Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 128
Like Tree15Likes
    Default [Beta] ZVJ rooting automation - please help test
    This has left Beta stage and been released here:
    [How-To] Automated Rooting of LS670ZVD/ZVH/ZVJ
    Thanks everyone for help testing and your feedback. You've made the process much clearer for future rooters.
    I'll do a more detailed writeup but needed to get some help testing this out for now:
    optiauto-beta7-sfx.exe [ / ]
    PLEASE ENABLE SCROLL BUFFERS USING OPTION H on the main page.
    This will allow you to cut/paste the full log if something goes wrong so I can figure out what happened.
    I've made it about 95% automated (don't need to type anything), but certain functions need to be performed on the phone in recovery. (ie applying update.zip)
    You MUST be ALREADY ROOTED to use Option B - ZVJ Root
    Included in this package is the Automated Root for ZVH/ZVD so if you aren't rooted yet on your existing ROM, you can use Option A to root.
    If you are already on ZVJ, then you will need to revert to ZVD using this thread:
    [How-To] Simplified UNROOT and return to STOCK
    and then root using Option A.
    Basically double-click on the .exe, choose Option B - Install Root - ZVJ
    Then go through each step, it should be self-explanatory
    You do NOT need to download the ZVJ update.zip, it is included in this package.
    Attached Thumbnails Attached Thumbnails [Beta] ZVJ rooting automation - please help test-root-opti-11.1.jpg   [Beta] ZVJ rooting automation - please help test-root-opti-11.2.6.jpg   [Beta] ZVJ rooting automation - please help test-root-opti-11.2.7.jpg
    [How-To] Rooting LS670ZVH
    Installed ZVH by mistake? Use simple update.zip to revert to ZVD / Froyo
    Thanked by 18:
    + Show/Hide list of the thanked
  2. #2
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Default
    At work so.I can't play with it today. If it works as it should, that would rock!
  3. #3
    garwynn's Avatar
    Posts
    ROM
    Stock! (For now...)
    Default Re: [Beta] ZVJ rooting automation - please help test
    Test phone is on ZVD+rooted so I can try this out. Only problem is the site that you gave is blocked at work.
    Can you send it by PM by any chance? Be happy to test it out.
    Also, just curious - I know you help work magic on the E4GT ODIN TARs (in addition to others).
    Is it possible that we could somehow pull something off like that using KP500?
    (Like a ZVJ+root option)
  4. #4
    hlxanthus's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by garwynn View Post
    Sfhub, would you mind posting a mediafire mirror?
  5. #5
    garwynn's Avatar
    Posts
    ROM
    Stock! (For now...)
    Quote Originally Posted by hlxanthus View Post
    MF also blocked along with other typical drop sites.
    I might try running to a place with free Wi-Fi and try downloading during lunch. As long as it's under 256 MB I'll be good. Will report back this afternoon.
  6. #6
    Default
    Dl link broken?
    Sent with telepathic powers
  7. #7
    Default
    Dl link broken?
    Edit computer was being stupid
  8. #8
    ijroorda's Avatar
    Posts
    ROM
    GingerROM/HydroKernel
    I tested this solution from un-rooted ZVD through to rooted ZVJ. I ran into one issue:
    On step B of the ZVJ root, the phone does not reboot into recovery - it just reboots. I had to power down and manually boot into recovery. From there, step C worked correctly.
    Other than that one hiccup, it worked great. Thanks for the work on this sfhub!
    Thanked by:
    Zhara
  9. #9
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    worked good for me ,1 issuse tho, i could not get it to root through the root package i had to flash su and install busybox manually
    Great work tho....Thanks
    If i Helped Please Hit The Thanks And Like Button
  10. #10
    garwynn's Avatar
    Posts
    ROM
    Stock! (For now...)
    OK, got it during lunch, ran it on a clean KP500 ZVD + root. Skipped wipe for obvious reasons but everything else worked as advertised, including the reboot recovery steps!
    I did have it happen to me yesterday when I did "adb reboot recovery" and it rebooted normally on wife's phone but same step. Maybe something to look into but rather minor. Other than that a great and very easy rooting solution!
  11. #11
    So help me understand.
    If my phone is already rooted in ZVD then option B will update the phone to ZVJ and maintain the rooted status?
    Will doing this maintain all my current software and settings that have been downloaded and configured, or will I have to redownload all my old data.
    I have link2SD and do not want to have to reinstall eveything or re-link everything.
    Thanks.
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by ijroorda View Post
    Apparently there is some issue with doing automated reboots through adb.
    I've had seen this issue periodically in the past, but forgot about it since it doesn't happen on the Samsung GS2.
    I don't know if the problem is with the adb on the phone or the adb client.
    Anyway, the workaround is to just repeat Step B. It almost always reboots the 2nd time around.
    I'll add a note to call attention to this workaround.
    Thanks for testing things out.
  13. Thread Author  Thread Author    #13
    Quote Originally Posted by benny3 View Post
    Do you have more details about this?
    I would like to fix this if it is repeatable.
  14. #14
    just tested it out. so far it seems to have rooted to zv. but with many bugs. my home button no longer functions. and when i long press the power button i no longer can silence my phone or put it into airplane mode. only power on and off. im sure theres more
    im going back to stock for now. these few things are annoying enuf
  15. Thread Author  Thread Author    #15
    Quote Originally Posted by blkphnt View Post
    Did you perform a factory reset?
    Those aren't bugs that would be introduced by the rooting process. If you are seeing those type problems they would be there even if you had installed the ZVJ update and never rooted it.
  16. #16
    Quote Originally Posted by sfhub View Post
    i returnded to zvd and rooted it and followed the instructions. and i factory reset it.idk. maybe it was a user error. i need my phone right now for life ya know but ill try again later to see it works and let you know
    but when i had stock zvj b4 i returned to zvd i didnt have these issues
  17. Thread Author  Thread Author    #17
    If you run it again, check closely in the log to see if there were any errors in the first step "install ZVJ recovery"
  18. #18
    I'm running rooted ZVH with custom (Xionia) recovery. Do I need to go back to stock recovery before trying this?
    Thanks for the great work!
  19. Thread Author  Thread Author    #19
    Quote Originally Posted by my.ads0 View Post
    If you are already rooted, there is nothing else you need to download or do ahead of time.
    Just follow every step in Option B.
    It will automatically give you the recovery you need and will put the ZVJ update.zip in place so you don't need to download that either.
    I'm about to upload Beta2, so if you can wait 15 mins, I'll have the new link up.
  20. #20
    Sounds good!
  21. Thread Author  Thread Author    #21
    Sounds good!
    Beta2 link is up on the first post.
  22. #22
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    Do we install stock LG recovery, then root ZVJ?
  23. #23
    garwynn's Avatar
    Posts
    ROM
    Stock! (For now...)
    Quote Originally Posted by telemike View Post
    Stock ZVH recovery is the first step in this automated process.
  24. #24
    Sdude1200's Avatar
    Posts
    ROM
    Stock.... for now
    Default
    Currently downloading beta 2 to test it out now.
  25. #25
    mike9670's Avatar
    DROID Master
    Posts
    Global Posts
    790 Global Posts
    ROM
    4.1.1
    Signature verification failure on update.zip
