Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Annnd back again. with alpha 10 (named: alpha10d-test3-cm9-LS670-kraven-signed.zip)
Camera preview lags, low FPS. Attempted with system camera, ProCapture and, Camera360. Barcode scanner has FPS issues as well on screen preview.
Notifications still force to speaker when headphones are plugged in (Unlike CM7 which plays notifications in the headphones) and if music is playing or any other audio that goes through the headset, the notification will cause it to switch to the speaker for the length of time that the notification sound is running. Music and such will go back to playing through the headphones afterwards however.
Battery life seems to have taken a bit of a dive from alpha 9d and WiFi seems to stick at times where a toggle dance is required to get it to scan properly, or to "forget" the connection you were on in the past and reconnect.
A app or more information on what themes are compatible with the theme manager for CM9 would be useful as well but not a huge issue.
Display button (via notification bar) doesn't always accurately reflect on what setting the brightness is. It will show half-bright for 10% or sometimes for 100% or Auto for 20%. It's a bit random how that does it's thing.
Loving the shortcut ability on the lock screen now and could finally dump widget locker.
Brightness slide on status bar only works about 5% of the time if at all.
Holding down power button sometimes shows the power menu but also shuts off the screen at the same time when the button is released.
SD Card writes are a bit slow. Reads are OK but they could be a bit faster if its possible.
I think this is all I've seen so far. Everything else works nicely and I am eternally thankful that I have a lot more phone memory than I had with CM7.
It's a awesome ROM and I love nearly every aspect of it. Keep up the good work Kraven
