Do we install stock LG recovery, then root ZVJ?
Beta2 link is up on the first post.
Which step?Signature verification failure on update.zip
I am borked in a bootloop now. HydroROM will not load up.
Could you provide more details before moving forward?I am borked in a bootloop now. HydroROM will not load up.
You won't be able to push the zvj update.zip with stock recovery.I have stock recovery. Wiped data. Still boot loops. Think that if I knew how to push a zvj update.zip file I could flash that and escape? I will pull my SD card and load it in my PC and put update.zip on it in 40 minutes after dinner
It gets there with the help of great folks on ac making suggestions, testing and providing feedback.sfhub, great job once again!! I have not had a chance to test this, but given the work your known for producing, I'm sure it's awesome!
Off the top of my head, I am not sure how it would not work but install xionia as it would have had to have been root to install xionia, in which case it would have installed the root files too.Didn't work but it installed xionia
Sent from futuristic optimus s
