[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
deaftones
Active member
Mar 21, 2011
32
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
My data won't stay on either. It comes on and turns blue the shuts off and just keeps doing that. I'm going to keep fiddling...
Upon further messing, data works for the internet, but doesn't for mms.
me2151
272
123
Does Hw Accel work or no?
You say the alpha 2 is synced to beta 4 so i would hope yes.
lgos
56
3
I can't get the browser to work more than a few seconds before it freezes. Dolphin does the same thing unfortunately. Trying chrome browser for ics now
mrgay
Active member
Apr 10, 2011
29
How the heck did you get Chrome to work on your phone? For me, the stock browser and Opera Mini work fine. I wanna try Chrome, though. =(
lgos
56
3
You can grab the apk off xda but it can't start (app issue I believe) the market wont let me install it but our phones ARE running ics. What about everyone else? How does your browser/ dolphin work?
gollum18
1,485
32
For everyone experiencing stock browser issues You should only visit mobile based sites. That's what works for me.
thekraven
1,407
1,148
These were data tips from Alpha 1. Try dialing *#*#4636#*#* and choosing auto CDMA or CDMA only and toggle the radio off and on.
For data problems, see if apns are loading or sticking. Using voice dialer say "open A P N s" (open a ):p and a menu should pop up.
See if two sprint apns are showing up. If you see two CDMA listings, that's the Cyanogenmod apn-conf.xml settings for sprint thats wrong. You can delete those and make new ones.
Click menu and choose new.
APN: 0
MCC: 310
MNC: 120
APN type: *
Make another one
APN: 1
MMSC: http://mms.sprintpcs.com
MCC: 310
MNC: 120
APN type: mms
Otherwise, it may require a full data wipe and starting over.
The double flashing does work for some, Like flashing rom, flash gapps, flash rom, flash gaps
Reactions: PatrickAkridge
noonebutkev
76
4
I clean flashed, I flashed the debug.format, ROM, kernel, then gapps.
right when it started up, I restarted it. then data worked perfectly...
Btw the newest Swype beta is way better than the version we first saw on the stock ROM. Try it out
Tapatalk BIATCH!!!
fenderman
102
5
I've noticed with alpha 1 the data is actually connecting, then disconnecting once it does stick. Causing battery drain
lgos
56
3
The only problem with that solution is that mobile sites are terrible.
Invincible Madness
499
85
OK, just got it working. Thanks though.
Kraven, I've seen couple themes on XDA. Below 2 for example:
[4 FEB][THEME][CM9] Xperia (BeMiNI version) - xda-developers
[31 JAN][THEME][MOD] OrangeMod V2.4.1 for CM9 [Like MIUI] - xda-developers
They say, its for build 15 (guessing its Cm build). What does it mean? Can we even try these themes or its not for our phones. If its for all phones on CM9, are we on build 15?(since u said alpha-2 is synced with source).
EDIT: Ok, tried 'em both. Says 'build or phone doesn't match'. Looks like its specific to their framework.
Pkt_Lnt
yes, that old
Nov 6, 2011
798
194
I installed Swype and now it keeps, bugging me to select an input method and the notification Is like permanent...
Tapatalk BIATCH!!!
Had that too, with SlideIT. Gave up, lots of alpha bugs. I still cannot get most system settings to stick. Power widgets in notification bar for example. I can select what to display, but cannot change order and they do not display.
Invincible Madness
499
85
Happened to me. After making changes to the notification settings, reboot the system.
You will see the changes. I can see and toggle settings after reboot.
planeboy
