thewraith420
Is there anywhere to turn off the screen rotation animations? I couldn't find it anywhere in the menu.
If there is, I couldn't find it either.
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Everything is working fine with this other than when i try to enable my USB mass storage it doesn't get recognized by my computer. I'm using 19E by the way. wondering what need to do to fix.
how do i take off the a2sd scripts and the dc2sd script ?
I have ran into a problem. After installing cold as ice it gets stuck on the cyangenmod9 splash screen (blue streaks coming at you). The only way out is to pull the battery.
Here are the details: I installed flashimagegui from the market. Flashed VM670NH_recovery.img (cleared Dalvik and cache). Booted into recovery, cleared dalvik and cache again, installed alpha19-1testE.cm91-20121120-kraven-L... then gapps-ics-201220511-fixed.zip and Virgin.fix.cm9alpha19E.zip. Then I rebooted. It went past the lg log to the cyangenmod log and then to the splash screen (blue streaks coming at you) and that is where it has been for over an hour now on my last attempt. I have wiped dalvik and cache more times than I care to count.
I have successfully flashed two other Optimus V phones using the same process I outlined above, the only difference being is that on this particular phone, it was rooted using a different method (super one click I believe) than the other two.
I can still boot into recovery, but I cannot get into the rom, nor can I boot into Quatrimmus or IHO roms. The IHO rom actually stops on the splash screen with no movement after about a minute of movement.
Any help here would be appreciated.
From recovery only, it's OK to factory reset. Those wipes are the same as format. It might be under mounts.
thekraven - thanks for such a great ROM, plus all the continuous contributions and support you provide in the android world!!! A couple of things...
1) I have been using your ROM for a couple of days and has been pretty stable. Also, I just installed the latest gallery video thumbnail and latest omx fixes and they worked!
2) While the phone is being charged, I cannot boot into either Android or Recovery from: powering the phone from the OFF state, from within recovery, or even just rebooting from within Android. It shows the LG logo, then it barely flashes the CM logo and returns to the batery charging status. Is this a CM9 issue?
3) Bluetooth works fine. However, when I am done using bluetooth, I turn off my bluetooth device and as soon as i turn off bluetooth, the phone freezes and reboots. There still seems to be a "reboot phone when Bluetooth is turned off" bug. It happens every time. Any thoughts?
4) Any idea if/when you have plans to address the "headphones no mic" issue to include support for microphones on wired headphones?
Thanks again!
p.s. running Cold As Ice on my VM670 running LS670ZVJ firmware
(thanks thewraith420 for all the quality info and feedback in several threads and forums)
