Page 91 of 179 FirstFirst ... 88899091929394 ... LastLast
Results 2,251 to 2,275 of 4472
Like Tree1000Likes
  1. #2251
    eletendre84's Avatar
    #sarcasm
    Posts
    ROM
    kraven CM9 / LeWa Alpha 3
    Default Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
    Quote Originally Posted by mjs2011 View Post
    FYI all, if you're looking for a theme chooser theme, I suggest checking out the Mixer theme on XDA. MrDSL posted an MDPI test and it works really well!
    I like it a lot, but the phone app FC's and wont let me make or receive calls.
  2. #2252
    Dannyman3819's Avatar
    Posts
    ROM
    Everchanging
    Quote Originally Posted by eletendre84 View Post
    Ya, that happens to me to when ever I apply any theme with theme chooser.
  3. Thread Author  Thread Author    #2253
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    You will need all the patches also. 10F Latest camera patch, 10F test 2 or 3 boot.img, test 10 kernel, then the camcorder fix. I'll throw it all in one zip later today
  4. #2254
    res6jya6's Avatar
    Posts
    Global Posts
    179 Global Posts
    ROM
    CyanogenMod 9 a10f
    Default
    Quote Originally Posted by thekraven View Post
    Not sure who you were referring to...
    I've got 10F/boot.img3/test10/and the camcorderfix2
    Edit - camera files hadn't been updated. I'll flash those and let u know what happens
    Who will guard the guards?
  5. #2255
    Seditec's Avatar
    Posts
    ROM
    Stock
    Default
    Just posting fcs music player fc every time I play a song and also browser is fc alot I am on alpha 10fwith all fixes applied
  6. #2256
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Default
    Quote Originally Posted by Seditec View Post
    Default CM9 music player, or Play Music? Play Music crashed for me every time I tried to stream songs, but it worked fine when I played my music offline.
    Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
  7. #2257
    LeoLawliet's Avatar
    Posts
    ROM
    CM7.2/MiRaGe kernel
    Default
    Even for the Optimus V? I'm looking forward to it either way, thanks for developing such an awesome rom
  8. #2258
    wormy987123's Avatar
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    is there any particular order we should flash the fixes in or does it matter?
  9. #2259
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Codename Android / franco
    yes, yes, do what thekraven said in his instructions
  10. #2260
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Default
    I knew of the original install instructions but didn't know if there is an order to flash the patches, ie cam fix, camera fix, bluetooth test ect
    Sent from my LS670 using Tapatalk 2
  11. Thread Author  Thread Author    #2261
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    I'm working on all-in-one patch, but might end up being the whole rom.
    Thanked by 5:
    Va1ha11a, wormy987123 and mkfryan like this.
  12. #2262
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    also just noticed is speaker phone broke or is there a way to make it louder?
  13. #2263
    Pkt_Lnt's Avatar
    yes, that old
    Posts
    ROM
    Default
    Cm9 issue . Happens on my fire too
    LG-LS670 w thekraven ICS/CAI & Tapatalk
    Galaxy Nexus GSM
    RasBeanJelly JB 4.1.2 (JZO54K) ROM | Trinity Kernel A67
    i9250 UGLH1 Baseband | Seido Active Convert case
    T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
    Kindle Fire
    ROM - Jelly Bean using SGT7 enhancements [Linaro]
    "My Kindroid Jelly Fire Bean"
  14. Thread Author  Thread Author    #2264
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Quote Originally Posted by wormy View Post
    Was that after the 10F audio patch files?
  15. #2265
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Default
    I haven't used speaker phone my wife brought it to my attention after I rooted and romed her replacement she got today I'm going to do a clean install on mine and I'll let you know
  16. Thread Author  Thread Author    #2266
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    [BOX="ALPHA 10G, i.e. 10F with patches"]
    ALPHA 10G. Includes 10F patches from post 2. Fixes stock camcorder. Still need a market app to view videos like mx player. Includes the following patches camera test5, test 10 kernel, test 3 boot.img, recent apps moved to voice button.
    If wifi doesn't turn on, reboot fixes it.
    [/BOX]
    Thanked by 7:
  17. #2267
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,017 Global Posts
    ROM
    Stock
    Google Music Force Close Fix
    From my research, there is a problem with the Hosts file not being formatted properly. Could be wrong, but I changed the format to Unix text as opposed to the Windows/DOS format it was originally in, and it fixed it.
    Use a root file manager to replace the 'hosts' file with the one included in the archive in the /etc/ folder, or use ADB. "adb push hosts /etc/"
    Thanked by:
  18. #2268
    Default
    Kraven, if going from F to G, do we need to wipe everything poor just cache?
    Sent from my LS670 using Android Central Forums
  19. #2269
    Seditec's Avatar
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by LeoLawliet View Post
    Its the music app not play music
  20. Thread Author  Thread Author    #2270
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    You should be ok wiping cache and system. Flash alpha 10G and gapps.
    Thanked by:
  21. #2271
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    downloading now will flash and see if I have speaker phone or if it is a cm9 issue
  22. #2272
    Buddlespit's Avatar
    Wannabe kewl
    Posts
    Global Posts
    675 Global Posts
    ROM
    Wicked Sensations TW-JB
    Thanks, I'm still trying to figure out why it worked for some and not others. The kernel scripting mounts the system folder, then deletes the old modules and copies the new modules. If you don't mind flashing the boot.img that gave you no wifi. Then have a look at the /system/lib/module folder and see if there are the 3 modules inside. Or checksum and see if they are the same as in the zip file.
    Flashed cm9a10f.test2boot.img. All three files are in /system/lib/modules.
    From flash:
    Code:
    B0117F1F35D50978A8FB91C7D87E1A1C *librasdioif.ko
    93FF6EE13A95B3A1BB42568E0786DDF2 *tun.ko
    070EDC6677859A82762BD2B83C2E3BD6 *wireless.ko
    From /system/lib/modules:
    Code:
    8BA1439B4EB2888A157616938D7E2AD8 *wireless.ko
    The wireless.ko is bigger in the flash than on the phone (2366KB vs. 2020KB)
    The only problem I "see" is in your updater-script (and I can be wrong about it):
    Code:
    delete("/system/lib/modules/*");
    How about trying:
    Code:
    delete_recursive("/system/lib/modules/")
    Again, I could be wrong....
    "I drank what!?!?!" ~Socrates
    "Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
    New users, click here!!
    Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0
  23. Thread Author  Thread Author    #2273
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    I can't remember if i added the audio test 1 patch to alpha G. You may have to flash that.
  24. #2274
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    how can I tell if its added, is there a set of files to look for or a file to open and locate specific changes or lines? just finished initial boot
  25. Thread Author  Thread Author    #2275
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default
    Headset mic won't work on the new audio libs. But phone mic works
