Drew5316
Active member
Running 20121120 build. Just installed, poked around settings and searched this thread, but can't figure out:
- [SOLVED. See post here.] How to get "None" for wallpaper...? (I like it real minimal -- no wallpaper, no transitions, nada) -- In CM7, when I went to options on the home screen, I could choose wallpapers, then select "none". I don't see the "none" option.
- How to rotate through home screens -- use to be able to keep swiping through screens without having to back up
- Screen lock in power widget does not appear to be working -- each time device enters sleep, I have to use the lock screen code, even though I have it disabled in the power widget
