I need help rooting my phone, it's an LG Optimus S LS670
czifro
56
7
Are you on zvh or zvj? Which rooting methods have you tried?
This will root you no matter what baseband you are on, but you still need to check if you have zvh or zvh first so you know where to start: http://forums.androidcentral.com/showthread.php?t=166929
The zvj upgrade/root only works if you are already rooted. So, if you have zvh run option A then option B to achieved rooted zvj. If you have zvj via sprint, then downgrade first to zvd and root that, then run option B. either way root is required to do option B.
Zhara
Queendroid
Apr 4, 2012
891
200
Ah, right. What he said. :p
