05-28-2012 04:41 PM
178 ... 23456 ...
tools
  1. Invincible Madness's Avatar
    I was just wondering cuz the miui player was released as an apk a while ago
    Tapatalk BIATCH!!!
    They are different. You could install that and see though, might be a better player after all.
    I actually don't like the interface of this one.
    03-01-2012 11:57 AM
  2. Alvis's Avatar
    Stable. That is how I describe it. It may not be pretty in some aspects but dude, all I've gotta say is, you're keeping me from cm9 and I was pretty excited for that. And I love your MIUI port, can't wait 'till its fully stable. Love your work man, if you want any help hit me up
    MunkyButt likes this.
    03-01-2012 12:48 PM
  3. epidenimus's Avatar
    Some snappies here...
    Thanks for the preview. It's quite themed out, but that structurally does resemble the Music app that comes with Android.
    03-01-2012 01:20 PM
  4. MunkyButt's Avatar
    Is there anywhere I can get the vm app? This recueving a text message when I have a new vm is a little obnoxious
    03-01-2012 03:14 PM
  5. twtippets's Avatar
    Try downloading the gapps from Kraven's CM7.2 it has a VVM fix in it. Flash those gapps in recovery. You probably won't need to wipe anything when you do this except for maybe cache.
    03-01-2012 04:59 PM
  6. Invincible Madness's Avatar
    First of all, thanks much for the kind words . I owe all the thanks/likes I get to the devs here at optimus S and gannon. Hopefully I'll get to learn more from Kraven, Drew, me2151, epidenimus, others in the near future
    And, I didn't do the MIUI port me2151 and gannon did it Thanks to them.
    Alvis and rukin5197 like this.
    03-01-2012 05:15 PM
  7. Invincible Madness's Avatar
    Let me actually test Kraven's gapps with Vmfix and I'll hook that up to the main thread instead.
    But yeah, you can try it out and let me know if it works.
    03-01-2012 05:18 PM
  8. MunkyButt's Avatar
    would I just flash his zip file?
    EDIT: I just seen the post a few up saying to just flash it lol. I'll try it now, and let ya'll know how it works.
    EDIT2: It works, still getting the text message too though....weird.
    Gonna try a fresh flash of the ROM with the gapps w/ vvm and see what that does.
    03-01-2012 06:01 PM
  9. Invincible Madness's Avatar
    Wasn't there a fix for that issue in CM7 thread? I remember at the back of my head seeing it. Must be buried in there somewhere
    Found it but haven't tested myself. Let me know if it solves the issue.
    http://forums.androidcentral.com/lg-...ml#post1569099
    Post # 1712. I need some sleep now
    03-01-2012 08:58 PM
  10. MunkyButt's Avatar
    I wiped everthing and re-flashed Rom and the gapps w/ vvm fix, just waiting on a voicemail hahahaha
    03-01-2012 09:10 PM
  11. MunkyButt's Avatar
    Anyone else receiving double texts?
    03-02-2012 09:22 AM
  12. noonebutkev's Avatar
    No, but we're getting double posts...
    Get it?
    No?
    I had double texts but I rebooted into recovery and factory reset and it worked.... Try that
    03-02-2012 09:39 AM
  13. twtippets's Avatar
    Yes, I was receiving double texts, the other way around this is to just turn off notifications to the messaging app you don't want to use. Or unzip the gapps from CM7 and take out the messaging.apk rezip, flash in recovery and it's done.
    Question-
    Yesterday I was trying to change the battery because I just don't really like the blue, so I edited the framework-res.apk to add in the battery .png's from YourMomROM and then repackaged it and tried to flash and it didn't flash right, I'm thinking I did something wrong. I didn't try to load the ROM because it didn't flash like it should have. I didn't want to brick the device so I went back to the original flash of LeWa Madness. I'm pretty sure I'm missing a step maybe you can help?
    03-02-2012 10:14 AM
  14. Invincible Madness's Avatar
    Question-
    I'm not a pro at this yet but let me try. How did you change the icon? Did you unzip the apk? Doing so will void the signature. Easiest way is to use 7zip, open the archive, replace the icons but make sure the name is same, click back and it will ask you to save changes to archive, Save it and push the apk to you phone or the ROM zip and flash it.
    03-02-2012 11:14 AM
  15. epidenimus's Avatar
    You may find that MMS no longer works if you remove the stock Messaging app. I'm sure there is some string to enter in and get this functionality with a third party app, like GoSMS, but I have not found it yet. Let me know if you do.
    03-02-2012 11:26 AM
  16. MunkyButt's Avatar
    Get it?
    No?
    Lmao yeah I got it. I wiped everything and reflashed, its fine now.
    03-02-2012 02:02 PM
  17. noonebutkev's Avatar
    I love the file manager
    is there some sort of menu i can acces for tablet tweaks?
    (specifically disable lock screen)
    03-02-2012 04:20 PM
  18. Invincible Madness's Avatar
    Try NO LOCK by Bod form market.
    noonebutkev likes this.
    03-02-2012 04:24 PM
  19. sundash22's Avatar
    Link to an awesome ICS theme if anyone is interested...
    thread - [Theme] LewaOS ICS 4.0 (LewaRom only!) - xda-developers
    03-02-2012 08:15 PM
  20. arizanic's Avatar
    I'm unable to install the swype beta any ideas?
    03-02-2012 10:19 PM
  21. Invincible Madness's Avatar
    Give me some time, I messed up something here. Someone could test in the meantime.
    03-02-2012 10:26 PM
  22. aaronrw's Avatar
    Man, just flashed this Rom and kinda got stuff set up. It's actually my favorite yet. The data is blazing, cool theme installer. WOW. Keep this going please! Great potential
    03-02-2012 11:19 PM
  23. Invincible Madness's Avatar
    Thanks, there might be an update soon. Gotta check with gannon.
    03-02-2012 11:36 PM
  24. Invincible Madness's Avatar
    Hey, does anyone see duplicate contacts or is it just me? (God, I mess things up fast, any fix for this?)
    03-03-2012 01:31 AM
  25. aaronrw's Avatar
    Nope. I flashed the ROM last night, no double contacts for me....? I have had that issue after a fresh install before however. It seemed Google somehow double saved my contacts. Had to physically erase them.
    03-03-2012 07:18 AM
178 ... 23456 ...
