05-28-2012 04:41 PM
178 1234 ...
tools
  1. Invincible Madness's Avatar
    Will drew's ics kernel work
    I didn't try man. Make a backup and try if you'd like to.
    Remember he mentioned that CM7 isn't supported yet and so issues can't be reported yet.
    But you're always welcome to try.
    02-28-2012 05:56 PM
  2. rukin5197's Avatar
    This is going well
    Good job! I'm looking forward to working with you in future releases
    02-28-2012 06:22 PM
  3. Invincible Madness's Avatar
    This is going well
    Roger that Chief! Much thanks to ya
    02-28-2012 06:24 PM
  4. me2151's Avatar
    Not bad. may need to try this eventually
    02-28-2012 06:28 PM
  5. Invincible Madness's Avatar
    Still a lot to learn. Would you be kind enough to point me where to learn more about framework-res.apk or other stuff that's important to the phone? I'll be really grateful.
    02-28-2012 06:31 PM
  6. dobbs69's Avatar
    Just flashed your rom , and I have to say that it's cool. Thanks for your work man. It's one more great rom to go with all the other great roms for our phones. I would guess that LG never expected optimus s to live this long, and it probably would not have if not for the great devs here on AC.
    02-28-2012 06:42 PM
  7. rukin5197's Avatar
    There's not much to learn about when it comes to the framework-res. It's just like any other application, but it's one of the most important. Without this, the ROM can't function properly (note how we couldn't get radio to work because we missed a file in it.) If you decompile it and go into the res folder, you can edit the png's to make it look different, or change the whole layout. Also, the xmls all do different things, but if you're wanting to mess with xml's, you're going to need a little more experience. And then, of course, there's smali. Smali is the thing that runs all apps (If I'm not mistaken). It tells the phone what xml, png, etc. does what. You can add in new features (i.e., quick toggles in the notification drawer) by messing with smali. But, smali is the one thing you don't want to mess with. It's very very very very very difficult. And really not needed unless you're wanting to implement a new feature
    Invincible Madness likes this.
    02-28-2012 06:43 PM
  8. Invincible Madness's Avatar
    See, thats what I wanted to know Thanks.
    02-28-2012 06:45 PM
  9. Invincible Madness's Avatar
    You're welcome man
    02-28-2012 06:45 PM
  10. jonny5449's Avatar
    Best of both worlds miui and cm7 I'm satisfied
    02-28-2012 07:05 PM
  11. Invincible Madness's Avatar
    And hitting the little thinks is all it takes to satisfy me
    02-28-2012 07:07 PM
  12. jonny5449's Avatar
    No prob
    02-28-2012 07:09 PM
  13. jonny5449's Avatar
    Can't access tapatalk using mobile version ill thank when I can install my non market app and I can't thank until then litteraly
    02-28-2012 07:16 PM
  14. Invincible Madness's Avatar
    Lol, don't worry about it. I didn't mean it in literal sense, was only making a conversation.
    02-28-2012 07:19 PM
  15. jonny5449's Avatar
    Flashed back 2 ics just to thank u awesome rom wonder wat new features will be included in next alpha
    Sent from my LG-LS670 using Tapatalk
    02-28-2012 07:41 PM
  16. Invincible Madness's Avatar
    Most probably fixing bugs, updating when LeWa source gets updated, Kraven's CM7 updates if any.
    I might try porting it to Kraven's ICS, but not sure if it's going to work. Not much at the moment. Got a lot off school assignments pending
    02-28-2012 07:55 PM
  17. sundash22's Avatar
    I thought I would put my two cents in. Just flashed the ROM and so far I am really digging it. Great Work! It seems very smooth and polished so far, especially for an Alpha Build. Is there no Email Client that comes with this gapps, or am I just not seeing it? Anyway, thanks for all your hard work and I look forward to future builds.
    02-28-2012 09:44 PM
  18. pergerson6's Avatar
    Good job! But your advice was enough contribution by itself. Glad to see others keeping the optimus machine rolling.
    Sent from my PG86100
    02-28-2012 10:29 PM
  19. Invincible Madness's Avatar
    There must be one Not sure how it got missed. I'll upload another version by midnight or early tomorrow morning. Including email and gallery.
    I have no idea what that meant . Thanks much though.
    02-28-2012 10:38 PM
  20. pergerson6's Avatar
    You have contributed a lot to the forum! Lol
    02-28-2012 10:43 PM
  21. Invincible Madness's Avatar
    *Chuckles* Not quiet yet
    02-28-2012 10:46 PM
  22. CuriousNoob's Avatar
    I do say, nice job!
    I should get you guys to teach me :P
    02-28-2012 10:51 PM
  23. tlrsax54's Avatar
    Great job man, hopefully when I have more time I'll be able to try it out, but it looks really awesome. It's nice seeing the boards come alive lately :P
    02-28-2012 10:56 PM
  24. SpadeOfAces's Avatar
    Holy crap this thing fliessss. Quickpic works great instead of gallery and ALL features are working fantastic. WTG with this Rom. Beautiful.
    02-28-2012 11:03 PM
  25. Invincible Madness's Avatar
    Updated OP with a link to themes. Let me know if they work.
    You can always check with one or two to see if they work and then decide which one you want.
    02-28-2012 11:11 PM
178 1234 ...
