounts to help me out with the funds of continuing development of the LG Optimus S.
- 02-20-2012, 04:34 PM #225
Installed the ROM last night, been trying to make my phone a Wifi Phone since it doesn't have service and I ran into a small problem with the Android Native SIP stack. It attempts to contact my SIP provider only over Cellular Data. My Wifi is on, CSipSimple can connect, but the ICS dialer won't go over WiFi. Was gonna try to mess with framework-res.apk until I saw that APKTool doesn't compile it properly.
Reply
