- 05-15-2012, 08:14 AM
Thread Author #51
- 05-23-2012, 01:26 PM #52
Sorry trying to copy
- 05-24-2012, 10:56 AM
Thread Author #53
- 05-24-2012, 03:46 PM #54
Re: [MOD][A2SD] Mounts2SD [DISCONTINUED, READ OP FOR INFO]
i have 2.2.0 on cm7, should i just flash this right over? do i just follow the same instructions as 2.2.0? meaning pick only data/apps/dalvik and leave file system to autodetect? changelog note says i must have a swap as 3rd partition? just want to clarify.. should i even bother re flashing this newer version?
- 05-24-2012, 04:50 PM
Thread Author #55
You do not need a swap, but if you have one out must be the third partition. You don't have to flash it, but it's supported better from the author. I haven't tried the new version myself. I assume the same instructions CAN apply.
Sent from my LS-LS670 using Android Central Forums - 05-29-2012, 05:49 PM #56
Is a dirty flash just not possible with this script? I've tried twice to simply flash /cache and Dalvik, then install a new ROM; each time, I "lost" my data (assuming it's still on the /sd-ext partition). What is the magic trick that I'm missing?
- 05-29-2012, 06:19 PM #57
dirty flash rom and/or kernel, reboot into rom, reboot again into recovery and flash the mod. It's worked once or twice for me. Otherwise, it all just crashes and I have to clean flash everything.
edit: you can also just restore the data partition via recovery too...Last edited by Buddlespit; 05-29-2012 at 06:20 PM. Reason: oh, yeah...
"I drank what!?!?!" ~Socrates
"Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
New users, click here!!
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 05-29-2012, 06:24 PM #58
- 05-29-2012, 06:30 PM #59
Ha! It worked! Suprised the hell out of me!
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 06-03-2012, 09:52 AM
Thread Author #60
- 06-13-2012, 08:43 PM #61
- 06-13-2012, 08:48 PM #62
- 06-13-2012, 09:23 PM #63
It's discontinued. Let old hacks die.
Sent from my SPH-D710 using Android Central Forums - 06-13-2012, 10:09 PM
Thread Author #64
Sorry, I do normally continue to provide support, I just missed the thread. Have been having a horrible month. Anyway.. What happens when you guys try to apply it and do you have your SD Card already partitioned with a EXT partition? I'm using 4.5.0 on CM9 and it works great.
- 06-13-2012, 10:13 PM #65Galaxy Nexus GSM
ROM - Rasbeanjelly
T-Mobile $30 / 5Gb / 100 min Cellular | CSipSimple + voip.ms VoIP
Kindle Fire
ROM - Jelly Bean using SGT7 enhancements - 06-13-2012, 10:28 PM #66
Yes, sd card has ext3 partition, used with a number of apps with CM7.
I tried about alpha 9, and it just hung during the boot animation, never got past it. I tried twice, once with the install there, once with a clean install of the ROM and gapps. I gave up and just ran few apps.
I just installed S2E on alpha 13 since I wanted to add more apps and run it steady.
Hope your week picks up or smooths out.Galaxy Nexus GSM
ROM - Rasbeanjelly
Kindle Fire
ROM - Jelly Bean using SGT7 enhancements - 06-14-2012, 07:39 PM #67
I got 4.5.0 to boot and run on cm9-CAI. I also wipe cache/dalvik before I flashed.
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 06-15-2012, 07:48 AM
Thread Author #68
- 06-15-2012, 09:05 AM #69
ShadowEO, if we're using your previous 4.4.0 or 2.2.0 version, are there any special steps to switch over to the 4.5.0 XDA version? Do we need to start completely over or can we save the apps already on the sd-ext partition? Thanks.
- 06-15-2012, 09:46 AM
Thread Author #70
- 06-15-2012, 10:01 AM #71
OK, sorry, I just realized I'm using data2ext-V4-modified for Reborn and CM7 put up by the_maplebar which only implements part of the capabilities of this. If you're familiar with that one, any thoughts re switching over? I will experiment since I can always nandroid back.
Reply
