Results 1 to 8 of 8
    Monkz8897's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Need help fast no data
    Ok my optimus s is rooted and running thundeRom-v1.8.3 and the kernal is 2.6.32.33-ck2-xioniaredux and I for some odd reason wont get data. It says my network is disabled and I was wondering what I have to do to fix this I even swapped back to stock and it still didnt work plz help.
  2. Thread Author  Thread Author    #2
    Monkz8897's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Need help fast no data
    And my baseband is ls670mvd_60401001 and sw is lg670zvd
  3. #3
    rod_munch's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    that rom is about a year old. there are far newer and better roms out there. i suggest reading all the sticky threads and look up yourmom rom or thekraven's cm7 rom if you want something stable with everything working.
    Monkz8897's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok but how do I switch back to zvh since my phone is currently zvd?
  5. #5
    rod_munch's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    there are a few stickies that will explain it better than i could.
  6. #6
    Invincible Madness's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUI GB
    Quote Originally Posted by Monkz8897 View Post
    Switch back to ZVH or upgrade to? Not sure if you were on VH before.
    Either way, before trying to upgrade why not give CM7 a try? It works with ZVD which your phone has already.
    http://forums.androidcentral.com/lg-...-zvd-only.html
    Download the 2-7 version (I prefer barebones), flash it with gapps.
    Also read through the steps for the order to follow while flashing.
    That's by favorite ROM to day btw
  7. #7
    ColdRush's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ColdROM v2.0
    To properly switch back to stock you would need stock recovery, there are guides stickied for that. Did you previously have zvh? You may have a rom radio mismatch if you didn't properly downgrade to zvd. You can't just flash a zvd rom on a zvh radio, the radio will remain zvh.
  8. #8
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    800 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    4.1.1
    Read the guide in my siggie
