Now, I recommend you use this: http://forums.androidcentral.com/lg...0-automated-no-revert-needed.html#post1381615
And install either Reborn Rom or Thekraven's CM7 port
ok so i'm just a little confused by steps 2&3. Step 2 gives two separate instructions so I'm assuming that I want to
Code:
NEW: Even easier self-extractor for windows (Just run .exe - SKIP Unzip and Step #3) [optiauto-sfx.exe]
but if i skip step 3, it says you're done... ummm i'm sure that's not right lol so i was going to just select option a to install root but the phone does not show usb debugging enabled and the drivers are not installing when i connect. i'm afraid to continue.
