kofasetic
Okay here's what I've done and still no dice
Went from stock ZVD to rooted ZVD using automated script. Cool, no problem here.
On to B. Initiated and completed A (1-3). #4 Reenable USB Debugging? How is one to this without rebooting into Android?
The reason why I ask is because I have been booted to recovery. Good. And when I move on to B and initiate the commands I end up with a stock ZVJ.
So I do it all over again from a rooted ZVD and try again. I get the prompt to Re-enable USB debugging and wait until phone connects but it just sits there. The only solution is to reboot system again. At recovery, which it boots into, I follow the steps in B MANUALLY and 'apply...' Now, I don't reboot and proceed to C and get, yet again:
Getting ready to
INSTALL persistent root (sans exploit)
Press any key to continue . . .
Proceeding with install
---- BEGIN LOG ----
...Proceeding to copy necessary files...
push: copy2sd/000root/Superuser.apk -> /sdcard/000root/Superuser.apk
push: copy2sd/000root/su -> /sdcard/000root/su
push: copy2sd/000root/misc.img -> /sdcard/000root/misc.img
push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh
push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh
push: copy2sd/000root/install-recovery-xionia.sh -> /sdcard/000root/install-reco
very-xionia.sh
push: copy2sd/000root/install-recovery-xionia-misc.sh -> /sdcard/000root/install
push: copy2sd/000root/install-recovery-vj-misc.sh -> /sdcard/000root/install-rec
overy-vj-misc.sh
push: copy2sd/000root/install-recovery-vd.sh -> /sdcard/000root/install-recovery
-vd.sh
push: copy2sd/000root/install-recovery-common.sh -> /sdcard/000root/install-reco
very-common.sh
push: copy2sd/000root/install-misc-common.sh -> /sdcard/000root/install-misc-com
mon.sh
push: copy2sd/000root/install-cleanup.sh -> /sdcard/000root/install-cleanup.sh
push: copy2sd/000root/install-cleanup-cache.sh -> /sdcard/000root/install-cleanu
p-cache.sh
push: copy2sd/000root/func.inc.sh -> /sdcard/000root/func.inc.sh
push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image
push: copy2sd/000root/busybox -> /sdcard/000root/busybox
16 files pushed. 0 files skipped.
2281 KB/s (2482507 bytes in 1.062s)
push: copy2sd-img/000root/xionia_cwma_12518.6.img -> /sdcard/000root/xionia_cwma
_12518.6.img
push: copy2sd-img/000root/recovery_vj.img -> /sdcard/000root/recovery_vj.img
push: copy2sd-img/000root/recovery_vd.img -> /sdcard/000root/recovery_vd.img
3 files pushed. 0 files skipped.
2423 KB/s (17641472 bytes in 7.109s)
- exec '/system/bin/sh' failed: No such file or directory (2) -
---- END LOG ----
Getting ready to reboot...
And after reboot, I get the same 'E:Can't find command file CACHE:recovery command Installation aborted. no valid image in ACHE.
Anyway, Thanks tough
Getting ready to
---- BEGIN LOG ----
very-xionia.sh
overy-vj-misc.sh
-vd.sh
very-common.sh
mon.sh
p-cache.sh
_12518.6.img
---- END LOG ----
