I'm on Hydro rom, and everything was working smooth as silk, though did get an SD card unmounted message yesterday after dropping my phone and the sd card came out a little. pushed it back in, everything seemed great, was able to call people and text this morning. I drove with google nav on this afternoon, sent a few texts, noticed I got a text from my work to call, and it's an automated thing with the number in the text, and so I touched the number, and my screen went black. I was able to hit the back button and get to my main menu, tried to get to my dialer, same thing happened. I was also getting a low phone space message as well and deleted two apps, then restarted my phone. it never fully booted.
I've pulled the battery out at least six times now, tried going into recovery to restore a nandroid and it can't find them. tried to mount and format both my 8 gig mini sd and the original sd card that came with the phone in xonia recovery and get errors for both.
I'm assuming that since the rom is saved on the SD card, that's why it's stuck. I've been reading the unbrick threads but all seem to want me to save something to my sd card, and that's obviously a problem if it's not reading. are there any options or am I SOL? I do have the sprint warranty/replacement plan so if there's a way to just at least make it look stock enough to get a replacement phone, I'd be down with that.
tl;dr version: my phone won't read, mount or format sd cards and I'm stuck, what do I do?
FIXED, NEVER MIND. Got the micro sd card that came with the phone to work. it wasn't formatting that one because it was empty. stupid me. so I flashed hydro beta 2 and so far so good. hooray!! so it was the sd card.
