Results 1 to 7 of 7
- 04-09-2012, 12:51 PM
Thread Author #1
Optimus S stuck a "android" startup screen. How do I fix it?
I had CM7 on my Optimus S, and I was trying to downgrade the radio as per this thread (Official Sprint ZVD / Froyo downgrade now available), and after I did Step A (applied the update.zip) I could no longer get the phone to boot up.
I see the Sprint splash screen, but then the phone seems to stay at the "Android" screen for a long, long time, and never goes anywhere. I've tried multiple battery pulls.
I am able to get to the stock recovery, but I don't know what to do there.
I backed up my data, so I'm not worried about that. I'm just trying to figure out the best way to get a functioning phone again. Any suggestions? - 04-09-2012, 01:01 PM #2
- 04-09-2012, 01:03 PM #3
- 04-09-2012, 01:04 PM #4
Verify the zvd update.zip is on the root of the SD card (not in any folder) and is named update.zip
Boot to xionia/ stock recovery, perform a wipe data/ factory reset. Really apply zvd update.zip and reboot
Sent from my LS670 using Tapatalk - 04-09-2012, 01:17 PM
Thread Author #5
Re: Optimus S stuck a "android" startup screen. How do I fix it?
I should have thought of wiping the data/cache afterwards! Wiping it from stock recovery fixed it.
I applied the update.zip from the custom recovery initially. My goal was to fix a problem my mom was having with this Optimus S. She would intermittently miss phone calls (the phone wouldn't even ring), and I didn't know if it could be a CM7 or a baseband problem.
I thought it may possibly have something to do with baseband because it showed "Unknown" under the baseband version on the phone. - 04-09-2012, 01:27 PM #6
- 04-09-2012, 03:13 PM #7
Reply
