It seems that I am too stupid to figure out how to make a nandroid backup.
All the tutorials I find on the interwebs refer to using Rom Manager which if you look at the stickies, will brick my phone.
I am rooted, I have Xionia recovery and found these instructions in another thread:
I dont know what all of that means, (using terminal? how does one activate a terminal?)
"flash_image recovery /sdcard/"name of recovery image" [what should this be called in this case?
Basically, I am asking one of you Android guru types to write up a sticky for making a Nandroid Backup for your phones that have been rooted using the simple rooting techniques here.
I have made copies of all the files my phone had when it was working right, but thats not a Nandroid backup. I can rebuild the phone to stock, and I am glad of that.
Thanks for the help/
I'm pretty sure u need to be rooted so that u can flash a custom recovery. The custom recovery is what u use to make a back up. Just root your phone. Place "flash_image" on the root of your sdcard. The place a custom recovery image on the root of your sdcard then using terminal type
su
reboot recovery
su
reboot recovery
